[Solved] "Pan" function limited in movement
domad
Post by domad »
Greetings to the Community!
It looks like in the weekly build:
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.21.0.31513 (Git) AppImage
Hash: b2ab8edba4bfd71681e639f8c3f1105066bed4c7
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Local: Local
the "pan" function of TechDraw is limited in movement, in particular using a large sheet it is impossible to move the page freely, this is very annoying for example when there is a strong zoom, it does not happen with the FC 0.21-31488 version.
Re: "Pan" function limited in movement
Does it depend on the mouse model?
domad
Post by domad »
chrisb wrote: Sun Jan 08, 2023 12:50 pm Does it depend on the mouse model?
Hi chris, hello to the Community!
No, these are the steps to reproduce:
mouse system = Blender; preferences= zoom to cursor;
- create any object in the model view
- create a page in Techdraw
- set up a large size template A0, A1..
- create a view of the object
- move the created view to the upper left corner, to the border or off the sheet
- zoom (mouse wheel) on the view, this phase becomes problematic
- activate the pan (shift+ central button or wheel_button) by moving to the right, trying to frame the upper left part of the sheet to frame the created view, even with the scrolling of the bars I cannot frame the view.
I correct what was previously stated, also the FC 0.21-31488 version suffers from the same problem.
wandererfan
Post by wandererfan »
domad wrote: Sun Jan 08, 2023 1:43 pm
I think I followed the directions up to here:
What happens next?
The scrollable area is only 3x page size - is that the issue?
domad
Post by domad »
wandererfan wrote: Sun Jan 08, 2023 5:24 pm .....
What happens next?
Hello wandererfan, greetings to the Community!
No, that's not the problem (at least I think), unless it's related.
I apologize for the delay in replying, I was away from the computer, then I also had to create an animated gif to be more explicit.
The gif shows what happens, in practice only the lower left corner of the page works, for the other positions it is not possible to zoom where the cursor is and it is not possible to use the Pan, not even the sidebars and in low they manage to frame the view.
domad
Post by domad »
The problems (zoom and pan) also persist in the FC 0.21-31527 version, in particular they occur with formats greater than A3, while with smaller formats they seem to work.
aapo
Post by aapo »
domad wrote: Wed Jan 11, 2023 8:57 am ... in particular they occur with formats greater than A3, while with smaller formats they seem to work.
Hmm, that is peculiar, indeed. I wonder how the size of the paper could affect this..? Maybe there are some hard coded constants in the code.
wandererfan
I think if you change your zoom, you'll be able to frame the interesting area. In any case, I'm going to change the outer limits of the scrollable area from 3x to 5x the page size.
domad
Post by domad »
wandererfan wrote: Wed Jan 11, 2023 2:21 pm I think if you change your zoom, you'll be able to frame the interesting area. In any case, I'm going to change the outer limits of the scrollable area from 3x to 5x the page size.
Changing the zoom does not solve the problem.
I insist on the fact that it could not be the limits of the scrollable area, it could instead be linked to the synchronization/alignment between the background (white box that represents the card), the scrollable area and the TechDraw page center, because the only corner, or area, that does not suffer from the problem is the one on the lower left.
wandererfan
domad wrote: Thu Jan 12, 2023 12:18 pm
Can you detect what am I doing differently?
