[Issue] Multiline Textfield with Dark Themes
balrobs
Post by balrobs »
Recently I noticed an issue with the multiline-textfield while using the ExtremeProDark Theme. So I investigated on other three Dark Themes (Dracula, ProDarkThemePack and Behave-Dark Colors) and discovered that:
  • all of them show an inconsistency between singleline and multiline textfields
  • the multiline textfield is only readable with the Behave-Dark Colors Theme
Behave-Dark Colors Theme:
Behave-Dark Colors.png (56.34 KiB) Viewed 2421 times
Dracula Theme:
ExtremeProDark Theme:
ProDarkThemePack Theme:
Edit: Forgot my system info:
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.21.29856 (Git) Snap 177
Hash: a6fbd74caeed6c9f55041ee82ec227c12bc11900
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
Installed mods:
  * BIM 2021.12.0
  * Behave-Dark-Colors 0.1.1
  * ProDarkThemePreferencePack 1.0.0
  * FEM_FrontISTR 0.1.0
  * ExtremeProDark 1.0.3
  * Dracula 0.0.2
MisterMaker
Re: [Issue] Multiline Textfield with Dark Themes
Post by MisterMaker »
I have seen this issue in the python console and I fixed it too there, not sure if it's the same style and I forgot too publish the fix.... I'll have a look at it tomorrow.
balrobs
Post by balrobs »
Thanks @Mistermaker for picking up the issue and for your wonderfull work.
Greetings
MisterMaker
This doesn't seem to be themed anywhere. It's just default color everywhere.
I think it has to do with qlineedit cursor position. But can't find any examples on how to put this in a theme.
Maybe @wandererfan knows how it is enabled then we probably can give it a name?
https://doc.qt.io/qt-6/qlineedit.html#c ... ition-prop
wandererfan
Post by wandererfan »
MisterMaker wrote: Tue Aug 02, 2022 8:22 am Maybe @wandererfan knows how it is enabled then we probably can give it a name?
The annotation text is an App::PropertyStringList, so the PropertyEditor needs to be tweaked. Either PropertyStringListItem in PropertyItem.cpp, or maybe Gui:LabelEditor in Widgets.cpp.
The template fields are updated by TechDraw/Gui/DlgTemplateField.cpp/DlgTemplateField.ui.
I don't know much about stylesheets, so I'm not sure why one respects the stylesheet and the other doesn't.
MisterMaker
@wandererfan Thanks for the help, I digged around and still don't understand why this multi-line box that skips the stylesheet, also don't understand why/how it has line numbers and why the cursor line is marked.
At least I know what is called: "leInput"!
        leInput = new QLineEdit(TechDrawGui__dlgTemplateField);
        leInput->setObjectName(QString::fromUtf8("leInput"));
wandererfan
MisterMaker wrote: Tue Aug 02, 2022 8:10 pm At least I know what is called: "leInput"!
leInput -> leProcessing -> leOutput? :D
I think you're looking for these classes in Gui/Widgets.cpp:
class GuiExport PropertyListEditor : public QPlainTextEdit
class GuiExport LabelEditor : public QWidget
class LineNumberArea : public QWidget
The yellow colour is hard coded here:
void PropertyListEditor::highlightCurrentLine()
    QList<QTextEdit::ExtraSelection> extraSelections;
    if (!isReadOnly()) {
        QTextEdit::ExtraSelection selection;
        QColor lineColor = QColor(Qt::yellow).lighter(160); //<<<<<<<<<<
        selection.format.setBackground(lineColor);
        selection.format.setProperty(QTextFormat::FullWidthSelection, true);
        selection.cursor = textCursor();
        selection.cursor.clearSelection();
        extraSelections.append(selection);
    setExtraSelections(extraSelections);
wandererfan
This change:
        //        QColor lineColor = QColor(Qt::yellow).lighter(160);
        QPalette palette = QGuiApplication::palette();
        QColor lineColor = palette.color(QPalette::Highlight);
        QColor textColor = palette.color(QPalette::HighlightedText);
        selection.format.setForeground(textColor);
gets you this:
"no stylesheet" and the couple of stylesheets I tried looked good, but I didn't try them all.
balrobs
Post by balrobs »
Wow, this is why I love FreeCad. A few days and issues get solved :D
