Position and orientation in the reference frame of a LCS
openBrain
Re: Position and orientation in the reference frame of a LCS
Post by openBrain »
carlopav wrote: Sat Mar 05, 2022 2:04 pm Se more thoughts? To me this is quite a crucial topic and would be nice if we could have a consistent api exposed to the developers...
Actually no, not really enough time for this. But I still think there is something to be improved there. ;)
josegegas
Post by josegegas »
Hello.
Just to clarify my question. Imagine a simple draft point:
point = Draft.makePoint(X, Y, Z)
then such a point will be at (X,Y,Z) relative to the global reference frame.
Now, imagine a local coordinate system that is at any position and orientation relative to the global coordinate system.
The question is, how can I get the position of the point, but as viewed from the local coordinate system?
I know I can do some simple geometry or a transformed coordinate system for this, but I though FreeCAD may already have this option...
The same applies for the position of the points that define a line.
Roy_043
Post by Roy_043 »
import FreeCAD as App
import Draft
doc = App.newDocument()
p1 = App.Vector(0, 0, 0)
p2 = App.Vector(1000, 500, 0)
line = Draft.make_line(p1, p2)
place = line.Placement
place.rotate(App.Vector(0, 0, 0), App.Vector(1, 1, 1), 35)
doc.recompute()
global_point = place.multVec(line.Points[1])
print(global_point)
local_point = place.inverse().multVec(global_point)
print(local_point)
ryryss
Post by ryryss »
Roy_043 wrote: Sun Jul 17, 2022 2:00 pm
import Draft
doc.recompute()
print(global_point)
print(local_point)
Hi, Roy
How to get the global location of an object in a link group? when the link group move, the placement information of objects in the group is not updated.
Roy_043
Post by Roy_043 »
Your code should determine the cumulative effect of the placements (see Option 1). Part.getShape can also be used, but is less efficient if you do not need the shape it returns (see Option 2).
import Part
doc = App.ActiveDocument
prt = doc.Part
grp = doc.LinkGroup
lnk = doc.Link
lin = doc.Line
# Option 1
point = lin.Points[1]
for obj in [lin, lnk, grp, prt]:
    point = obj.Placement.multVec(point)
print(point)
# Option 2
shape, matrix, obj = Part.getShape(prt, "LinkGroup.Link", needSubElement=True, retType=2)
place = App.Placement(matrix)
point = place.multVec(point)
print(point)
Placement_Test_LinkGroup.FCStd
(7.39 KiB) Downloaded 46 times
edwilliams16
Post by edwilliams16 »
Roy_043 wrote: Fri Jul 22, 2022 10:37 am
What is the meaning of this error your file generates when clicking on LinkGroup?
Error adjustedGlobalPlacement
I get it with
OS: macOS High Sierra (10.13)
Version: 0.20.29177 (Git)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
  * Curves 0.4.4
  * DynamicData 2.46.0
  * fasteners 0.3.44
  * fcgear 1.0.0
  * GDML 1.8.0
  * Help 1.0.2
  * lattice2 1.0.0
  * MeshRemodel 1.8919.0
  * toSketch
but not with
Version: 0.21.29393 (Git)
Hash: 6820e0a9ec85203a6f342ca72a2ff8fd417beaf1
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * Curves 0.4.4
  * fasteners 0.3.44
  * fcgear 1.0.0
  * GDML 1.8.0
  * Help 1.0.2
  * lattice2 1.0.0
  * toSketch
Roy_043
Post by Roy_043 »
edwilliams16 wrote: Fri Jul 22, 2022 11:43 pm What is the meaning of this error your file generates when clicking on LinkGroup?
I am pretty clueless.
I don't get the error with V0.20 either BTW.
Branch: releases/FreeCAD-0-20
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
josegegas
Post by josegegas »
I am doing what I think may be the most efficient way to solve this:
#Create a placement:
p1 = App.Placement()
#Move to (0,0,1). The "point" is now (0,0,1).
p1.Base = (0,0,1)
#Create a local coordinate system (initially orthonormal to the global coordinate system):
lcs = App.activeDocument().addObject( 'PartDesign::CoordinateSystem', 'LCS' )
#Get the placement of p1 as seen from LCS (same as global placement of p1):
lcs.Placement.inverse().multiply(p1)
#Move and rotate the LCS:
lcs.Placement=App.Placement(App.Vector(0,0,-1), App.Rotation(0,0,90), App.Vector(0,0,0))
#Get the new placement of p1 as seen from the translated and rotated LCS:
Is this correct?
dprojects
Post by dprojects »
realthunder wrote: Mon Feb 07, 2022 1:31 am
Gui.Selection.getSelectionEx('',0):
Is it documented somewhere? is there any API for that? or this is hidden knowledge borrowed from ancient aliens and posted at forum only for chosen? LOL
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
