Trying to give the radius to an arc, but it's not working because understood like a spline. But an true arc.
Is the radius measurement can be compelled to set a manual radius? or the approximate feature could be improved with an 3 pints calculated arc?
Radius cannot be set to an arc
- Capture.JPG (33.18 KiB) Viewed 563 times
Re: Radius cannot be set to an arc
It indeed visually seems to be a circular arc. What is your FreeCAD version info, and can you post the example file?
