[Ongoing] Testing Toponaming in upstream FreeCAD
Report observations made with the new Toponaming branch.
mfro
Re: [Ongoing] Testing Toponaming in upstream FreeCAD
Post by mfro »
Found the "Sketcher_SwapGeometryID" function in the Toponaming branch.
What does it do and why would I use it?
Cheers,
Markus
Post by Kunda1 »
mfro wrote: Sun Oct 02, 2022 11:58 am Found the "Sketcher_SwapGeometryID" function in the Toponaming branch.
can you specify lines in the source?
mfro
Post by mfro »
Kunda1 wrote: Fri Oct 07, 2022 9:11 am
I didn't check (yet). I was referring to the additional Icon/Function in Sketcher Workbench.
Cheers,
Markus
obelisk79
Post by obelisk79 »
Greetings,
Is there an updated status on the progress of the final PR adding the Part Design integration? It's been quite some time and I've been waiting for this before testing as it's a significant part of my primary work flow.
Regards,
Joe
realthunder
Post by realthunder »
It lets you swap the internal names of the geometries, in order to reduce chance of model breaking in later steps. See this post for and example.
Try Assembly3 with my custom build of FreeCAD at here.
realthunder
obelisk79 wrote: Sat Oct 22, 2022 9:58 pm Greetings,
Regards,
Joe
The team agree to make formal release for the toponaming branch in its current state first (very soon). And if no major problems reported by other developers, then I'll add the PartDesign patch.
drmacro
Post by drmacro »
realthunder wrote: Sun Oct 23, 2022 5:10 am
Regards,
Joe
Does this imply that some or all of the TNP mitigation should work in a Part workbench situation?
This movie shows my test with PArt WB with the build shown below:
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.21.29382 +77 (Git)
Branch: development/toponaming
Hash: 5cc0693e61b9b547cc26404604ea6c1c883a6435
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.0.dev
Installed mods:
  * parts_library
  * kicadStepUpMod 10.16.5
  * Manipulator 1.4.9
  * PrefExtras
  * QuickMeasure
  * MyDefaults 2022.9.15
  * ZolkoBase 0.0.1
  * DynamicData 2.46.0
  * fasteners 0.4.19
  * MacMechX 2022.9.15
  * ExtremeProDark 2.3.3
  * ProDarkThemePreferencePack 1.0.0
  * fcgear 1.0.0
  * plugins
  * Pyramids-and-Polyhedrons
  * Defeaturing 1.2.0
  * Assembly4 0.12.4
  * BaseTest 0.0.1
  * OpticsWorkbench 1.0.9
  * workfeature-macro
  * sheetmetal 0.2.58
  * A2plus 0.4.59e
  * CurvedShapes 1.0.4
  * BasicMech 0.0.1
  * Dracula 0.0.2
  * Curves 0.5.12
  * workfeature
  * lattice2 1.0.0
wsteffe
Post by wsteffe »
drmacro wrote: Wed Oct 26, 2022 11:17 am This movie shows my test with PArt WB with the build shown below:
And what is it supposed to demonstrate ?
drmacro
Post by drmacro »
wsteffe wrote: Wed Oct 26, 2022 2:00 pm
...the sketch for the olive block is attached to the top surface of the green block. Change the sketch of the green block and the olive block is now attached to the bottom surface of the green block.
adrianinsaval
Post by adrianinsaval »
please use webp or some other video format, gif is very hard to follow because there's no start/end reference.
