[Bug] IFC Export not working properly
This forum section is only for IFC-related issues
paullee
Post by paullee »
Just test IFC Export, seems something not working properly (again) ? :D
Test_ Ifc_ 01_ ArchWall-Sketch.FCStd
(13.21 KiB) Downloaded 68 times
Test_ Ifc_ 01a_ ArchWall-Sketch.FCStd
(22.55 KiB) Downloaded 68 times
Test_ Ifc_ 01_ ArchWall-Sketch-Wall.ifc
(3.14 KiB) Downloaded 69 times
Test_ Ifc_ 01a_ ArchWall-Sketch-Wall.ifc
(3.53 KiB) Downloaded 67 times
Screenshot from 2022-05-24 08-05-22.png (314 KiB) Viewed 2434 times
(re-import IFC into FreeCAD)
Screenshot from 2022-05-24 08-06-53.png (297.86 KiB) Viewed 2434 times
Screenshot from 2022-05-24 08-09-15.png (104.75 KiB) Viewed 2434 times
Screenshot from 2022-05-24 08-03-20.png (119.35 KiB) Viewed 2434 times
Screenshot from 2022-05-24 08-03-39.png (123.21 KiB) Viewed 2434 times
OS: Fedora 34 (Workstation Edition) (GNOME/gnome)
Version: 0.20.28765 (Git)
Branch: (HEAD detached at 795f86c)
Hash: 795f86c18c22260cfc3627bdd5b71504b9dca4ef
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * Curves 0.4.3
  * DynamicData 2.46.0
  * Assembly4 0.11.12
  * ArchTextures
Same result in below version -
Version: 0.20.28810 (Git) AppImage
Branch: (HEAD detached at 6f5a5a2)
Hash: 6f5a5a2019c586db63650713de860d3e810739d4
Installed mods:
  * Curves 0.4.3
  * Assembly4 0.11.12
  * ArchTextures
yorik
Founder
Re: [Bug] IFC Export not working properly
Post by yorik »
Seeing the problem too. getExtrusionData() looks OK:
Screenshot from 2022-05-24 11-09-32.png (68.61 KiB) Viewed 2376 times
The problem is in the code that detects rectangles from faces:
Screenshot from 2022-05-24 11-09-43.png (159.38 KiB) Viewed 2376 times
https://github.com/FreeCAD/FreeCAD/blob ... C.py#L1942 The rectangles are not properly positioned. Their rotation, however, seem correct. I think the problem is the position (0,0,0) at L1947, actually each subwall should get an offset...
paullee
Post by paullee »
Thanks checking.
getExtrusionData() should be fine as ArchWall works without problem. The ExportIFC.py and IFC are just too difficult for me to understand what they work currently. :oops:
thomas-neemann
Post by thomas-neemann »
if someone wants a workaround immediately: create a simple copy in part and export it as an ifc
Test_ Ifc_ 01_ ArchWall-Sketch.ifc
(11.2 KiB) Downloaded 63 times
paullee
Post by paullee »
Alternatively, export as Brep also works
paullee
Post by paullee »
yorik wrote: Tue May 24, 2022 9:18 am https://github.com/FreeCAD/FreeCAD/blob ... C.py#L1942 The rectangles are not properly positioned. Their rotation, however, seem correct. I think the problem is the position (0,0,0) at L1947, actually each subwall should get an offset...
I dig into some history and find below change -
https://github.com/FreeCAD/FreeCAD/comm ... 9274c70bd1
+        povc = ifcbin.createIfcCartesianPoint(tuple(p.CenterOfMass[:2]))
-        povc = ifcbin.createIfcCartesianPoint((0.0,0.0))
+        # profile must be located at (0,0) because placement gets added later
+        #povc = ifcbin.createIfcCartesianPoint(tuple(p.CenterOfMass[:2]))
I have no idea the meaning of the previous code, but seems the previous line works ? :)
exportIFC.py
(104.47 KiB) Downloaded 64 times
The new ifc reimported into FreeCAD
Screenshot from 2022-05-27 08-14-57.png (217.88 KiB) Viewed 2178 times
yorik
Founder
Post by yorik »
The whole thing was -If I remember correctly- to try to make these IfcRectangleProfileDef understood by Revit, which never succeeded. Therefore, in the IFC preferences, there is an option to disable the use of IfcRectangleProfieDef entirely. I think the (0,0) location was needed somewhere... But couldn't remember. In any case, we should test your file with some more apps to make sure.
I just tested it with IFc++, IfcOpenShell viewer and BlenderBIM and all display it correctly... I think we can consider it OK :) Would you mind doing a pull request?
paullee
Post by paullee »
OK, I can do the PR ( sort of reverting previous commit ), just I haven't understood how the whole thing works :lol:
And indeed tested that disabling IFCRectangleProfileDef works also - maybe it was why I had my impression it 'used to' work at some point.
Another thing is 'native' IFC support and Sharing Code between Freecad and Blenderbim, there is nothing common in this ExportIFC.py with BlenderBIM right? (I never have time to really install it and test )
Screenshot from 2022-05-28 05-41-15.png (228.8 KiB) Viewed 2098 times
paullee
Post by paullee »
Revisited again [Regression ?] - Villa Savoye Model export problems and noted it had been IFCRectangleProfileDef .
Should we support this, or make it default to Disable IFCRectangleProfileDef to make the FC exported IFC 'universally compatible' ? :roll:
Screenshot from 2022-05-28 07-01-34.png (242.04 KiB) Viewed 2077 times
yorik
Founder
Post by yorik »
The thing is, IfcRectangleProfileDef is standard IFC. It's Revit's fault to not support it. We shouldn't remove it just to satisfy a bad implementation somewhere. Ok I did it :) git commit 47125d8fda
