Path Workbench Code restructuring - heads up
Re: Path Workbench Code restructuring - heads up
@sliptonic:
thanks a lor for the the script!
No time to test it until now. Unfortunately.
(Somebody can sell me days of 96 hours? I would buy a dozen. )
Here is your version modified with a solution for encoded viewprovider issue. This version also removes the command-line usage. This one is designed to be run in a folder containing .FCStd files, converting each and appending the new versions with "_current" to the filename.
Thanks for the script, Sir. Work on my similar script was failing in the re-Zipping process.
Edit 2023-03-11: Deleted files in place of updated version. Originals were about 90+ downloads combined.
Cheers.
Russell
OS: Windows 10 Version 2009
Version: 0.21.30769 (Git)
Hash: 1282fdb7e8a721e9b411358d68daf8921b0bf50a
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
* FC_SU
* PathExp
* Z_MacroStartup
- sliptonic
Awesome! Thanks Russ
Since the list of module maps is still incomplete, maybe we should add a dry-run option that just spits out the list of modules that don't have maps.
And/Or have the action cancel and not create the new version, but report the missing modules that are needed for success with a message to the user suggesting they be added and the utility re-run.
Russell
Russell
Hi @sliptonic, Hi @Russ4262,
I use the Path workbench for many years, and I can't beleave that all the precedent work desapear like this!
Many thanks for your script which try to keep our work!
In JobFixerCopy.py, I added in the maps:
objectmaps:
"PathScripts.PathPocket": "Path.Op.Pocket",
"PathScripts.PathProfileContour": "Path.Op.Profile",
viewprovidermaps:
"PathScripts.PathPocketGui": "Path.Op.Gui.Pocket",
"PathScripts.PathHelixGui":"Path.Op.Gui.Helix",
"PathScripts.PathProfileContourGui": "Path.Op.Gui.Profile",
however, I still have difficulty retrieving models with tool definitions.
Here are the error messages I get:
I also attached the offending test model before and after conversion...
Thanks for your help
Gauthier.
objectmaps:
viewprovidermaps:
16:35:40 Invalid type Path::PropertyTool for property UsinagePlatineMinuterie06_current#T1__Fraise_D3x20.Tool
16:35:40 Invalid type Path::PropertyTool for property UsinagePlatineMinuterie06_current#T2__Foret_D2.Tool
16:35:40 <string>(1)<class 'AttributeError'>: Module Path.Op.Profile has no class ObjectContour
16:35:41 Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/shiboken2/files.dir/shibokensupport/__feature__.py", line 142, in _import
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolController'
File "/home/gauthier/src/FreeCAD/build_20221218/Mod/Path/Path/Dressup/Gui/Tags.py", line 477, in updateData
self.updatePositions(obj.Positions, obj.Disabled)
File "/home/gauthier/src/FreeCAD/build_20221218/Mod/Path/Path/Dressup/Gui/Tags.py", line 467, in updatePositions
self.obj.Proxy.pointAtBottom(self.obj, p), self.colors
File "/home/gauthier/src/FreeCAD/build_20221218/Mod/Path/Path/Dressup/Tags.py", line 1350, in pointAtBottom
self.setup(obj)
File "/home/gauthier/src/FreeCAD/build_20221218/Mod/Path/Path/Dressup/Tags.py", line 1314, in setup
self.toolRadius = float(PathDressup.toolController(obj.Base).Tool.Diameter) / 2
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Tool'
Gauthier.
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.21.0.31340 (Git)
Build type: Unknown
Hash: 856af2a12287a2d7c0d5ab23646be43af26b14b1
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.8.0.dev
Locale: C/Default (C) [ OS: French/France (fr_FR) ]
Installed mods:
* fasteners 0.4.27
* Curves 0.6.5
* Assembly4 0.12.5
* CurvedShapes 1.0.4
- UsinagePlatineMinuterie06_current.FCStd
- (928.32 KiB) Downloaded 145 times
- UsinagePlatineMinuterie06.FCStd
- (430.03 KiB) Downloaded 135 times
- sliptonic
It's the flip-side of improving fast. People start to get comfortable with the tool as it is. But remember, we're not even at 1.0 yet. There's a good chance that things will break, especially in development and no implied guarantee of backward compabitility. We do our best but caveat emptor.
Great! Thanks.In JobFixerCopy.py, I added in the maps:
objectmaps:
viewprovidermaps:
There is the file from this post. I can open it in 0.20, but it crashes my FreeCAD 0.21, even if I run JobFixerCopy.py on it.Russ4262 wrote: ↑Wed Nov 16, 2022 5:14 amHere is your version modified with a solution for encoded viewprovider issue. This version also removes the command-line usage. This one is designed to be run in a folder containing .FCStd files, converting each and appending the new versions with "_current" to the filename.
Should I create a ticket?
I went back and tried that file in several ways.
First, with an older version of FreeCAD (0.21) before the refactor. No crash, but lots of TechDraw errors.
Next, with the original referenced FCStd file and a recent version of FC. Again, no crash, but a bunch of Path errors reported.
Finally, with the repaired FCStd file and the same recent version of FC. No crash and no errors.
Version: 0.21.0.31432 (Git)
Hash: 63a2855751d638bf27ed969dc60654bda2b54baf
Python 3.10.8, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
* FeedsAndSpeeds 0.5.0
* FeedsAndSpeeds-master.zip
* freecad.gears 1.0.0
* Help 1.0.3
Gene
Indeed, sorry for the noise. I removed the whole Job in 0.20, and FreeCAD still crashes when loading the file. I have to investigate this further.
I ran the JobFixerCopy.py script to the target file, then opened it with FC version provided. Only one error occurs and is on the Job - see screenshot. I recompute the Job and the error disappears. The Drilling operation has no path visible and cannot be accessed when double clicking to edit. Deleting and recreating a default Drilling op succeeds.
Russell
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
* FC_SU
* PathExp
* Z_MacroStartup
- Initial Job error upon loading.
- Screenshot 2023-03-11 070840.png (158.03 KiB) Viewed 13326 times
