Freecad 0.21 Possible GUI issues
SNicker317
Post by SNicker317 »
OS: macOS 10.16
Version: 0.21.0.31739 (Git)
Hash: 37dc6e8a296073bf5c437b975d8fb236f923723f
Python 3.10.8, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
  * ThreadProfile 1.84.0
  * dodo 1.0.0
  * ProDarkThemePreferencePack 1.0.0
  * FeedsAndSpeeds 0.5.0
  * Dracula 0.0.2
  * A2plus 0.4.60i
  * Manipulator 1.5.0
  * fasteners 0.4.54
  * lattice2 1.0.0
  * Estimate 0.1.2
  * ExtremeProDark 2.6.4
  * sheetmetal 0.2.61
  * ExplodedAssembly
  * Help 1.0.3
  * Curves 0.6.5
  * Assembly4 0.12.5
  * Assembly3 0.11.4
issue#1. When entering or leaving the Sketcher the program instantly returns to the Start Page.
issue#2. In TechDraw, the increase or decrease decimal places button and entries do nothing when used on a drawing created with a past version of freecad (Ver 19). Buttons do appear to be working on new drawings that were created with ver 21.
Thanks for all your great work and aid.
adrianinsaval
Re: Freecad 0.21 Possible GUI issues
Post by adrianinsaval »
can you provide working and not working example files for issue #2? issue #1 is a known problem specific of macOS I think, not sure if the cause has been identified but you can search the forum for a thread about that, IIRC it's not directly related to startpage but it rather always returns to the first tab.
In general I recommend you create separate threads for separate issues as the discussion can become very confusing if both are mixed.
wandererfan
Post by wandererfan »
SNicker317 wrote: Thu Feb 02, 2023 3:29 pm issue#2. In TechDraw, the increase or decrease decimal places button and entries do nothing when used on a drawing created with a past version of freecad (Ver 19). Buttons do appear to be working on new drawings that were created with ver 21.
If you want to change how many decimals a dimension uses after you've created the dimension, then change the format specification in the property editor.
SNicker317
wandererfan wrote: Thu Feb 02, 2023 6:45 pm
OK, I see now whats happening, it's defaulting to "%.2w" which ignores trailing 0's after the decimal. Need to change tp "%0.2f" to show trailing 0's... then buttons works as expected.
SNicker317
adrianinsaval wrote: Thu Feb 02, 2023 5:04 pm can you provide working and not working example files for issue #2? issue #1 is a known problem specific of macOS I think, not sure if the cause has been identified but you can search the forum for a thread about that, IIRC it's not directly related to startpage but it rather always returns to the first tab.
Sorry for the multi-issues , in the future I will split up...
Regards
