Feature Request
Feature Request
FreeCAD 20.2
I have been using FreeCAD since version 0.9, and has come to do so many things right, I don't want this to sound like a complaint.
Using PART mode...
You create several components (cubes, cones spheres...), then use Cuts/Unions/Intersections to make what I'm calling an object. You then move the object around until you put it where you want it.
Oops! One of the cylinders isn't oriented correctly. If you delete the object to get at the components, all the components revert back to where they were before you moved the object. If you open the object to expose the tree, the components are all displayed where they started, just like if you had deleted the object. Now when you move the components inside the object, you're left to guess how that will display on the screen.
The way I am dealing with this problem now is: I try to move all the components to their final position before I create the object. That way, moving the components gives me the same thing I see when I close the tree to view the object.
In future versions it would be nice to have all the components move along with the changes in orientation of the objects. If you use Placement to move the components, Apply incremental Changes doesn't work until you press Apply. The same thing happens if you move components in Tree View.
P.S. In version 20.2, somebody forgot to include Help > About FreeCAD, unless you want us to read the version on the top line of the display.
Using PART mode...
"When the facts change, I change my mind. What do you do, sir?"
-- John Maynard Keynes
- Shalmeneser
Re: Feature Request
<Copy to clipboard> button ?fester2251 wrote: ↑Tue Jan 24, 2023 7:53 pm P.S. In version 20.2, somebody forgot to include Help > About FreeCAD, unless you want us to read the version on the top line of the display.
Re: Feature Request
fester2251 wrote: ↑Tue Jan 24, 2023 7:53 pm FreeCAD 20.2
I have been using FreeCAD since version 0.9,...
Using PART mode...
As a long term user it seems that you have not acquired enough confidence with FreeCAD terminology.
There is no "PART mode" there is a "Part WB"
Object is a solid made by CSG (Boolean Operations)
and so on.
Plus:
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
To supply correct infos about FreeCAD it has here for some time.
Kind regards.
Carlo D.
- Various other stuffs.
Re: Feature Request
Hi
conserve the original placement and possibility remain of the new placement (example compound created (0,0,0) moved in xxx and deleted)
mario
+1 for the 2 optionsfester2251 wrote: ↑Tue Jan 24, 2023 7:53 pm Oops! One of the cylinders isn't oriented correctly. If you delete the object to get at the components, all the components revert back to where they were before you moved the object. If you open the object to expose the tree, the components are all displayed where they started, just like if you had deleted the object. Now when you move the components inside the object, you're left to guess how that will display on the screen.
mario
- adrianinsaval
Re: Feature Request
consider using Part design instead so when you move the body everything inside it moves with it, otherwise place all the components inside a Part container as you crate them and change the placement of the Part instead of just one element.
Re: Feature Request
Hi
@adrianinsaval
see here:
if compute (realtime) : fusion erased the objects return in original place
if not compute : fusion erased the objects stay in new place
I don't know how to control compute or not compute
I am interested to 2 options
mario
@adrianinsaval
see here:
OS: Windows 10 Version 2009
Version: 0.21.0.31625 (Git)
Hash: 72df7997700062b6a02f2f208e6291f64073fb88
Python 3.10.8, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
- adrianinsaval
Re: Feature Request
In the second gif you still have selected the two components of the fusion not the fusion itself, since they are not visible changing their placement is not immediately visible, once you apply the change the fusion is also updated. It is expected behavior.
The maximum 90deg on y axis is not a bug either, there was a recent discussion about this, limiting this angle was actually solving a bug, see https://forum.freecadweb.org/viewtopic. ... =placement
The confusion here comes from user misunderstanding, if this workflow does not suit your style consider using Part Design or putting everything in a Part container as I mentioned before.
- Shalmeneser
Re: Feature Request
Can you modify the title of the 1st post to have a text more meaningful ?
Re: Feature Request
Hi
the two options are interesting
mario
Ok the placement of the fusion display (0,0,0) and the object (10,0,0) now i understandadrianinsaval wrote: ↑Thu Jan 26, 2023 5:45 pm In the second gif you still have selected the two components of the fusion not the fusion itself,
if this change affect my macros , i think going crazyadrianinsaval wrote: ↑Thu Jan 26, 2023 5:45 pm The maximum 90deg on y axis is not a bug either, there was a recent discussion about this, limiting this angle was actually solving a bug, see https://forum.freecadweb.org/viewtopic. ... =placement
mario
