[solved] UI bug in polar-pattern
rynn
Post by rynn »
in the polar-pattern dialog, changing the number of occurences no longer has an effect.
Changing this parameter in the data-tab still works.
QObject::connect: No such signal Gui::UIntSpinBox::valueChanged(uint)
QObject::connect:  (sender name:   'spinOccurrences')
OS: Debian GNU/Linux bookworm/sid (KDE/plasma)
Version: 0.21.0.31598 +2 (Git)
Branch: Meins
Hash: 3cfd922769269814c37a287e8b617fbbbf22a10d
Python 3.10.9, Qt 5.15.7, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * Curves 0.6.5
  * A2plus 0.4.60h
  * Assembly4 0.12.5
  * Pyramids-and-Polyhedrons
  * Render 2022.4.0
  * sheetmetal 0.2.60
  * Silk 1.0.0
  * CurvedShapes 1.0.4
  * DynamicData 2.46.0
  * FreeCAD_assembly3 0.11.3
  * fcgear 1.0.0
  * fasteners.backup1664828890.5062773 0.4.13 (Disabled)
  * fasteners 0.4.53
  * ExplodedAssembly
polar_pattern.FCStd
(21.34 KiB) Downloaded 67 times
Re: UI bug in polar-pattern
Works here as it used to.
OS: macOS 10.16
Version: 0.21.0.31513 (Git)
Hash: b2ab8edba4bfd71681e639f8c3f1105066bed4c7
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: C/Default (C)
Installed mods:
  * FC_SU
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.4.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.16
  * sheetmetal 0.2.60
  * ExplodedAssembly
  * Curves 0.6.5
rynn
Post by rynn »
rebuild freecad and now it works again.
maybe because of https://github.com/FreeCAD/FreeCAD/comm ... b6abeeece9 but not sure.
