What is the deal with pivy?
- adrianinsaval
Re: What is the deal with pivy?
Isn't pivy easily installed with pip?
Not sure the pypi package is maintained.
The problem isn't compiling so much as it is running the system.
Sample run...
freecad
FreeCAD 0.21.0, Libs: 0.21.0R31631 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2023
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
Assembly4 workbench (v0.12.5) loaded
Sheet Metal workbench loaded
Interlocking laser cut workbench loaded
During initialization the error "module 'pivy._coin' has no attribute 'delete_SoGeo'" occurred in /home/chris/.local/share/FreeCAD/Mod/kicadStepUpMod/./InitGui.py
Please look into the log file for further information
During initialization the error "module 'pivy._coin' has no attribute 'delete_SoGeo'" occurred in /home/chris/.local/share/FreeCAD/Mod/ExplodedAssembly/InitGui.py
During initialization the error "module 'pivy._coin' has no attribute 'delete_SoGeo'" occurred in /home/chris/.local/share/FreeCAD/Mod/A2plus/./InitGui.py
('Mod/Pyramids_and_polyhedrons', 'Mod/Pyramids-and-Polyhedrons', 'Mod/FreeCAD-Pyramids-and-Polyhedrons', 'Mod/Pyramids-and-polyhedrons')
During initialization the error "module 'pivy._coin' has no attribute 'delete_SoGeo'" occurred in /home/chris/.local/share/FreeCAD/Mod/fasteners/./InitGui.py
During initialization the error "module 'pivy._coin' has no attribute 'delete_SoGeo'" occurred in freecad.asm3
File "<string>", line 217, in InitApplications
File "/usr/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/home/chris/.local/share/FreeCAD/Mod/Assembly3/./freecad/asm3/init_gui.py", line 3, in <module>
from . import gui
File "/usr/lib/python3/dist-packages/shiboken2/files.dir/shibokensupport/__feature__.py", line 142, in _import
File "/home/chris/.local/share/FreeCAD/Mod/Assembly3/./freecad/asm3/gui.py", line 4, in <module>
from pivy import coin
File "/usr/lib/python3/dist-packages/pivy/__init__.py", line 30, in <module>
from .coin import SoDB, SoNodeKit, SoInteraction
File "/usr/lib/python3/dist-packages/pivy/coin.py", line 40397, in <module>
class SoGeo(object):
File "/usr/lib/python3/dist-packages/pivy/coin.py", line 40431, in SoGeo
__swig_destroy__ = _coin.delete_SoGeo
AttributeError: module 'pivy._coin' has no attribute 'delete_SoGeo'
connect failed: No such file or directory
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 0.21.0.31631 (Git)
Build type: Unknown
Hash: ce0391686eef83f538ad2ce3c253f8b2f3b08ee8
Python 3.10.6, Qt 5.15.3, Coin 4.0.1, Vtk 9.1.0, OCC 7.5.1
Installed mods:
* freecad.gears 1.0.0
* BIM 2021.12.0
* CycloidGearBox
* parts_library
* CurvedShapes 1.0.4
* SelectorToolbar
* EM
* Assembly4 0.12.5
* ThreadProfile 1.84.0
* sheetmetal 0.2.60
* 3D_Printing_Tools
* ose-piping
* kicadStepUpMod 10.16.8
* ExplodedAssembly
* A2plus 0.4.60h
* LCInterlocking
* Assembly3 0.11.4
* Design456 0.0.1
* symbols_library
* Help 1.0.3
* lattice2 1.0.0
* FeedsAndSpeeds 0.5.0
* Pyramids-and-Polyhedrons
* fasteners 0.4.53
Working on...
https://github.com/iplayfast/CycloidGearBox
related:
https://forum.freecadweb.org/viewtopic.php?f=4&t=74383
maybe this helps:
https://stackoverflow.com/questions/684 ... ute-delete
are you configuring pivy with setup.py or with cmake?
maybe this helps:
Yup, same bug. I've seen him haunting the same places as melooo wrote: ↑Fri Jan 20, 2023 10:36 pm related:
I think I've tried both. Which should I be using?maybe this helps:
Working on...
Cmake is preferred. But actually both should work.
If I read the link I posted correctly you need to delete the old _coin.so. And run the compilation again. There is also the chance you have multiple _coin.so libraries. Can you post the output of this:
sudo updatedb
locate _coin.so
sudo updatedb
chris@shop:~/github/pivy$ locate _coin.so
/usr/lib/python3/dist-packages/pivy/_coin.so
I checked the date, and it's older than my last setup.py which was last night.
After building with cmake
sudo updatedb
chris@shop:~/github/pivy/build$ locate _coin.so
/home/chris/github/pivy/build/interfaces/_coin.so
Running freecad without recompiling crashes
FreeCAD 0.21.0, Libs: 0.21.0R31635 (Git)
A3 available
FreeCAD: /home/chris/github/freecad-source/src/Mod/Part/Gui/TaskDimension.cpp:1343: static void PartGui::ArcEngine::initClass(): Assertion `SoEngine::getClassTypeId() != SoType::badType()' failed.
/home/chris/bin/freecad: line 2: 240520 Aborted (core dumped) bin/FreeCAD
Trying a clean make now
Made no difference, crash in same place.
Working on...
what does this command reports:
I suspect that you have pivy installed via the package-manager but want to replace it with a self compiled version. The version from the package-manager doesn't have the SoGeo bindings. (it's version 0.6.5)
Some replaced the important files manually, and I guess this worked.
apt list pythoon3-pivy
looo wrote: ↑Sun Jan 22, 2023 9:34 am what does this command reports:
*edit, I just realized the typo, NOT pythoon3 fixed*Code: Select all
apt list python3-pivy
Listing... Done
python3-pivy/jammy,now 0.6.5-1build6 amd64 [installed]
except it didn't.I suspect that you have pivy installed via the package-manager but want to replace it with a self compiled version. The version from the package-manager doesn't have the SoGeo bindings. (it's version 0.6.5)
Working on...
So I've tried using synaptic complete removal of pivy.so and soqt.so, and even went so far as to remove the directories
I then in the pivy/build directory did
and it seemed to install to Installing: /usr/lib/python3/dist-packages/pivy/
On running freecad (after making it)
I've tried recompiling fresh from @realthunder's coin, and fresh from the original coin3d coin.
In every case I'm getting the same crash.
so I'm obviously missing a step here.
I'm sorry to be such a newb, but how would you take a fresh linux install, and install and build freecad from source? I can't seem to do it anymore.
/usr/lib/python3/dist-packages$ sudo rm -rf pivy
cmake ..
make
sudo make install
/home/chris/bin/freecad: line 2: 89991 Aborted (core dumped) bin/FreeCAD
Working on...
