Annotation styles do not apply some settings
zecoj
Post by zecoj »
Hi, hoping to check if this is happening to me only...
When apply the saved Annotation Style, some settings are not correctly applied. I have tried creating new style, deleting, renaming but does not seem to affect.
- Dimension Overshoot
- Extension Lines
- Extension Overshoot
Re: Annotation styles do not apply some settings
Hi and welcome to the forum!
For such GUI posts it is always sensible to attach your full FreeCAD info as described in the IMPORTANT forum rules linked above.
Roy_043
Post by Roy_043 »
Confirmed. It is a long-standing bug. There are (at least) two issues with the code AFAICT. Some properties are simply misspelled (e.g. "DimensionOvershoot" in the code should be "DimOvershoot") and the color value is not stored in the correct format.
I'll see if I can fix this.
Version: 0.21.30858 (Git)
Hash: 7a5019b2625a148acb23fb915df48ffa69636fe9
Python 3.8.13, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
Roy_043
Post by Roy_043 »
@zecoj Another issue I encounter:
  1. Open the Draft_AnnotationStyleEditor.
  2. Select an existing style.
  3. Change the Font name.
  4. Press OK.
  5. Reopen the Draft_AnnotationStyleEditor.
  6. Result: the selected Font Name has not been saved.
Do you experience the same?
Roy_043
Post by Roy_043 »
