using an external workbench (Woodworking) with an AppImage
dbyy
Post by dbyy »
I just came across of the external workbench "Woodworking" for FreeCad.
Is there a way known whether I can an external workbench with an Linux AppImage (0.20.2)?
I know how to 'install' this workbench on a conventional installed FreeCAD on Linux, however I would like to use it with the latest AppImage.
Any help is much appreciated..
TIA
onekk
Re: using an external workbench (Woodworking) with an AppImage
Post by onekk »
dbyy wrote: Wed Feb 01, 2023 3:22 pm Hello,
TIA
If is in the AddOn Manager there is no problem to install it in an AppImage, as the AddoOn are installed in "FreeCAD user directory".
if the Wb is not made available using AddOn Manager it is as simple to install by hand the WB downloaded maybe from github in the Mod subdir of your "FreeCAD user directory".
But beware that is WoodWorking WB is what I think, it is developed to be compatible with 0.20.0 and not the point releases, by designer choice.
Regards
Carlo D.
- Various other stuffs.
adrianinsaval
Post by adrianinsaval »
appimage can run external wrokbenches like any other freecad version, the external workbenches are installed in a user directory
dbyy
Post by dbyy »
> adrianinsaval:
Interesting reply.
But what or better where is the 'user directory' you're referencing to?
I tried two things, I added under preferences > Ad-on Manager > Custom repositories
a) the location of tre workbench on Github, and
b) a references to the extracted workbench on a local folder.
The Appimage keeps this information even after relaunch but the workbench is still not visible in the list of workbenches.
Any other trick?
jimb
Post by jimb »
The info is all in the woodworking workbench installation instructions
cd ~/.local/share/FreeCAD/Mod/
git clone https://github.com/dprojects/Woodworking.git
dbyy
Post by dbyy »
Good tip, Thanks.
(folder '`/.local/share/FreeCAD/Mod' didn't exist. Had to create it.)
Cheers
