Constraint icons size at Sketcher edit (PR ready)
vanuan
Re: Constraint icons size at Sketcher edit (PR ready)
Post by vanuan »
Let's look at the implementation of Quarter. It doesn't appear to use the setPixelsPerInch method:
https://coin3d.github.io/Coin/html/clas ... d342b11d44
So it means that by default SoFont uses pixels, not points to determine the font size (72 pixels per inch instead of 96).
To determine the font size in pixels when text scaling is set to 200%, Qt uses the following formula:
device_pixel_ratio = 2 // 200%
pixels = points / 72 * 96 * device_pixel_ratio
Currently, Quarter doesn't appear to use device_pixel_ratio at all. Neither does it use a 96 logical dpi value to account for differences between screens and printers. It just assumes a logical dpi of 72 and draws everything in low resolution.
Maybe, you're right and just setting dpi to 96 multiplied by device pixel ratio (using setPixelsPerInch method) would help.
vanuan
Post by vanuan »
There's even a comment about that in a portion of code that is used to grab the picture from Quarter:
https://github.com/FreeCAD/FreeCAD/blob ... 1627-L1630
//NOTE: To support pixels per inch we must use SbViewportRegion::setPixelsPerInch( ppi );
//The default value is 72.0.
vanuan
Post by vanuan »
Looking further at Coin3D code, it doesn't appear Viewport's PPI is used anywhere. Which suggests that SoFont is implemented to specify the size in pixels, while it was supposed to take into an account the pixels per point value of the viewport.
vanuan
Post by vanuan »
Quick look:
viewer = FreeCADGui.ActiveDocument.ActiveView.getViewer()
rm = viewer.getSoRenderManager()
vp = rm.getViewportRegion()
vp.getPixelsPerInch()
# 72.0
vp.getPixelsPerPoint()
# 1.0
confirms that pixel = point as far as Coin3D is concerned.
chennes
Post by chennes »
Is anyone else suddenly getting black boxes around their constraints?
This just started happening to me in the last couple of weeks. I haven't done a bisect yet to track down the exact commit, but I'll get on that soon.
Chris Hennes
Pioneer Library System
Elyas
Post by Elyas »
chennes wrote: Thu Jan 28, 2021 1:30 am Is anyone else suddenly getting black boxes around their constraints?
As far as I remember,
I got rid of it with some kind of setting in Display - 3D View - Rendering. Anti-aliasing may be.
Do you get this always? Sometimes all red vanishes from a sketch - this happens mostly while selecting - and returns as suddenly as it comes, e.g. by applying a constraint. Werner said it comes from something running out of resources.
If it is always, I would guess it comes from Abdullah's recent highDPI changes.
chennes
Post by chennes »
Elyas wrote: Thu Jan 28, 2021 6:43 am As far as I remember,
Oh, awesome, thanks for the tip. I had been testing a bug report from the other day and left line smoothing on. Switching back to MSAA8x resolved the issue. Line smoothing is an old (and not very good) AA strategy anyway, so I'm not sure it's worth spending time actually fixing this particular glitch.
Chris Hennes
Hologram
Post by Hologram »
chrisb wrote: Tue Jan 05, 2021 11:04 pm Right now I have the feeling I would like to have two independent scale factors, or fontsize plus icon scale. But then I have to admit, that I lived for years with a fixed icon size and I never had changed to fontsize until I got a highdpi display.
It appears a single scale factor ended up being implemented. I am wondering though, is it possible to scale the icons independently from the dimension text? I prefer the icons to be relatively large, because that helps me to identify them better.
Dimension text.png (128.68 KiB) Viewed 631 times
I would need the text to be about half its current size. My font size is 13 in the stylesheet and I am using a 1.5 view scale with a 40px font size here, which obviously is way too large for text, but pretty comfortable for the icons (27 inch 4k Screen set to 175% scaling). It looks like the icons are half the text size, which would explain the discrepancy between the two.
Hologram wrote: Wed Jan 25, 2023 10:56 pm I am wondering though, is it possible to scale the icons independently from the dimension text?
How about to increase the ViewScaleRatio and decrease the font size.
