How to test if object's display mode includes "Shaded"
DorinDXN
Post by DorinDXN »
Hi all, hope you're well :)
To avoid this error
.. 'Shaded' is not part of the enumeration
How to test if object's display mode includes (i.e. can accept) "Shaded"?
This is not working
if App.ActiveDocument.getObject"Test").ViewObject.DisplayMode.includes("Shaded"):
cheers,
Dorin
Chris_G
Re: How to test if object's display mode includes "Shaded"
Post by Chris_G »
You can get the list of available display modes with :
obj.ViewObject.getEnumerationsOfProperty("DisplayMode")
So the test statement will be :
if "Shaded" in obj.ViewObject.getEnumerationsOfProperty("DisplayMode"):
DorinDXN
Post by DorinDXN »
Thnks for reply,
it doens't work as expected,
in FreeCAD 0.18 raises
'Gui.ViewProviderDocumentObject' object has no attribute 'getEnumerationsOfProperty'
in FreeCAD 0.21 there is no error but returns False even if the objects accepts "Shaded"
but I solved due to the fact that all objects I want to set as "Shaded" and I cannot,
had either "Base" or "Group" so, for now, I'm using this workaround
if not(("Base" == App.ActiveDocument.getObject(s[p].Name).ViewObject.DisplayMode) or ("Group" == App.ActiveDocument.getObject(s[p].Name).ViewObject.DisplayMode)):
which works in FC 0.18 and not in FC 0.21
but I'll use FC 0.18 anyways
cheers,
Dorin
