Is "Basic Part Design Tutorial" in line with actual Part Design workflow?
onekk
Re: Is "Basic Part Design Tutorial" in line with actual Part Design workflow?
Post by onekk »
edwilliams16 wrote: Tue Oct 11, 2022 5:56 pm ...
My proposed modeling flow may not be much more stable than the wiki version, but it has the virtue of being consistent (I believe) with the recommendations of forum experts like @Shalmeneser. It must be confusing to newcomers to be told that the wiki workflow is not recommended.
This is also my concern, probably your workflow seems more safe than the external reference to solid, so probably it is better in that sense and "more robust".
Regards
Carlo D.
- Various other stuffs.
edwilliams16
Post by edwilliams16 »
@onekk I tidied up your script a little.
I'm not sure the dimensional constraints in makesk_1 can't be included in conList. They seem to have to be added after. A bug?
"""Script to replicate Part Design Tutorial Example.
https://wiki.freecadweb.org/Basic_Part_Design_Tutorial
This code was written as an sample code
Author: Carlo Dormeletti
Copyright: 2022
Licence: CC BY-NC-ND 4.0
import os
import FreeCAD  # noqa
import FreeCADGui  # noqa
import Sketcher
import Part
from FreeCAD import Placement, Rotation, Vector  # noqa
def activate_doc(doc_name):
    """Activate a specific document."""
    FreeCAD.setActiveDocument(doc_name)
    FreeCAD.ActiveDocument = FreeCAD.getDocument(doc_name)
    FreeCADGui.ActiveDocument = FreeCADGui.getDocument(doc_name)
    print(f"Document: {doc_name} activated")
def clear_doc(doc_name):
    """Clear the document deleting all the objects."""
    doc = FreeCAD.getDocument(doc_name)
    for obj in doc.Objects:
        try:
            doc.removeObject(obj.Name)
        except Exception:
            pass
def setview(doc):
    """Rearrange View."""
    try:
        doc_v = FreeCAD.Gui.activeView()
        FreeCAD.Gui.SendMsgToActiveView("ViewFit")
        doc_v.viewAxometric()
    except Exception:
        pass
def check_exist(doc_name):
    """Check the existence of a FC document named doc_name.
    If it not exist create one.
    try:
    except NameError:
        doc = FreeCAD.newDocument(doc_name)
    return doc
# CODE start here
# Some handy abbreviations
VEC0 = Vector(0, 0, 0)
ROT0 = Rotation(0, 0, 0)
# Create an appropriate place for the final file.
home_dir = os.path.expanduser('~')
dirpath = os.path.join(home_dir, 'pd_tut')
if os.path.exists(dirpath):
    pass
else:
    # create path
    os.mkdir(dirpath)
# Some methods to ease the work
def createPDBody(doc, bodyname, lcs=False):
    """Create new Part Design Body."""
    newBody = doc.addObject("PartDesign::Body", bodyname)
    if lcs is True:
        # add an LCS at the root of the Part, and attach it to the 'Origin'
        lcs0 = newBody.newObject('PartDesign::CoordinateSystem', 'LCS_0')
        lcs0.Support = [(newBody.Origin.OriginFeatures[0], '')]
        lcs0.MapMode = 'ObjectXY'
        lcs0.MapReversed = False
    newBody.recompute()
    doc.recompute()
    return newBody
def make_base_sketch(doc, bd_name, sk_name, l1, h1, dim_const=True):
    #rectangular sketch
    sk = doc.getObject(bd_name).newObject('Sketcher::SketchObject', sk_name)
    p1 = Vector(0, 0, 0)
    p2 = Vector(l1, 0, 0)
    p3 = Vector(l1, h1, 0)
    p4 = Vector(0, h1, 0)
    geoList = []
    geoList.append(Part.LineSegment(p1, p2))
    geoList.append(Part.LineSegment(p2, p3))
    geoList.append(Part.LineSegment(p3, p4))
    geoList.append(Part.LineSegment(p4, p1))
    (line0, line1, line2, line3) = sk.addGeometry(geoList, False)
    conList = []
    conList.append(Sketcher.Constraint('Coincident', line0, 2, line1, 1))
    conList.append(Sketcher.Constraint('Coincident', line1, 2, line2, 1))
    conList.append(Sketcher.Constraint('Coincident', line2, 2, line3, 1))
    conList.append(Sketcher.Constraint('Coincident', line3, 2, line0, 1))
    conList.append(Sketcher.Constraint('Horizontal', line0))
    conList.append(Sketcher.Constraint('Horizontal', line2))
    conList.append(Sketcher.Constraint('Vertical', line1))
    conList.append(Sketcher.Constraint('Vertical', line3))
    sk.addConstraint(conList)
    if dim_const is True:
        con_num = sk.ConstraintCount
        sk.addConstraint(Sketcher.Constraint('DistanceX', line2, 1, line2, 2, l1))
        sk.addConstraint(Sketcher.Constraint('DistanceY', line1, 2, line1, 1, h1))
        sk.renameConstraint(con_num, u'length')
        sk.renameConstraint(con_num + 1, u'width')
    sk.recompute()
    return sk
def make_sk1(doc, bd_name, sk_name):
    """Make sketch 1."""
    sk.MapMode = 'FlatFace'
    sk.Support = (doc1.getObject('YZ_Plane'), [''])
    # Lengths
    h1 = 26.00
    l1 = 10.00 # fake value we assign it later
    l2 = 5.00
    # we draw it using counterclockwise order
    p2 = Vector(0, h1, 0)
    p3 = Vector(-l2, h1, 0)
    p4 = Vector(-l1, 0, 0)
    geoList = []
    sk.addExternal("base_sketch", "Edge2")  #-3
    conList =[]
    conList.append(Sketcher.Constraint('Coincident', -1, 1, line0, 1)) #origin
    conList.append(Sketcher.Constraint('Horizontal', line1))
    conList.append(Sketcher.Constraint('Vertical', line0))
    conList.append(Sketcher.Constraint('Coincident', -3, 2, line2, 2)) #ext reference
    #dimensional constraints (putting in conList fails!?)
    sk.addConstraint(Sketcher.Constraint('DistanceY', line0, 1, line0, 2, h1))
    sk.addConstraint(Sketcher.Constraint('DistanceX', line1, 1, line1, 2, -l2))
    sk.recompute()
    #doc.recompute()
    return sk
# Create the document
DOC1_NAME = 'pd_tut_ew'
doc1 = check_exist(DOC1_NAME)
doc1.clearDocument()
activate_doc(DOC1_NAME)
bd1_name = 'body1'
# We need a body where to place the Features
pd1 = createPDBody(doc1, bd1_name)
base_sk_name = "base_sketch"
base_sketch = make_base_sketch(doc1, bd1_name, base_sk_name, 53.00, 26.00)
base_sketch.addConstraint(Sketcher.Constraint('Symmetric',0,1,0,2,-1,1))
sk1_name = 'sketch_1'
sk1 = make_sk1(doc1, bd1_name, sk1_name)
sk1.Visibility = False
sk1.recompute()
pa1 = pd1.newObject('PartDesign::Pad', 'pad1')
pa1.Type = u"Length"
pa1.AlongSketchNormal = True
pa1.Midplane = True
pa1.Profile = sk1
pa1.setExpression('Length', u'base_sketch.Constraints.length')
pa1.recompute()
# here
pd1.recompute()
doc1.recompute()
doc1.FileName = os.path.join(dirpath, f"{DOC1_NAME}.FCStd")
doc1.Comment = "File produced using PD Scripting"
doc1.CreatedBy = "Dormeletti Carlo"
doc1.save()
setview(doc1)
onekk
Post by onekk »
edwilliams16 wrote: Tue Oct 11, 2022 10:53 pm @onekk I tidied up your script a little.
Many thanks, as usual seeing someone else code is very interesting.
I don't know, why distance constraints work in this way.
These are first experiments with Sketcher, documentation is not very broad about Sketcher scripting so most of the code is taken from python console 'echo' and some code found in Part Design code sources.
Probably experimenting a little more will reveal more and I hope it will make documentation better for future Scripting users.
Let's finish "edwilliams16" versions of the tutorial and see if @Roy_043 has some hints and would put this "more modern version" on the Wiki.
Thanks again a lot and Best Regards.
Carlo D.
onekk
Post by onekk »
Ok it seems I've managed to get something similar to edwilliams16 example.
Some refinements in sketcher code and probably some errors.
20221011_pdtut_ew2.py
(10.77 KiB) Downloaded 51 times
EDIT: new code in:
https://forum.freecadweb.org/viewtopic.php?f=22&t=72207
Here old code is retained as it could be the base for further iterations
@edwilliams16 could you please check the code for mistakes or "big errors", side note, seems that "distance constraints" are working inside conList see make_sk4:
conList = []
    conList.append(Sketcher.Constraint('Parallel', 3, 1))
    conList.append(Sketcher.Constraint('Distance', 1, 2, 2, 2, 17.00))
    conList.append(Sketcher.Constraint('PointOnObject', 0, 2, -2))
    conList.append(Sketcher.Constraint('PointOnObject', 0, 1, -2))
    conList.append(Sketcher.Constraint('DistanceY', -1, 1, 0, 1, 7.00))
I have modified slightly the constraints.
Probably some constraints could be inserted in the creation code, but to reuse some functions, I have left some out, making a "unconstrainted sketch" to complete after creation,
Tell me what you think about?
@Roy_043 After the revision of @edwilliams16 maybe with some help we could make a page about this "more modern way" to make the tutorial.
I know that TNP mitigation could change the workflow, but for 0.20 maybe it will be a "better way" to advise to new users?
Regards
Carlo D.
edwilliams16
I'll take a look at your code. Here's my script:
Copyright: 2022
import os
import Sketcher
import Part
        try:
        except Exception:
            pass
def setview(doc):
    try:
    except Exception:
        pass
    try:
    except NameError:
    return doc
# CODE start here
    pass
else:
    # create path
    os.mkdir(dirpath)
    if lcs is True:
    newBody.recompute()
    doc.recompute()
    return newBody
def sketchPolyLine(vertexList, closed = True, addHVConstraints = True):
    geoList = []
    conList = []
    npts = len(vertexList)
    for i in range(npts - 1):
        geoList.append(Part.LineSegment(vertexList[i], vertexList[i+1]))
    if closed:
        geoList.append(Part.LineSegment(vertexList[-1], vertexList[0]))
        conList.append(Sketcher.Constraint('Coincident', i, 2, i + 1, 1))
    if closed:
        conList.append(Sketcher.Constraint('Coincident', npts - 1, 2, 0, 1))
    if addHVConstraints:
        for i, ls in enumerate(geoList):
            if abs(ls.tangent(0)[0].y) < 1e-14:
                conList.append(Sketcher.Constraint('Horizontal', i))
            elif abs(ls.tangent(0)[0].x) < 1e-14:
                conList.append(Sketcher.Constraint('Vertical', i))
    return (geoList, conList)
    #rectangular sketch
    geoList, conList = sketchPolyLine([p1, p2, p3, p4])
    sk.addConstraint(Sketcher.Constraint('Symmetric',0,1,0,2,-1,1))
    sk.recompute()
    return sk
    # Lengths
    h1 = 26.00
    l2 = 5.00
    sk.recompute()
    return sk
def make_sk2(doc, bd_name, sk_name):
    sk.Support = (doc1.getObject('XZ_Plane'), [''])
    l1 = 5.00
    l2 = 11.00
    h1 = 26 #fake
    w1 = 26.5 #fake
    p1 = Vector(-w1, h1, 0)
    p2 = Vector(-w1 + l2, h1, 0)
    p3 = Vector(-w1 + l2, h1 - l1, 0)
    p4 = Vector(-w1, h1 - l1, 0)
    sk.addExternal("base_sketch", "Edge3")  #-3
    sk.addExternal("sketch_1", "Edge3")  #-4
    conList.append(Sketcher.Constraint('PointOnObject', -3, 1, line3)) #ext reference
    conList.append(Sketcher.Constraint('PointOnObject', -4, 1, line0)) #ext reference
    sk.addConstraint(Sketcher.Constraint('DistanceY', line3, 1, line3, 2, l1))
    sk.addConstraint(Sketcher.Constraint('DistanceX', line0, 1, line0, 2, l2))
    sk.recompute()
    #doc.recompute()
    return sk
def make_sk3(doc, bd_name, sk_name):
    """Make sketch 3."""
    l1 = 16.7
    l2 = 7
    w1 = 26.5 #fake
    p1 = Vector(-w1, l1, 0)
    p2 = Vector(-w1 + l2, l1, 0)
    p3 = Vector(-w1 + l2, 0, 0)
    p4 = Vector(-w1, 0, 0)
    conList.append(Sketcher.Constraint('Coincident', -3, 1, line3, 1)) #ext reference
    sk.addConstraint(Sketcher.Constraint('DistanceY', line1, 2, line1, 1, l1))
    sk.recompute()
    #doc.recompute()
    return sk
def make_sk4(doc, bd_name, sk_name):
    """Make sketch 4."""
    d1 = 7
    d2 = 17
    p1 = Vector(-11, 19, 0) #fake approx
    p2 = Vector(-22, 5, 0) #fake approx
    p3 = Vector(0, 5, 0) #fake approx
    p4 = Vector(0, 19, 0) #fake approx
    geoList, conList = sketchPolyLine([p1, p2, p3, p4], closed = True)
    sk.addExternal('sketch_1', 'Edge3')
    conList.append(Sketcher.Constraint('PointOnObject', 0, 1, -3)) #ext reference
    conList.append(Sketcher.Constraint('PointOnObject', 1, 1, -3)) #ext ref
    conList.append(Sketcher.Constraint('PointOnObject', -1, 1, 2)) #yaxis
    sk.addConstraint(Sketcher.Constraint('Distance',-3,2,line0,2,d1))
    sk.addConstraint(Sketcher.Constraint('Distance',line0,2,line0,1,d2))
    sk.recompute()
    return sk
bd1_name = 'body1'
#build sketches
base_sketch.Visibility = False
#base_sketch.addConstraint(Sketcher.Constraint('Symmetric',0,1,0,2,-1,1))
sk1.recompute()
sk2_name = 'sketch_2'
sk2 = make_sk2(doc1, bd1_name, sk2_name)
sk2.Visibility = False
sk3_name = 'sketch_3'
sk3 = make_sk3(doc1, bd1_name, sk3_name)
sk3.Visibility = False
sk4_name = 'sketch_4'
sk4 = make_sk4(doc1, bd1_name, sk4_name)
sk4.Visibility = False
#first pad
pa1.Midplane = True
pa1.Profile = sk1
pa1.recompute()
# here
#pd1.recompute()
#first pocket
pk1 = pd1.newObject('PartDesign::Pocket', 'pocket1')
pk1.Type = u'ThroughAll'
pk1.Profile = sk2
pk1.AlongSketchNormal = True
#pk1.ReferenceAxis = (sk2,['N_Axis'])
pk1.Reversed = True
pd1.recompute()
#second pad
pa2 = pd1.newObject('PartDesign::Pad', 'pad2')
pa2.Type = u"Length"
pa2.AlongSketchNormal = True
pa2.Profile = sk3
pa2.setExpression('Length',u'base_sketch.Constraints.width')
#mirror pocket and second pad
pa3 = pd1.newObject('PartDesign::Mirrored', 'Mirrored_Pad')
pa3.Originals = [pk1, pa2]
pa3.MirrorPlane = (doc1.getObject('YZ_Plane'), [''])
pa3.Refine = True
pa3.recompute()
pd1.Tip = pa3
pd1.recompute()
#final pocket
pk2 = pd1.newObject('PartDesign::Pocket', 'pocket1')
pk2.Type = u'Length'
pk2.Profile = sk4
pk2.Midplane = True
pk2.AlongSketchNormal = True
pk2.Length = 17
pk2.Refine = True
doc1.recompute()
doc1.save()
setview(doc1)
Screen Shot 2022-10-12 at 12.18.28 PM.png (27.64 KiB) Viewed 1570 times
edwilliams16
@onekk I found one error - in sketch_4 the 7 mm dimension should be a diagonal Distance - not a Distance_Y
Otherwise our code is quite similar. I factored out a function to make a sketcher polygon with constraints.
onekk
Post by onekk »
edwilliams16 wrote: Thu Oct 13, 2022 3:16 am @onekk I found one error - in sketch_4 the 7 mm dimension should be a diagonal Distance - not a Distance_Y
Hello, many thanks, for the work.
Your code is more clean, and readability is improved.
I think that goal to make a more modern example is accomplished, now the point is to make a wiki page with the "modernized example".
I think that other users, my mind remind @Roy_043 , @Shalmeneser, @chrisb, @TheMarkster as people that gave most advices to new users, could give some further advices.
Every constructive criticism is welcomed.
Obviously if this "modernized example" could be of some help in modelling correctly with sketcher.
Sadly my 0.19 AppImage is refusing to start as in my Arch Linux distribution something is changed.
So I can't test the script to see if we could advise 0.19 as lowest version were the script and the example should work.
What do you think?
Many thanks again and Best Regards.
Carlo D.
onekk wrote: Thu Oct 13, 2022 4:47 am I think that @Roy_043 , @Shalmeneser, @chrisb, @TheMarkster could give some further advices as by memory they are the people that gave most advices to new users.
I will have a look later.
onekk
Post by onekk »
chrisb wrote: Thu Oct 13, 2022 4:49 am ...
Thanks a lot.
Roy_043
Post by Roy_043 »
onekk wrote: Thu Oct 13, 2022 4:47 am I can't test the script to see if we could advise 0.19 as minir version were the script and the example should work.
The scripts do not work in V0.19 because the doc.clearDocument() method is missing in that version. I would personally just create a new document. I also would not save the document, but if you do you should prompt the user for a filename IMO.
