Hi FreeCAD Forum:
I have downloaded a foot model in stl format and imported it into FreeCAD.
First of all, I converted it from stl into solid.
I'm wondering how I could get a simple insole contour according to the foot scan.
What I can do now is just Boolean operation with cut, see attached image.
Looking forward to hearing from you.
Best Regards,
Mea08kw
Insole design from 3D foot scanner
- 1.png (95.36 KiB) Viewed 1557 times
Re: Insole design from 3D foot scanner
This topic can be helpful: https://forum.freecadweb.org/viewtopic.php?f=3&t=20525
Thanks dude, I will look into it.NewJoker wrote: ↑Mon Oct 24, 2022 12:42 pm This topic can be helpful: https://forum.freecadweb.org/viewtopic.php?f=3&t=20525
Hi Guys
I attached a journal or conference paper regarding to insole design via Rhinoros with a customized plug-in.
Sections 2.2.1 to 2.2.6 introduce the entire insole design process step by step.
From my understanding, the creation of section curves and insole surface are the most important keys to achieve what I want.
I'm not sure how to create section curves from a solid and create a surface from the lower part of section curves.
I appreciate any solutions coming up.
Many thanks.
Mea08kw
Many thanks.
Mea08kw
- CAD_12(6)_2015_700-709.pdf
- (871.71 KiB) Downloaded 89 times
You should x-post to the curves wb thread https://forum.freecadweb.org/viewtopic.php?f=3&t=22675
Will do, thanks for reminding me.Kunda1 wrote: ↑Tue Oct 25, 2022 7:05 am You should x-post to the curves wb thread https://forum.freecadweb.org/viewtopic.php?f=3&t=22675
