Calculating a rotation with two parameters?
freedman
Re: Calculating a rotation with two parameters?
Post by freedman »
Ed, I haven't tried to run your code yet but my issues are normally based around the GUI and control. I create a spinbox and then need to give the user control of something simple enough to use. That's why I like this:
box_obj.Placement.Matrix.rotateX(math.radians(1))
It's one line of code that corresponds directly with a editable field angle. In my case building a rotation, to keep it simple, two fields, essentially lat. and Long. control of a rotation.
I also have to say it's one line of code I don't have to think about when I look at it, after a week of or so I forgot the rotation stuff. :)
Here is a video of the control that I have over each of the coil Bodies as I build the armature.
Thanks all
edwilliams16
Post by edwilliams16 »
@freedman
What happens if you adjust both azimuth and inclination in your model? Does it matter in which order they were adjusted?
The most obvious difficulty with the rotateX, rotateY, rotateZ API I see is generating rotations about axes other than the principal ones. You probably have to use attachments to line up the principal axes with the ones you need. Nothing wrong with that - I'm just pointing out where you could run into a road block.
freedman
Post by freedman »
Video; the order doesn't matter, I think it can be seen.
And yes I am applying this to a sketch placement. I take the current sketch placement and make a copy, then apply all my placement changes to the copy, so there can be multiple. Once all the changes are cranked in I copy the new Placement back to the sketch. This gives really good performance visually.
Lots of control for a couple inputs.
Thanks
edwilliams16
@freedman
So you are adjusting the parameters of a App.Placement(yaw, pitch, roll) not directly manipulating the object the rotateX. rotateY, rotateZ API?
In that case the order is built-in to the constructor.
BTW, the best way to animate a rotation is using the slerp() method:https://wiki.freecadweb.org/Sandbox:Edw ... polation.) or sclerp() for a placement change. It provides a simple interpolation scheme between two rotations or placements respectively. You just vary a parameter from 0 to 1 to go from one to the other. Much simpler than calculating the increment by hand.
freedman
Post by freedman »
Here is the core code of the assembler: If you feed it a Sketch and a Body it will connect the origins and do the rotations shown in the videos. Ed, your the expert on modifing placements, if you see any way to simplify this I am interested. The Conx_ stuff is supporting added properties.
I have 1200 lines of macro code to control everything and it's all based on these few lines ....
def go_ASM(self,my_sketch,my_body):
    my_body.Placement.Base.x = 0
    my_body.Placement.Base.y = 0
    try:
        self.sk_att = my_sketch.AttachmentOffset.copy()
    except: return
    self.sk_plc = my_sketch.Placement.copy()
    my_sketch.Placement.Matrix.rotateX(math.radians(my_body.Conx_XAxisRot))
    my_sketch.Placement.Matrix.rotateZ(math.radians(my_body.Conx_ZAxisRot))
    delta_global = App.Placement (App.Vector(0,0,my_body.Conx_Zoffset),App.Rotation(my_body.Conx_RotZ,0,0),App.Vector(0,0,0))
    my_sketch.Placement = my_sketch.Placement.multiply(delta_global) # use the changed copy placement to build new Placement
    rot_orig = FreeCAD.ActiveDocument.getObject(my_sketch.Name).getGlobalPlacement()    # build rotation with placement copy
    my_sketch.AttachmentOffset = self.sk_att  # copy back in the attachment offset
    my_sketch.Placement = self.sk_plc   # copy back in the placement
    prt_rot = my_body.getGlobalPlacement().multiply(my_body.Placement.inverse())
    my_body.Placement = prt_rot.inverse().multiply(rot_orig)
lamikr
Post by lamikr »
edwilliams16 wrote: Tue Jan 31, 2023 4:34 am @freedman
In general if you have for example a cubic and rotate it to different directions, then the order in which you rotate x, y, z matters to the end result in which position the cubic ends up being. So I was wondering how is this possible, but your explanation of that the order is already baked in to constructor could explain why it works.
Another thing that usually needs testing is what happens when rotating close to 90 or degree rotations. In some api's it easy to make weird rotation in corner cases. https://wang-yimu.com/gimbal-lock/
edwilliams16
edwilliams16 wrote: Tue Jan 31, 2023 4:34 am BTW, the best way to animate a rotation is using the slerp() method:https://wiki.freecadweb.org/Sandbox:Edw ... polation.) or sclerp() for a placement change. It provides a simple interpolation scheme between two rotations or placements respectively. You just vary a parameter from 0 to 1 to go from one to the other. Much simpler than calculating the increment by hand.
Here's sclerp in action:
import Part, time
doc = App.ActiveDocument
Gui.ActiveDocument.ActiveView.setAxisCross(True)
# Add a colored box
box_obj = doc.addObject('Part::Box', 'Box')
box_obj.recompute()
blue, green, red = (0.,0.,1.,0.), (0.,0.4,0.,0.), (1.,0.,0.,0.)
box_obj.ViewObject.DiffuseColor = [blue, (0.,0.,0.,1.),green ,(0.,0.,1.,1.),red ,(0.,0.,1.,1.)]
#reposition Box xyz if you like, -5 is default Box center
box_pl_start = App.Placement(App.Vector(-5.0,-5.0,-5.0), App.Rotation())
box_obj.Placement = box_pl_start
box_pl_end = App.Placement(App.Vector(25.0,25.0,25.0), App.Rotation(App.Vector(0, 0, 1), 45))
box_obj.recompute()
link = doc.addObject('App::Link','Link')
link.setLink(doc.Box)
link.Label = 'FinalBox'
link.Placement = box_pl_end
nsteps = 100
secs = 5
for i in range(nsteps+1):
    inc = i/nsteps
    time.sleep(secs/nsteps)
    box_obj.Placement = box_pl_start.sclerp(box_pl_end, inc)
    App.Gui.updateGui()
doc.recompute()
edwilliams16
freedman wrote: Tue Jan 31, 2023 6:17 am Here is the core code of the assembler: If you feed it a Sketch and a Body it will connect the origins and do the rotations shown in the videos. Ed, your the expert on modifing placements, if you see any way to simplify this I am interested. The Conx_ stuff is supporting added properties.
I couldn't disentangle your code in a reasonable amount of time. However, I did notice you used getGlobalPlacement(). This can be problematical if you have linked copies of the same sketch as in my demo file below.
In this situation, getGlobalPlacement() will always return the global placement of the original sketch - which is
Placement [Pos=(0,-10,2.22045e-15), Yaw-Pitch-Roll=(1.3494e-14,-45,90)]
(select a sketch, send to the Python Console with ctrl-shift-P and run obj.getGlobalPlacement() )
while that of the linked copy is actually
Placement [Pos=(7.07107,-7.07107,25), Yaw-Pitch-Roll=(45,-45,90)]
This may not be an issue depending on your usage of links.
linkedsketches.FCStd
(7.23 KiB) Downloaded 16 times
dtay
Post by dtay »
Hello Ed and Freedman,
It's great to see that the matrix works well for Freedman's needs. I concur with Ed that the matrix has its limitations and the Placement API is more suitable for complex rotations.
Regarding the sclerp code, it's certainly an interesting topic. However, it seems to have a quirk when crossing 180 degrees as it takes the shortest distance and rotates in the opposite direction.
I may have gotten carried away playing with/learning the Draft workbench in this code:
import Part, time, Draft
# Set final rotation angle - CCW<180  CW>180
finAng = 180
# Set dim text size
txSize = 2
fDoc= FreeCADGui.ActiveDocument
try:
    if fDoc.Box:
        doc.removeObject('Box')
        doc.removeObject('Link')
        doc.removeObject('Dimension')
        doc.removeObject('Dimension001')
        doc.removeObject('Dimension002')
except: pass
# Add box
box_obj.recompute()
# Color box - RGB
red, green, blue = (1.,0.,0.,0.), (0.,1.,0.,0.), (0.,0.,1.,0.)
box_obj.ViewObject.DiffuseColor = [red, (0.,0.,0.,1.),green ,(0.,0.,0.,1.),blue ,(0.,0.,0.,1.)]
#reposition Box, -5 is default Box center
box_pl_start = App.Placement(App.Vector(20,10.0,-25.0), App.Rotation())
box_pl_end = App.Placement(App.Vector(-20.0,-10.0,25.0), App.Rotation(App.Vector(0, 0, 1), finAng))
# Add XYZ dimensions
xDim = Draft.make_linear_dimension(App.Vector(0,0,0),App.Vector(0,0,0))
yDim = Draft.make_linear_dimension(App.Vector(0,0,0),App.Vector(0,0,0))
zDim = Draft.make_linear_dimension(App.Vector(0,0,0),App.Vector(0,0,0))
# set dim normals - best viewed from ISO
xDim.Normal, yDim.Normal, zDim.Normal = (0,0,1), (0,0,1), (1,0,0)
# Format dimensions
xD = fDoc.Dimension
yD = fDoc.Dimension001
zD = fDoc.Dimension002
dRed, dGreen, dBlue = (1.,0.,0.), (0.,1.,0.), (0.,0.,1.)
xD.ArrowType, xD.LineColor, xD.TextColor, xD.FontSize = u"Arrow", dRed, dRed, str(txSize)
yD.ArrowType, yD.LineColor, yD.TextColor, yD.FontSize = u"Arrow", dGreen, dGreen, str(txSize)
zD.ArrowType, zD.LineColor, zD.TextColor, zD.FontSize = u"Arrow", dBlue, dBlue, str(txSize)
#use Box placement to update dim lengths via expression
xDim.setExpression('.End.x', u'Box.Placement.Base.x')
yDim.setExpression('.End.y', u'Box.Placement.Base.y')
zDim.setExpression('.End.z', u'Box.Placement.Base.z')
def updateDims():
    #Flip dimension text on +/- side of coord
    xD.FlipText = doc.Box.Placement.Base.x < 0
    yD.FlipText = doc.Box.Placement.Base.y < 0
    zD.FlipText = doc.Box.Placement.Base.z < 0
    #use Box placement to update dim line positions
    yDim.Dimline = (doc.Box.Placement.Base.x,0,0)
    zDim.Dimline = (doc.Box.Placement.Base.x, doc.Box.Placement.Base.y,0)
    Gui.Selection.clearSelection()
nsteps = 100
secs = 5
    inc = i/nsteps
    updateDims()
    App.Gui.updateGui()
    doc.recompute()
edit: code fix
edwilliams16
dtay wrote: Wed Feb 01, 2023 2:06 am
Yes, slerp/sclerp will take shortest route. You'd need to break it up into segments to turn more than 180 degrees. Probably simpler to interpolate angle in an Axis/Angle representation in that case. Of course, the rotation axis becomes undefined at exactly 180 degrees.
EDIT: BTW, I think your script needs a
from FreeCAD import Vector as av
