I'm working on this (it's an issue on some Linux flavors right now even with Qt5) -- I used a one shot timer to kill the dialogs and set the time too short. I'm going to refactor to use a more flexible approach.
Compilation testers needed
Re: Compilation testers needed
That's correct but there is a little difference compared to Qt6. While with Qt5 the unit tests can continue and let the user close the dialogs manually this isn't possible any more with Qt6. The application kind of freezes and when clicking on the X symbol the window manager jumps in after a few seconds asking the user to kill the application.I'm working on this (it's an issue on some Linux flavors right now even with Qt5)
In case it is of help for you: The PartDesign tests also open some modal dialogs that are closed automatically. You will find the relevant code here: https://github.com/FreeCAD/FreeCAD/blob ... Gui.py#L38
Thanks -- I was using a 10ms timer, and I see there we've got a 500ms! In an effort to keep each unit test less than 100ms my new plan is to use a normal (non-oneshot) timer that just checks for the dialog every 10ms for up to a second. My thinking is that will fix both the Qt5 and the Qt6 issue. Though if the tests actually fail and the expected dialog never appears I don't know how to recover in Qt6 then.
git commit 2f3baa033 changes the Addon Manager GUI test dialog closer to use a repeating timer that runs for up to a second. Can you let me know if this fixes the issue you are seeing with Qt6?
Sorry, but this doesn't fix it. Actually there are three cascaded dialogs and the top two are not even correctly painted (same as before your change). Here is a screentshot of how it looks:chennes wrote: ↑Mon Jan 02, 2023 9:41 pm git commit 2f3baa033 changes the Addon Manager GUI test dialog closer to use a repeating timer that runs for up to a second. Can you let me know if this fixes the issue you are seeing with Qt6?
Thanks! With your latest changes it works much better now. The tests now all complete and no longer block the application. However, they still don't disappear automatically and the user has to still manually click on the X icon. At least, this won't kill the application any more.
But there is now a regression with Qt5. It shows the problems that the Qt6 build had. In the console I get these warnings:
Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt.
You must not let any exception whatsoever propagate through Qt code.
If that is not possible, in Qt 5 you must at least reimplement
QCoreApplication::notify() and catch all exceptions there.
I'm testing on Windows, Ubuntu 20.04 LTS, and Ubuntu latest, and am not getting that error with Qt5 . I will build Qt6 on one of the Linux systems and see if I can replicate it then.
Do you have enabled the respective warning category?wmayer wrote: ↑Mon Jan 02, 2023 10:05 am
ToDo:
Unfortunately there are still a lot of old-style connects in the code base that won't work any more with Qt6 because signal or slot functions have been renamed or removed. For some reason Qt6 doesn't seem to print any warnings any more if the call of connect() has failed.
https://codebrowser.dev/qt6/qtbase/src/ ... lcConnectv
export QT_LOGGING_RULES=qt.core.qobject.connect.debug=true
export QT_LOGGING_RULES=qt.*.debug=true
@chennes If it may help, below the callstack of the main thread when this message appears :wmayer wrote: ↑Wed Jan 04, 2023 10:10 amCode: Select all
Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must not let any exception whatsoever propagate through Qt code. If that is not possible, in Qt 5 you must at least reimplement QCoreApplication::notify() and catch all exceptions there.
#0 __futex_abstimed_wait_common64() at nptl/nptl/futex-internal.c:57
#1 __futex_abstimed_wait_common() at nptl/nptl/futex-internal.c:87
#2 __GI___futex_abstimed_wait_cancelable64() at nptl/nptl/futex-internal.c:139
#3 __pthread_cond_wait_common() at nptl/nptl/pthread_cond_wait.c:503
#4 ___pthread_cond_wait() at nptl/nptl/pthread_cond_wait.c:627
#5 QWaitConditionPrivate::wait() at src/corelib/thread/qwaitcondition_unix.cpp:146
#6 QWaitCondition::wait() at src/corelib/thread/qwaitcondition_unix.cpp:225
#7 QThread::wait() at src/corelib/thread/qmutex.h:270
#8 ??() at /usr/lib/python3/dist-packages/PySide2/QtCore.cpython-310-x86_64-linux-gnu.so
#9 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#10 _PyObject_MakeTpCall() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#11 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#12 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#13 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#14 PySide::SignalManager::callPythonMetaMethod(QMetaMethod const&, void**, _object*, bool)() at /lib/x86_64-linux-gnu/libpyside2.cpython-310-x86_64-linux-gnu.so.5.15
#15 PySide::SignalManager::qt_metacall(QObject*, QMetaObject::Call, int, void**)() at /lib/x86_64-linux-gnu/libpyside2.cpython-310-x86_64-linux-gnu.so.5.15
#16 doActivate<false>() at src/corelib/kernel/qobject.cpp:3 912
#17 QMetaObject::activate() at src/corelib/kernel/qobject.cpp:3 946
#18 QDialog::rejected() at src/widgets/.moc/moc_qdialog.cpp:242
#19 QDialogPrivate::finalize() at src/widgets/dialogs/qdialog.cpp:178
#20 doActivate<false>() at src/corelib/kernel/qobject.cpp:3 898
#21 QMetaObject::activate() at src/corelib/kernel/qobject.cpp:3 946
#22 QDialogButtonBox::rejected() at src/widgets/.moc/moc_qdialogbuttonbox.cpp:299
#23 QDialogButtonBoxPrivate::_q_handleButtonClicked() at src/widgets/widgets/qdialogbuttonbox.cpp:882
#24 doActivate<false>() at src/corelib/kernel/qobject.cpp:3 898
#25 QMetaObject::activate() at src/corelib/kernel/qobject.cpp:3 946
#26 QAbstractButton::clicked() at src/widgets/.moc/moc_qabstractbutton.cpp:308
#27 QAbstractButtonPrivate::emitClicked() at src/widgets/widgets/qabstractbutton.cpp:415
#28 QAbstractButton::click() at src/widgets/widgets/qabstractbutton.cpp:904
#29 QAbstractButton::click() at src/widgets/widgets/qabstractbutton.cpp:890
#30 QAbstractButton::qt_metacall() at src/widgets/.moc/moc_qabstractbutton.cpp:265
#31 QPushButton::qt_metacall() at src/widgets/.moc/moc_qpushbutton.cpp:141
#32 doActivate<false>() at src/corelib/kernel/qobject.cpp:3 912
#33 QMetaObject::activate() at src/corelib/kernel/qobject.cpp:3 946
#34 QTimer::timeout() at src/corelib/.moc/moc_qtimer.cpp:205
#35 ??() at /usr/lib/python3/dist-packages/PySide2/QtCore.cpython-310-x86_64-linux-gnu.so
#36 QObject::event() at src/corelib/kernel/qobject.cpp:1 336
#37 ??() at /usr/lib/python3/dist-packages/PySide2/QtCore.cpython-310-x86_64-linux-gnu.so
#38 QApplicationPrivate::notify_helper() at src/widgets/kernel/qapplication.cpp:3 637
#39 Gui::GUIApplication::notify() at /home/ob/dev/FreeCAD/src/Gui/GuiApplication.cpp:85
#40 QCoreApplication::notifyInternal2() at src/corelib/kernel/qcoreapplication.cpp:1 064
#41 QTimerInfoList::activateTimers() at src/corelib/kernel/qtimerinfo_unix.cpp:643
#42 timerSourceDispatch() at src/corelib/kernel/qeventdispatcher_glib.cpp:183
#43 g_main_context_dispatch() at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#44 ??() at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#45 g_main_context_iteration() at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#46 QEventDispatcherGlib::processEvents() at src/corelib/kernel/qeventdispatcher_glib.cpp:423
#47 QCoreApplication::processEvents() at src/corelib/global/qflags.h:69
#48 ??() at /usr/lib/python3/dist-packages/PySide2/QtCore.cpython-310-x86_64-linux-gnu.so
#49 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#50 _PyObject_MakeTpCall() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#51 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#52 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#53 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#54 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#55 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#56 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#57 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#58 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#59 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#60 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#61 _PyObject_FastCallDictTstate() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#62 _PyObject_Call_Prepend() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#63 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#64 _PyObject_MakeTpCall() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#65 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#66 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#67 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#68 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#69 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#70 _PyObject_FastCallDictTstate() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#71 _PyObject_Call_Prepend() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#72 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#73 _PyObject_MakeTpCall() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#74 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#75 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#76 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#77 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#78 _PyEval_EvalFrameDefault() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#79 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#80 PyEval_EvalCode() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#81 ??() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#82 PyRun_StringFlags() at /lib/x86_64-linux-gnu/libpython3.10.so.1.0
#83 Base::InterpreterSingleton::runString[abi:cxx11](char const*)() at /home/ob/dev/FreeCAD/src/Base/Interpreter.cpp:240
#84 TestGui::UnitTestDialog::on_startButton_clicked() at /home/ob/dev/FreeCAD/src/Mod/Test/Gui/UnitTestImp.cpp:178
#85 TestGui::UnitTestDialog::qt_static_metacall() at /home/ob/dev/FCBuild/src/Mod/Test/Gui/QtUnitGui_autogen/include/moc_UnitTestImp.cpp:91
#86 TestGui::UnitTestDialog::qt_metacall() at /home/ob/dev/FCBuild/src/Mod/Test/Gui/QtUnitGui_autogen/include/moc_UnitTestImp.cpp:127
#87 doActivate<false>() at src/corelib/kernel/qobject.cpp:3 912
#88 QMetaObject::activate() at src/corelib/kernel/qobject.cpp:3 946
#89 QAbstractButton::clicked() at src/widgets/.moc/moc_qabstractbutton.cpp:308
#90 QAbstractButtonPrivate::emitClicked() at src/widgets/widgets/qabstractbutton.cpp:415
#91 QAbstractButtonPrivate::click() at src/widgets/widgets/qabstractbutton.cpp:408
#92 QAbstractButton::mouseReleaseEvent() at src/widgets/widgets/qabstractbutton.cpp:1 044
#93 QWidget::event() at src/widgets/kernel/qwidget.cpp:9 033
#94 QApplicationPrivate::notify_helper() at src/widgets/kernel/qapplication.cpp:3 637
#95 QApplication::notify() at src/widgets/kernel/qapplication.cpp:3 081
#96 Gui::GUIApplication::notify() at /home/ob/dev/FreeCAD/src/Gui/GuiApplication.cpp:85
#97 QCoreApplication::notifyInternal2() at src/corelib/kernel/qcoreapplication.cpp:1 064
#98 QApplicationPrivate::sendMouseEvent() at src/widgets/kernel/qapplication.cpp:2 619
#99 QWidgetWindow::handleMouseEvent() at src/widgets/kernel/qwidgetwindow.cpp:683
#100 QWidgetWindow::event() at src/widgets/kernel/qwidgetwindow.cpp:300
#101 QApplicationPrivate::notify_helper() at src/widgets/kernel/qapplication.cpp:3 637
#102 Gui::GUIApplication::notify() at /home/ob/dev/FreeCAD/src/Gui/GuiApplication.cpp:85
#103 QCoreApplication::notifyInternal2() at src/corelib/kernel/qcoreapplication.cpp:1 064
#104 QGuiApplicationPrivate::processMouseEvent() at src/gui/kernel/qguiapplication.cpp:2 282
#105 QWindowSystemInterface::sendWindowSystemEvents() at src/gui/kernel/qwindowsysteminterface.cpp:1 169
#106 xcbSourceDispatch() at src/plugins/platforms/xcb/src/plugins/platforms/xcb/qxcbeventdispatcher.cpp:105
#107 g_main_context_dispatch() at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#108 ??() at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#109 g_main_context_iteration() at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#110 QEventDispatcherGlib::processEvents() at src/corelib/kernel/qeventdispatcher_glib.cpp:423
#111 QEventLoop::exec() at src/corelib/global/qflags.h:69
#112 QCoreApplication::exec() at src/corelib/global/qflags.h:121
#113 Gui::Application::runApplication() at /home/ob/dev/FreeCAD/src/Gui/Application.cpp:2 265
#114 main() at /home/ob/dev/FreeCAD/src/Main/MainGui.cpp:270
IIRC, this is mechanism used somewhere in your Gui tests. Maybe there are several dialogs open and at some moment the wrong one is targeted.
No, I didn't know that an environment variable has to be set now. I will try it. Thanks!
