Roy_043 wrote: ↑Sat Jan 28, 2023 7:24 pm
Gui.Selection.addSelection('Unnamed','Wire') is the result of Draft.select:
You mean the second addSelection? The first addSelection is presumably the result of the step 4 and that does not involve Draft.select as far as I can tell.
But which code is responsible for
Gui.Selection.clearSelection() (occurs 2x)?
It's the same "normal" selection code (see backtrace below) that works based on 3D view mouse events whether the Draft_Move is active or not. From your console log I can see that the first point you selected was outside the wire and in fact outside of any object. But if you had clicked over an edge of the wire (even if due to snapping the actual starting point would end up being elsewhere), in addition to clearSelection(), there would have been something like
Gui.Selection.addSelection('Unnamed','Wire','Edge1',98.285,85.9994,0)
And it could be some other object. In the screenshot below I'm moving draft wire -triangle but starting point was over an edge of a rectangle, so the edge of that rectangle is selected.
And once you select the end point, the same thing happens again and you either end up with something selected or not depending on what is "under" the second point.
#0 0x0000155553fbefa0 in Gui::SelectionSingleton::clearSelection(char const*, bool)@plt () at /usr/local/freecad/lib/libFreeCADGui.so
#1 0x000015555463c51f in Gui::NavigationStyle::processEvent(SoEvent const*) (this=0x55555c2a6830, ev=0x55555c2a3e30) at ../src/Gui/NavigationStyle.cpp:1498
#2 0x0000155554681559 in Gui::View3DInventorViewer::processSoEvent(SoEvent const*) (this=0x55555c28cba0, ev=0x55555c2a3e30) at ../src/Gui/View3DInventorViewer.cpp:2275
#3 0x0000155554617813 in SIM::Coin3D::Quarter::EventFilter::eventFilter(QObject*, QEvent*) (this=0x55555c2a46c0, obj=0x55555c28cba0, qevent=0x7fffffffc010) at ../src/Gui/Quarter/EventFilter.cpp:167
#4 0x00001555503dc51b in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) (event=<optimized out>, receiver=<optimized out>) at kernel/qcoreapplication.cpp:1214
#5 QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) (receiver=receiver@entry=0x55555c28cba0, event=event@entry=0x7fffffffc010) at kernel/qcoreapplication.cpp:1203
#6 0x0000155550df6a55 in QApplicationPrivate::notify_helper(QObject*, QEvent*) (this=this@entry=0x5555556f27c0, receiver=receiver@entry=0x55555c28cba0, e=e@entry=0x7fffffffc010) at kernel/qapplication.cpp:3694
#7 0x0000155550e00343 in QApplication::notify(QObject*, QEvent*) (this=<optimized out>, receiver=0x55555c2a02c0, e=0x7fffffffc500) at kernel/qapplication.cpp:3160
#8 0x00001555541902c0 in Gui::GUIApplication::notify(QObject*, QEvent*) (this=0x7fffffffd110, receiver=0x55555c2a02c0, event=0x7fffffffc500) at ../src/Gui/GuiApplication.cpp:85
#9 0x00001555503dc80a in QCoreApplication::notifyInternal2(QObject*, QEvent*) (receiver=0x55555c2a02c0, event=0x7fffffffc500) at ../../include/QtCore/../../src/corelib/kernel/qobject.h:142
#10 0x0000155550dff457 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool)
(receiver=receiver@entry=0x55555c2a02c0, event=event@entry=0x7fffffffc500, alienWidget=alienWidget@entry=0x55555c2a02c0, nativeWidget=0x7fffffffd150, buttonDown=buttonDown@entry=0x1555513268d0 <qt_button_down>, lastMouseReceiver=..., spontaneous=true, onlyDispatchEnterLeave=false) at kernel/qapplication.cpp:2646
#11 0x0000155550e5535d in QWidgetWindow::handleMouseEvent(QMouseEvent*) (this=0x555557554e20, event=0x7fffffffcba0) at /usr/include/c++/9/bits/atomic_base.h:413
#12 0x0000155550e581ec in QWidgetWindow::event(QEvent*) (event=0x7fffffffcba0, this=0x555557554e20) at kernel/qwidgetwindow.cpp:289
#13 QWidgetWindow::event(QEvent*) (this=0x555557554e20, event=0x7fffffffcba0) at kernel/qwidgetwindow.cpp:232
#14 0x0000155550df6a66 in QApplicationPrivate::notify_helper(QObject*, QEvent*) (this=this@entry=0x5555556f27c0, receiver=receiver@entry=0x555557554e20, e=e@entry=0x7fffffffcba0) at kernel/qapplication.cpp:3700
#15 0x0000155550e000f0 in QApplication::notify(QObject*, QEvent*) (this=0x7fffffffd110, receiver=0x555557554e20, e=0x7fffffffcba0) at kernel/qapplication.cpp:3446
#16 0x00001555541902c0 in Gui::GUIApplication::notify(QObject*, QEvent*) (this=0x7fffffffd110, receiver=0x555557554e20, event=0x7fffffffcba0) at ../src/Gui/GuiApplication.cpp:85
#17 0x00001555503dc80a in QCoreApplication::notifyInternal2(QObject*, QEvent*) (receiver=0x555557554e20, event=0x7fffffffcba0) at ../../include/QtCore/../../src/corelib/kernel/qobject.h:142
#18 0x00001555507c77d3 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) () at /lib/x86_64-linux-gnu/libQt5Gui.so.5
#19 0x00001555507c910b in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) () at /lib/x86_64-linux-gnu/libQt5Gui.so.5
#20 0x00001555507a335b in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) () at /lib/x86_64-linux-gnu/libQt5Gui.so.5
#21 0x0000155549ded32e in () at /lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#22 0x000015554e08817d in g_main_context_dispatch () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#23 0x000015554e088400 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#24 0x000015554e0884a3 in g_main_context_iteration () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#25 0x0000155550434435 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) (this=0x5555558093d0, flags=...) at kernel/qeventdispatcher_glib.cpp:422
#26 0x00001555503db3ab in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) (this=this@entry=0x7fffffffcf40, flags=..., flags@entry=...) at ../../include/QtCore/../../src/corelib/global/qflags.h:140
#27 0x00001555503e3116 in QCoreApplication::exec() () at ../../include/QtCore/../../src/corelib/global/qflags.h:120
#28 0x000015555402ef6e in Gui::Application::runApplication() () at ../src/Gui/Application.cpp:2265
#29 0x0000555555566987 in main(int, char**) (argc=1, argv=0x7fffffffdda8) at ../src/Main/MainGui.cpp:270
- Screenshot_20230129_205341.png (319.1 KiB) Viewed 689 times
