Integration of BlenderBIM Features : FreeCAD Arch/BIM - Native IFC
yorik
Founder
Re: Integration of BlenderBIM Feaures : FreeCAD Arch/BIM
Post by yorik »
Yes the process of revealing children is tedious. The idea is to do like BlenderBIM does, offer different import strategies (one object only, structure only, structure + children...)
When does your error above occur? When expanding the site?
paullee
Post by paullee »
yorik wrote: Mon Nov 07, 2022 9:39 am When does your error above occur? When expanding the site?
Yes, crashed expanding the site.
paullee
Post by paullee »
Just updated the add-on, importing return error -
09:05:49  Traceback (most recent call last):
  File "/home/paullee/Downloads/FreeCAD_weekly-builds-30345-2022-09-11-conda-Linux-x86_64-py310/squashfs-root/usr/lib/python3.10/site-packages/shiboken2/files.dir/shibokensupport/feature.py", line 139, in _import
<class 'ModuleNotFoundError'>: No module named 'bb_import'
Screenshot from 2022-11-26 09-07-36.png (222.47 KiB) Viewed 1729 times
yorik
Founder
Post by yorik »
I don't understand how you got this error... there is no more reference to bb_import anywhere. Make sure your addon is up to date? And what steps have you followed to get this error?
paullee
Post by paullee »
Hmmm strange, maybe I had not restarted FC before I tested ?
Seems nothing wrong now ? :roll:
Screenshot from 2022-11-29 00-37-41.png (238.27 KiB) Viewed 1598 times
ragohix769
Post by ragohix769 »
paullee wrote: Mon Nov 28, 2022 4:47 pm Hmmm strange, maybe I had not restarted FC before I tested ?
How is done colors?
Are you using a different model?
Anyway i've import too (the original one), in 11 sec. :-)
That's good :-)
After #ElonMuskBuyTwitter I'm no more on Twitter, that's really enough :-(
=> Now you can find me here on #Mastodon: https://mastodon.uno/@opensoul - I hope more people do the same :-)
paullee
Post by paullee »
Ar, not aware of the colour - same model file !
And now dialog box pop up providing 2 option of IFC import to be selected.
paullee
Post by paullee »
Reveal Children return some error, but seems still working ? :)
02:42:10  Loading GUI of Part module... done
02:42:10  Imported 47.0 Mb in 01:03
02:42:10  Traceback (most recent call last):
  File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_import.py", line 56, in insert
    FreeCADGui.activateWorkbench("BIMWorkbench")
<class 'KeyError'>: No such workbench 'BIMWorkbench'
02:44:18  Traceback (most recent call last):
02:44:18    File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_viewproviders/ifc_vp_object.py", line 89, in revealChildren
02:44:18      ifc_tools.create_children(self.Object, ifcfile)
02:44:18    File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_tools.py", line 92, in create_children
02:44:18      create_child(obj, child)
02:44:18    File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_tools.py", line 75, in create_child
02:44:18      child = create_object(element, parent.Document, ifcfile)
02:44:18    File "/home/paullee/.local/share/FreeCAD/Mod/FreeCAD-BlenderBIM/./ifc_tools.py", line 155, in create_object
02:44:18      shape, colors = get_shape([ifcentity], ifcfile)
02:44:18  TypeError: cannot unpack non-iterable NoneType object
Screenshot from 2022-11-29 02-49-15.png (333.31 KiB) Viewed 1542 times
paullee
Post by paullee »
The Site object has no Reveal Children :roll:
Screenshot from 2022-11-29 03-13-54.png (187.63 KiB) Viewed 1528 times
ragohix769
chennes wrote: Sun Oct 23, 2022 1:16 am
ragohix769 wrote: Sat Oct 22, 2022 11:07 pm It's failing on automatic installing IfcOpenShell
Is there an error message in the FreeCAD console?
I'm trying latest FC snapd package with the --edge version (0.21) (because PPA Daily repos are no more updated :-( ) so I had to reinstall all from scretch. So I installed NativeIFC via addon manager in FC adding gitlab respos manually, but it's failing automatic install of ifcopenshell via pip, and now even if try to install via console as done in the past, the importer it's not working.
Log of the console:
01:36:53  IfcOpenShell was not found on this system. IFC support is disabled.
Visit https://wiki.freecadweb.org/IfcOpenShell to learn about installing it.
01:38:12  Custom repo list changed, forcing recache...
01:38:14  [
        "3",
        "8"
01:38:14  [
        "3",
        "8"
01:38:14  [
        "3",
        "8"
01:38:14  Command '['/snap/freecad/464/bin/python3', '-m', 'pip', '--disable-pip-version-check', 'list', '--path', '/home/dando/snap/freecad/common/AdditionalPythonPackages/py38']' returned non-zero exit status 1.
01:38:14  pip timed out
01:38:30  IfcOpenShell was not found on this system. IFC support is disabled.
01:44:53  IfcOpenShell was not found on this system. IFC support is disabled.
Especially I don't understand this at the end of the FC console if I try to open "Schependomlaan.ifc" demo file (47 MB):
In my system ifcopenshell is already installed:
:~$ pip install ifcopenshell
Requirement already satisfied: ifcopenshell in ./.local/lib/python3.8/site-packages (0.7.0)
OS: Ubuntu Core 20 (KDE/plasma)
Version: 0.21.31153 (Git) Snap 464
Hash: 3f118b52bc62db6a5ca85daafaa2c021411e7177
Python 3.8.10, Qt 5.15.5, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Locale: Italian/Italy (it_IT)
Installed mods:
  * BIM 2021.12.0
  * FreeCAD-NativeIFC 2022.10.20
