[solved] Can't install DesignSPHysics via Addon-Manager
Moderator: oliveroxtoby
shIxx
Post by shIxx »
Hello community,
when I try to install DesignSPHysics via the addon manager, the WB is first downloaded (approx. 80mb) then unpacked and then the message "DesignSPHysics was successfully installed from the zip file" appears. But FreeCAD does not prompt me to restart and the following is displayed in the output window:
15:31:26  Addon Developer Warning: Repository URL set in package.xml file for addon Curves workbench (https://github.com/tomate44/CurvesWB) does not match the URL it was fetched from (https://github.com/JMG1/ExplodedAssembly)
15:31:26  Addon Developer Warning: Repository branch set in package.xml file for addon freecad.gears workbench (develop) does not match the branch it was fetched from (master)
15:31:27  Git Python Befehl konnte nicht ausgeführt werden: Prüfe die Installation von GitPython und/oder git
15:31:49  Traceback (most recent call last):
15:31:49    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_workers.py", line 916, in run
15:31:49      self.macro.fill_details_from_wiki(url)
15:31:49    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_macro.py", line 315, in fill_details_from_wiki
15:31:49      self.clean_icon()
15:31:49    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_macro.py", line 341, in clean_icon
15:31:49      with open(constructed_name, "wb") as f:
15:31:49  OSError: [Errno 22] Invalid argument: 'C:\\Users\\thoma\\AppData\\Local\\Temp\\FreeCAD\\Cache\\AddonManager\\MacroIcons\\120px-FCBmpImportScreenshot.png?20210923163201'
15:31:52  Syntax error while reading __files__ from macro AeroFoil
15:31:52  __Files__         = "AeroFoil_UI_Files/AeroFoil_Initial_Dialog.ui, AeroFoil_UI_Files/AeroFoil_NACA4Digit_Dialog.ui, \
15:31:54  Traceback (most recent call last):
15:31:54    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_workers.py", line 916, in run
15:31:54      self.macro.fill_details_from_wiki(url)
15:31:54    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_macro.py", line 315, in fill_details_from_wiki
15:31:54      self.clean_icon()
15:31:54    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_macro.py", line 341, in clean_icon
15:31:54      with open(constructed_name, "wb") as f:
15:31:54  OSError: [Errno 22] Invalid argument: 'C:\\Users\\thoma\\AppData\\Local\\Temp\\FreeCAD\\Cache\\AddonManager\\MacroIcons\\Macro_makeCube.png?20110801163602'
15:31:54  OSError: [Errno 22] Invalid argument: 'C:\\Users\\thoma\\AppData\\Local\\Temp\\FreeCAD\\Cache\\AddonManager\\MacroIcons\\Macro_Site_From_Contours.png?20190704172250'
15:31:56  Traceback (most recent call last):
15:31:56    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_workers.py", line 916, in run
15:31:56      self.macro.fill_details_from_wiki(url)
15:31:56    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_macro.py", line 315, in fill_details_from_wiki
15:31:56      self.clean_icon()
15:31:56    File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\addonmanager_macro.py", line 341, in clean_icon
15:31:56      with open(constructed_name, "wb") as f:
15:31:56  OSError: [Errno 22] Invalid argument: 'C:\\Users\\thoma\\AppData\\Local\\Temp\\FreeCAD\\Cache\\AddonManager\\MacroIcons\\Centericon.png?20210619192700'
After restarting FC, DesignSPHysics is not visible in the WB-dropdown-menu.
I have no idea what's going wrong
OS: Windows 10 Version 2009
Version: 0.20.2.29177 +426 (Git)
Branch: (HEAD detached from 0.20.2)
Hash: 930dd9a76203a3260b1e6256c70c1c3cad8c5cb8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
  * 3D_Printing_Tools
  * boltsfc 2022.11.5
  * CfdOF 1.21.3
  * Curves 0.6.5
  * Defeaturing 1.2.0
  * DesignSPHysics 0.6.3(24-09-2022)
  * EM
  * ExplodedAssembly 0.6.5
  * fasteners 0.4.54
  * FEMbyGEN 1.2.0
  * FEM_FrontISTR 0.1.0
  * freecad.gears 1.0.0
  * IconThemes
  * PieMenu 1.2.4
  * Render 2022.4.0
  * sheetmetal 0.2.60
  * SP_Startup
thschrader
Re: Can't install DesignSPHysics via Addon-Manager
Post by thschrader »
shIxx wrote: Thu Jan 19, 2023 2:50 pm ...
DesignSPhysics is a macro, not a workbench.
See here:
https://github.com/DualSPHysics/DesignSPHysics
chennes
Post by chennes »
Which is also why you are not prompted to restart: you don’t need to.
Chris Hennes
Pioneer Library System
shIxx
Post by shIxx »
thschrader wrote: Thu Jan 19, 2023 4:37 pm DesignSPhysics is a macro, not a workbench.
See here:
Thanks for the quick reply.
DualSPHysics can be found under Workbenches in the Addon Manager. I also read that it is a macro.
But it is strange that it does not appear under the macros either.
There is a folder in ..../Mods but nothing appears in FreeCAD.
thschrader
shIxx wrote: Sun Jan 22, 2023 9:56 am Thanks for the quick reply.
Can you try the manual installation as described here:
Do steps 1+2, after that you should find the designsphysics-macro in the macro-dialog.
Start macro. Attention: macro-start kills your previous session, you must built your geometry inside the
macro (or importing it).
thschrader
zip contains 3 test-cases:
testCases.zip
(283.56 KiB) Downloaded 57 times
shIxx
Post by shIxx »
thschrader wrote: Mon Jan 23, 2023 7:31 am Can you try the manual installation as described here:
As I said in the beginning, the message "DesignSPHysics was successfully installed from the zip file" was shown after installed via addon-manager and DesignSPHysics is in the Mod folder. All I had to do was to copy DesignSPHysics.FcMacro from Mod to Macro folder. And it seems to be working now.
Only the DamBreak case ends in an error, but that's due to the case itself I think as the other two are working:
*** Exception (JSphGpuSingle::LoadDemData) at ..\source\JSph.cpp:1181
Text: Object mk=10 (mkbound=0) - Value of Kfric is invalid.
Finished execution (code=1).
Thanks!
thschrader
shIxx wrote: Mon Jan 23, 2023 11:50 am ...
Oh, sorry.
In "Execution Parameters" change Solid-solid interaction to "SPH".
In model-tree klick on obstacle, "Float state ==> configure" and adjust degrees of freedom.
Now it should work.
The watermill case is based on this tutorial:
https://www.youtube.com/watch?v=AqxzzF9REcw
shIxx
Post by shIxx »
thschrader wrote: Mon Jan 23, 2023 12:29 pm In "Execution Parameters" change Solid-solid interaction to "SPH".
Now it should work.
Thanks,.. everything is working now
