Outlet Boundary condition (extrapolated type) bug
Moderator: oliveroxtoby
M4mina
Post by M4mina »
When I tried to define an exit as outlet extrapolated i received an error that the word uniform or nonuniform is missing from the case/0/U dictionary
I had to add the word uniform myself to make it work in line 32 I added "// I added Uniform here!!!!! [Mina]" to find it easily
/*--------------------------------*- C++ -*----------------------------------*\
|                Generated by the CfdOF workbench for FreeCAD                 |
|                  https://gitlab.com/opensimproject/CfdOF                    |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.0 0.0 0.0);
boundaryField
    inlet
        // Fix all three components of velocity on inflow and only the normal component on outflow,
        // in order to be well-posed if there are some faces on the patch which are actually outflows.
        type                fixedNormalInletOutletVelocity;
        fixTangentialInflow yes;
        normalVelocity
            type            fixedValue;
            value           uniform ( 0.0 0.4255 0.0 );
    open
        type        inletOutlet;
        inletValue uniform (0 0 0); // I added Uniform here!!!!! [Mina]
        //TODO: We need to write an out-flowing value here so that adjustPhi can have an adjustable flux to work
        //TODO: with at iteration 1
        value       $internalField;
    open001
        type        pressureInletOutletVelocity;
    defaultFaces
        type        slip;
oliveroxtoby
Re: Outlet Boundary condition (extrapolated type) bug
Post by oliveroxtoby »
M4mina wrote: Fri Nov 11, 2022 12:04 am When I tried to define an exit as outlet extrapolated i received an error that the word uniform or nonuniform is missing from the case/0/U dictionary
Thanks. Fixed.
M4mina
Post by M4mina »
Thank you :)
