Having the same issue. I have 0.18 Installed and it WAS working but it seems to hang after the splash screen and then just hangs (+10 min...). 0.20.2 what I was trying to update to. I have tried on 2 computers- the other one is running Win7. On both machines 0.20.2 displays the splash screen and then terminates- I have watched it the process manager and it does terminate on both machines. Install files were downloaded separately (I just mean that I am not using the actual same file)
Attached is the log file (I think?)
Jim
FreeCAD closes on startup
Re: FreeCAD closes on startup
- FreeCAD.log
- (51.34 KiB) Downloaded 25 times
In your case the OpenGL version is the problem:
Log: Init: App::FreeCADInit.py done
Log: Init: Creating Gui::Application and QApplication
Log: Local server 'FreeCAD' started
Log: This system does not support framebuffer objects
Log: This system does not support NPOT textures
Log: OpenGL version is: 1.1 (1.1.0)
Ok thank you for the reply. I will fix that.
Jim
Jim
I'm in Thank you very much. I was able to update/upgrade to OpenGL3.3
Sincerely appreciate it!
Jim
Jim
Got it running.
I had to:
1) delete all previous versions of FreeCad before installing 0.20.2
2) check the "delete preferences and settings" option when uninstalling previous versions.
So far, so good.
I had to:
So far, so good.
I removed the file and the software finally booted, but unfortunately, I was only able to access the app, but cannot do anything. Here's a screenshot of it.wmayer wrote: ↑Fri Dec 30, 2022 9:21 amFor some reason the QtWebEngine module doesn't work correctly. It's hard to say why this happens.I'm getting a bunch of errors like this:
A workaround is to remove the folder StartPage from the Mod directory. If this still doesn't work then also remove the AddonManager directory.
- Screenshot 2023-01-28 184010.png (112.53 KiB) Viewed 646 times
