Draft is not showing the correct angle dimension
thomas-neemann
Re: Draft is not showing the correct angle dimension
Post by thomas-neemann »
Roy_043 wrote: Mon Jan 30, 2023 7:45 am Thanks, but this solution has already been given twice in this topic.
sorry, didn't read everything
jfc4120
Post by jfc4120 »
I discovered that the part measure angular also gives the wrong dimension.
However if you draw a line over the sketch line, then delete the sketch you get the correct angles.
