When we will can use binder for sweep?
When we will can use binder as a shape for a sweep or a loft?
- Capture.JPG (17.05 KiB) Viewed 2717 times
Re: When we will can use binder for sweep?
Its cannot possible with binder. loft and sweep.
Could be easy to add this feature, I guess.
- external_shape.FCStd
- (10.71 KiB) Downloaded 59 times
Works just fine. You need to select correctly. That's all.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.27371 (Git)
Branch: Master
Hash: cfdf334b7f45b6ac0d6432890b1a9c5792ddaaa5
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Gene
Branch: Master
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Gene
I think you redraw the binder. Its not the purpose of my post. If we can use the binder for pad, why not for a sweep or a loft.
As TheMarkster already pointed up you need to select the Face of the Binder and not the Binder itself:
- BinderFaceSweep.JPG (77.78 KiB) Viewed 2438 times
Thinking about that, why to not give the same workflow like others shapes, I mean select the shapebinder and then launch the sweep command?
The selection workflow is tricky if the body has not any shape inside (starting a new shape)
