[Solved] Help with a macro
jfc4120
Post by jfc4120 »
OS: Windows 10 Version 2009
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * Help 1.0.3
I have two macros, one works only if there are two lines to get angle, the other works if a closed wire and gets the angle between two selected edges.
They are still in work, but do work. I am trying to figure out how to handle all in a single macro.
I would also like the macro to get the angle between an edge and a line from sketcher (all in same plane) of course.
Angle between lines macro:
import FreeCAD, FreeCADGui
# -*- coding: utf-8 -*-
import Draft
import math
# from math import cos, sin, radians
from PySide import QtGui
convert = 25.4
TOTAL = 0
getDouble = QtGui.QInputDialog.getDouble
Vector, Placement = App.Vector, App.Placement
doc = App.ActiveDocument
start_point = Vector(0, 0, 0)
#inserted
edge = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0]
edgePt1 = edge.Vertexes[0].Point
edgePt2 = edge.Vertexes[1].Point
vect = edgePt1 - edgePt2
#here
s=Gui.Selection.getSelectionEx()
edge=s[0].SubObjects[0]
x0 = edge.firstVertex().Point.x * .039370078
y0 = edge.firstVertex().Point.y * .039370078
z0 = edge.firstVertex().Point.z * .039370078
x1 = edge.lastVertex().Point.x * .039370078
y1 = edge.lastVertex().Point.y * .039370078
z1 = edge.lastVertex().Point.z * .039370078
edge2=s[1].SubObjects[0]
x2 = edge2.firstVertex().Point.x * .039370078
y2 = edge2.firstVertex().Point.y * .039370078
z2 = edge2.firstVertex().Point.z * .039370078
x3 = edge2.lastVertex().Point.x * .039370078
y3 = edge2.lastVertex().Point.y * .039370078
z3 = edge2.lastVertex().Point.z * .039370078
if x0 == x2 and y0 == y2:
    p1 = App.Vector(x0, y0, z0)
    p2 = App.Vector(x1, y1, z1)
    p3 = App.Vector(x3, y3, z3)
if x0 == x3 and y0 == y3:
    p3 = App.Vector(x2, y2, z2)
if x1 == x2 and y1 == y2:
    p1 = App.Vector(x1, y1, z1)
    p2 = App.Vector(x0, y0, z0)
if x1 == x3 and y1 == y3:
ang1 = math.degrees((p2 - p1).getAngle(p3 - p1))
print(ang1)
#good ang2 = math.degrees((p3 - p2).getAngle(p1 - p2))
#ang2 = math.degrees((p1 - p2).getAngle(p3 - p2))
#print(ang2)
#ang3 = degrees((p1 - p3).getAngle(p2 - p3))
#The side lengths are:
#Code: Select all
#L12 = (p1 - p2).Length
L12 = (p2 - p1).Length
print(L12)
#L23 = (p2 - p3).Length
#L31 = (p3 - p1).Length
#pt = App.Vector(multlist[0][0] * convert, multlist[0][1] * convert, multlist[0][2] * convert)
#t1 = round(ang1, 3)
#t11 = str(t1)
#text1 = Draft.make_text(t11, pt)
#print('p1',p1)
Angle between edges code:
import Draft
import math
convert = 25.4
TOTAL = 0
#inserted
#here
x0 = edge.Vertexes[0].Point.x * .039370078
y0 = edge.Vertexes[0].Point.y * .039370078
z0 = edge.Vertexes[0].Point.z * .039370078
x1 = edge.Vertexes[1].Point.x * .039370078
y1 = edge.Vertexes[1].Point.y * .039370078
z1 = edge.Vertexes[1].Point.z * .039370078
edge2 = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[1]
x2 = edge2.Vertexes[0].Point.x * .039370078
y2 = edge2.Vertexes[0].Point.y * .039370078
z2 = edge2.Vertexes[0].Point.z * .039370078
x3 = edge2.Vertexes[1].Point.x * .039370078
y3 = edge2.Vertexes[1].Point.y * .039370078
z3 = edge2.Vertexes[1].Point.z * .039370078
print(ang1)
#print(ang2)
#Code: Select all
print(L12)
#t11 = str(t1)
#print('p1',p1)
And I haven't figured out the other yet. I have another macro that does all 3 using points that works, but I'd like to do it with just 2 lines / edges selected.
Thanks.
angle_test22.FCStd
(11.98 KiB) Downloaded 14 times
jfc4120
Re: Help with a macro
Post by jfc4120 »
For now I am not going to go ahead with it, here's why:
18:50:28  x0 -15.627980554039395
18:50:28  x0 -24.59290367941755
18:50:28  x2 -61.32742673799614
18:50:28  x3 -24.59290367941754
When printing out values for test, even though above x0 is supposed to be equal to x3, it's not.
Even though draft snap to end point was used. I will just use my 3 point macro that @edwilliams16 helped me with.
But if anyone figures this out please reply.
edwilliams16
Post by edwilliams16 »
Let me see if I understand what you want. You want the angle between two coplanar edges that you select.
  • Do the two edges share a vertex?
  • If they don't, should we check if they are actually coplanar?
  • Are they edges of the same object, or could they be from different objects?
  • Should we check if two edges have actually been chosen?
  • Which angle, interior or exterior do you want to return?
  • Do the two edges belong to objects in a common coordinate system
  • If not, could either object be a linked object?
Note that in your code, you convert inches to mm. This is unnecessary if you are computing angles as they don't depend on the length unit.
jfc4120
Post by jfc4120 »
Yes coplanar, they could be two separate lines or two wires connected. And yes always a vertex. Unless there's a fairly simple way to find the angle even if they don't have a vertex would be good too.
And I have dropped the idea about the sketch line I will just use the three points macro for that.
I played around a little more and got the one with two separate lines working by rounding to six decimal places.
I just thought it would be nice to have one where you can select two edges or two lines.
One problem also is I have to click with mouse to select if you select from the tree then the end points show and there are errors you probably know what I mean.
I am almost positive I have gotten in over my head here.
At least I have the three-point macro that definitely works.
dan-miel
Post by dan-miel »
jfc4120 wrote: Wed Feb 01, 2023 10:50 pm And I haven't figured out the other yet. I have another macro that does all 3 using points that works, but I'd like to do it with just 2 lines / edges selected.
You might install the Quick Measure Add-in and take a look at the code. It measures edges and other features and returns measurements in the units that are in the settings. I hope the coding helps.
Dan
edwilliams16
edwilliams16 wrote: Thu Feb 02, 2023 1:35 am Let me see if I understand what you want. You want the angle between two coplanar edges that you select.
Not necessarily
Yes
Either
Yes
Both
Use global coordinates
Can be
from math import degrees
vlocs =[] #collect locations of vertices
for sel in Gui.Selection.getSelectionEx('',0):
    for path in sel.SubElementNames if sel.SubElementNames else ['']:
        subObj = sel.Object.getSubObject(path)
        if subObj.ShapeType == 'Edge':
            vlocs.append(subObj.Vertexes[0].Point) #global vertex location
            vlocs.append(subObj.Vertexes[1].Point)
if len(vlocs) == 4: #two edges selected
    print(vlocs)
    if vlocs[2].isEqual(vlocs[0], 1e-7) or vlocs[2].isEqual(vlocs[1], 1e-7):#swap 2 & 3 if 2 is vertex
       temp = vlocs[2]
       vlocs[2] = vlocs[3]
       vlocs[3] = temp
    p = Part.Plane(vlocs[0], vlocs[1], vlocs[2])
    if abs(p.projectPoint(vlocs[3], "Distance")[0]) < 1e-7: #check coplanar
        ang = degrees((vlocs[0]-vlocs[1]).getAngle(vlocs[2] - vlocs[3]))
        print(f'Angles are {ang}  {180 - ang}')
    else:
        print('Edges are not coplanar')
else:
    print('Select two edges')
EDIT: fixed bug if two endpoints were the same.
jfc4120
Post by jfc4120 »
Working on 2 wire edges or 2 lines, but two other edges not.
See the selected in image:
I get:
Edges are not coplanar, but they are. FIle attached also.
In one image, sorry I mis-spelled menu.
angle_test22.FCStd
(13.21 KiB) Downloaded 22 times
jfc4120
Post by jfc4120 »
Another test, front view worked, home view did not, attached.
angle_test222.FCStd
(11.07 KiB) Downloaded 16 times
edwilliams16
@jfc4120
Yes. I forgot two edge endpoints could coincide. Fixed above...
jfc4120
Post by jfc4120 »
@edwilliams16 Believe it or not, as short as that code is, I don't understand how it works, but it does. :? :D 8-)
Thanks, it's nice to do a quick angular measure in draft home view, if you saw the other post, freecad does not give accurate angular dimensions in home view, the 3d home view.
@dan-miel Thank you for your reply, I will have a look.
