Stored Draft color integer is different from the default?
Roy_043
Post by Roy_043 »
While working on the Draft_AnnotationStyleEditor code I notice that Draft stores a different color integer from the default. Is this a deliberate choice?
Example:
RGB = (11, 12, 13)
Draft format:
1095401999616
Hex:
??RRGGBBAA
ff0b0c0d00
Default format:
185339391
Hex:
??RRGGBBAA
000b0c0dff
yorik
Founder
Re: Stored Draft color integer is different from the default?
Post by yorik »
I don't understand exactly what you mean... the size of the integer you mean? AFAICR it varies, for ex. 255 is a valid color integer.
In any case I think it's meant to be saved in the same format as in the FreeCAD parameters, if it's different it's probably a mistake.
Roy_043
Post by Roy_043 »
The color integers contain four relevant bytes. Qt stores the Alpha value in the highest of those bytes (ARGB), whereas FreeCAD stores the Alpha value in the lowest byte (RGBA):
With the given RGB list (11, 12, 13) Qt returns this int:
ff0b0c0d
And FreeCAD would stored the value as:
0b0c0dff
In the Draft code the Qt int is simply shifted 8 bits to the left which results in:
ff0b0c0d00
This means that the RGB bytes are in the correct position, but the int has a different value from what is used in other parts of FreeCAD.
2 functions to convert from ARGB to RGBA and vice versa:
def argb_to_rgba(color):
    """Change byte order of a 4 byte color int from ARGB (Qt) to RGBA."""
    return ((color & 0xFFFFFF) << 8) + (color >> 24)
def rgba_to_argb(color):
    """Change byte order of a 4 byte color int from RGBA to ARGB (Qt)."""
    return (color >> 8) + ((color & 0xFF) << 24)
yorik
Founder
Post by yorik »
Roy_043 wrote: Wed Nov 16, 2022 2:31 pm Qt stores the Alpha value in the highest of those bytes (ARGB), whereas FreeCAD stores the Alpha value in the lowest byte (RGBA)
Hmm indeed it's possible that I forgot that bit...
