LF: Designer able to convert from Solidworks/others
Hello friends!
I work with Glia, an organization dedicated to making Free and Open Access medical devices that are as good or better than currently existing gold standard devices. We have made several essential and successful devices including a stethoscope and PPE. We've also made a 3D printed tourniquet that we are working on making an injection molding version of. These tourniquets have been used in Gaza, Myanmar and most recently Ukraine.
In the course of working on injection molding, we have found no molding or mold design shops that use FreeCAD or any FOSS tools. As such, we're hiring a designer who is able to convert from Solidworks / similar into FreeCAD so that we can maintain our repository and keep all our devices Free and Open Access.
The current repository is here if you're interested in seeing what we've done so far.
Please reach out to me here or via email at tarek@tarek.org. We're open to negotiating hourly or project-based payment. All products of this relationship will be released as open source files and will be used to produce the molds we make tourniquets out of.
Thank you!
tarek : )
Thank you!
tarek : )
- Shalmeneser
Re: LF: Designer able to convert from Solidworks/others
- buckle_back_SHALM.FCStd
- (75.88 KiB) Downloaded 69 times
- Capture d’écran 2022-07-15 160835.jpg (51.08 KiB) Viewed 4803 times
- Shalmeneser
- Windlass_SHALM.FCStd
- (45.11 KiB) Downloaded 68 times
- Capture d’écran 2022-07-15 170657.jpg (15.33 KiB) Viewed 4781 times
- thomas-neemann
it's probably easier than you think. the people who work with solidworks etc. only need to export it as stp or stl etc., freecad can import that and you can continue working with it in freecad
Thank you for this. We want the files to be easy to modify in the future, which seems to exclude importing an STL. STP is one we've been playing with, but it hasn't been a great medium for communicating between us and shops that work on Solidworks. Do you have some examples I could show the designers by chance?thomas-neemann wrote: ↑Fri Jul 15, 2022 5:33 pm it's probably easier than you think. the people who work with solidworks etc. only need to export it as stp or stl etc., freecad can import that and you can continue working with it in freecad
The problems we've had interfacing with molding design and production shops is why we're letting them go forward with solidworks then immediately porting and producing from the FreeCAD source.
tarek : )
Actually we have some "injection molding people" amount our users. Maybe you should talk to them. I think there is at least one who is actually building those tools himself. Unfortunately, I was only able to find one thread but that wasn't one of those I was looking for: 3D design of molds for thermoforming.
@chrisb Do you have one of those threads / users I'm thinking of "at hand / in your bookmarks"?
Regards / Viele Grüße
Max
Max
I suggest @freecad-heini-1. I would rate him a modeling wizard.
Thank you dear Chris. Unfortunately, I currently have no time for such projects, there are enough tasks to do in my family, office, house, yard and garden.
Hello Tarek. I am interested in the job offer and would like to know further.tarek wrote: ↑Sat Jul 16, 2022 2:15 am
tarek : )
Am I right that the remodeling is for the parts, not the mould?
I have cloned the repository and found that you have the source file of the parts in OpenSCAD format.
For starters, attached is the backing support part made in OpenSCAD WB.
I can also make it in sketch + feature approach if that is preferred.
Also, I do not know if the FreeCAD .amf format is compatible with OpenSCAD .3mf format.
It should be checked [at least later] if the development on FreeCAD source can still be used in 3D printer setting.
Lastly, I used this FreeCAD version below to generate the model. If you prefer other version, let me know.
You can reach me at iwanteknikmesin08@gmail.com.
Kind regards,
Iwan
OS: macOS 13.0
Version: 2022.1021.26244 +5249 (Git)
Branch: LinkDaily
Hash: d307b5c936403e8dca3f24b5c1e64bd16c88b28d
Python version: 3.9.10
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.6.0
Locale: C/Default (C)
- backing support.step
- (140.65 KiB) Downloaded 58 times
- backing support.FCStd
- (113.79 KiB) Downloaded 61 times
