Does a variant of that path exist for Qt6UiTools6, or something along those lines? It's interesting to me that the package ends with a 6, does Debian do that will all the Qt stuff? Also, I assume you are using the standard Debian package for Qt6?jjubenv wrote: ↑Sun Oct 30, 2022 7:33 pm I get this with the QT6 build:Code: Select all
Expected Config file at "/usr/lib/x86_64-linux-gnu/cmake/Qt6UiTools/Qt6UiToolsConfig.cmake" does NOT exist
Compilation testers needed
Re: Compilation testers needed
(I provide too much detail here, in case someone else want's to try).
Since Debian bullseye(v11.5) does not have a standard package for QT6, I used their bullseye-backports repo by adding it to my apt configuration. Here is the list of 'Qt6' packages in the backports repository: https://packages.debian.org/search?suit ... ywords=qt6
I did some more digging, and found I should have installed packages that end with '-dev' (instead of simply libqt6uitools6), that library is installed with the 'qt6-tools-dev' package. cmake then progressed a bit and I had to install the 'qt6-webengine-dev' package, and pip install pyside6 (which also installs shiboken6).
I think this is all I needed to install (I may have forgotten some though)
sudo apt -t bullseye-backports install qt6-base-dev
sudo apt -t bullseye-backports install qt6-base-dev-tools
sudo apt -t bullseye-backports install libqt6svg6-dev
sudo apt -t bullseye-backports install qt6-tools-dev
sudo apt -t bullseye-backports install qt6-webengine-dev
pip install pyside6
cmake -DFREECAD_QT_VERSION=6 ../freecad-pr7647-src
Summary report
-- Build type:
-- Compiler: /usr/bin/c++ (10.2.1)
-- Flags: -Wall -Wextra -Wno-write-strings
-- Standard: Requires C++17
-- Python: 3.9.2 [/usr/bin/python3.9] []
-- PCL: not enabled
-- pybind11: not enabled
-- Boost: 1.74.0
-- XercesC: 3.2.3 [/usr/lib/x86_64-linux-gnu/libxerces-c.so] [/usr/include]
-- ZLIB: 1.2.11
-- PyCXX: 7.1.7 [/home/jake/development/freecad/freecad-pr7647-src/src]
-- OCC: 7.5.1 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBool;TKBO;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEPBase;TKSTEPAttr;TKSTEP209;TKSTEP;TKHLR;TKFeat] [/usr/lib/x86_64-linux-gnu] [/usr/include/opencascade]
-- SMESH: 7.7.1.0 build internal
-- MEDFile: 4.1.0 [/usr/lib/x86_64-linux-gnu/libmedC.so] [/usr/include]
-- HDF5: 1.10.6
-- VTK: 7.1.1
-- NETGEN: not enabled
-- SWIG: 4.0.2
-- Eigen3 3.3.9
-- QtCore: 6.3.1
-- QtNetwork: 6.3.1
-- QtXml: 6.3.1
-- QtWidgets: 6.3.1
-- QtPrintSupport: 6.3.1
-- QtOpenGL: 6.3.1
-- QtSvg: 6.3.1
-- QtUiTools: 6.3.1
-- QtConcurrent: 6.3.1
-- QtWebEngineWidgets: 6.3.1
-- Designer plugin: not built (BUILD_DESIGNER_PLUGIN is OFF)
-- Shiboken: 6.4.0.1 [Shiboken6_DIR-NOTFOUND] [\ /home/jake/.local/lib/python3.9/site-packages/shiboken6/include]
-- PySide: 6.4.0.1 [\ /home/jake/.local/lib/python3.9/site-packages/PySide6/include]
-- PySideTools: [/usr/lib/qt6/libexec/uic] [/usr/lib/qt6/libexec/rcc]
-- Freetype: 2.10.4
-- OpenGL: /usr/lib/x86_64-linux-gnu/libGL.so
-- OpenGLU: [/usr/lib/x86_64-linux-gnu/libGLU.so][/usr/include]
-- Coin3D: 4.0.0 [/usr/lib/x86_64-linux-gnu/libCoin.so] [/usr/include]
-- Pivy: 0.6.5
-- SPNAV: [/usr/lib/libspnav.so] [/usr/include]
-- Matplotlib: 3.3.4
-- Rift: not enabled (BUILD_VR)
-- Doxygen: 1.9.1
-- Language: English
-- Coin3D_DOC: not found
Now run 'cmake --build /home/jake/development/freecad/freecad-pr7647-src' to build FreeCAD
Fedora repos are missing qt6-qtwebengine-devel, so i'm unable to test cmake with QT6.
You can turn BUILD_WEB off and it should remove that dependency, so you can at least test that much (if you want to).
Thanks for taking the time to poke that this -- I'm sure others will find this info useful in the coming months as we work to get FreeCAD to actually compile against the Qt6 libraries!jjubenv wrote: ↑Sun Oct 30, 2022 9:50 pm I did some more digging, and found I should have installed packages that end with '-dev' (instead of simply libqt6uitools6), that library is installed with the 'qt6-tools-dev' package. cmake then progressed a bit and I had to install the 'qt6-webengine-dev' package, and pip install pyside6 (which also installs shiboken6).
I have tested the Qt6 build on a newly setup Debian Bullseye and was able to build FreeCADBase, FreeCADApp and the App and Gui libraries of most of the modules.
What still must be ported are: FreeCADGui, TechDraw, TechDrawGui and WebGui.
BTW: I wonder about the availability of shiboken6 and PySide6. Do there exist any packages for them? I haven't found anything so far.
Only a few operating systems seem to be packaging these - Qt themselves encourage installing using pip (which of course makes life difficult in the cMake file, but we've got some workarounds in there).
This git commit af0a014cf2 ports some long hanging fruits to Qt6.
Similar issue:Haavard wrote: ↑Sun Oct 30, 2022 9:44 am I get the following error:Code: Select all
CMake Error at /usr/lib64/cmake/Qt5/Qt5Config.cmake:28 (find_package): .....
CMake Error at /usr/lib/aarch64-linux-gnu/cmake/Qt5/Qt5Config.cmake:28 (find_package):
Could not find a package configuration file provided by
"Qt5WebEngineWidgets" with any of the following names:
Qt5WebEngineWidgetsConfig.cmake
qt5webenginewidgets-config.cmake
Add the installation prefix of "Qt5WebEngineWidgets" to CMAKE_PREFIX_PATH
or set "Qt5WebEngineWidgets_DIR" to a directory containing one of the above
files. If "Qt5WebEngineWidgets" provides a separate development package or
SDK, be sure it has been installed.
cMake/FreeCAD_Helpers/SetupQt.cmake:21 (find_package)
CMakeLists.txt:69 (include)
I wasn't able to find the missing package for Qt5, so:
That did the trick.
Then cmake and compiling was ok:
OS: Debian GNU/Linux 11 (bullseye) (LXDE/LXDE-pi)
Version: 0.21.30767 +2 (Git)
Build type: Unknown
Branch: pr/7647
Hash: c472df9cb01ec16596773e30dfbb7e3a1aaa765f
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
Locale: French/France (fr_FR)
However FC starts with no icons and no start page:
Is it the result expected? Or I did something wrong? (I'm not an expert about compiling stuffs)
@-alex- I presume you are getting that error when trying to compile against Qt5, not Qt6, right? If that is the case, you need to install the "qt5webengine-dev" package (or its equivalent in your OS of choice) using your system package manager.
