[Solved] Anyone else having issues creating a new file when inside a sketch?
Hologram
Post by Hologram »
For some reason, I can't seem to create a new file when I am in the Sketcher workbench and editing a sketch. When I close out of the task, I can immediately hit Ctrl + N and create a new file. I have tested the file > new menu, the new button on the toolbar and Ctrl + N and none of them can be used to create a new file as long as I am editing a sketch in any of the documents that are open (even if it is not the active document).
OS: Windows 10 Version 2009
Version: 0.21.0.31391 (Git)
Hash: 0ab2608a429f3a5ee9a63da9b66d13557655d7e4
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * BIM 2021.12.0
  * Launcher
  * persistenttoolbars
  * SelectorToolbar
drmacro
Re: Anyone else having issues creating a new file when inside a sketch?
Post by drmacro »
The Combo view has an open dialog...it blocks the creation of a new document, it blocks the deletion of the sketch or other features, etc.
Hologram
Post by Hologram »
Ah right, makes sense. Was suspecting that to be the case as well. Good to know it's a known issue.
It's mostly that this dialog isn't as obvious when you have both a comboview and a tree view window open. 😅
drmacro
Post by drmacro »
Hologram wrote: Thu Feb 02, 2023 7:15 pm Ah right, makes sense. Was suspecting that to be the case as well. Good to know it's a known issue.
I wouldn't call it an issue, I'd call it designed and expected behaviour. :roll:
Hologram
Post by Hologram »
I don't mind the terminology, it's expected behaviour, that's all I wanted to know. 😜
