Interesting project: DesignSPHysics fluid simulator
Moderator: oliveroxtoby
thschrader
Re: Interesting project: DesignSPHysics fluid simulator
Post by thschrader »
Hello everyone,
the designsphysics-macro now has the possibility to add inlet/outlet
to the simulation. For instance to simulate the flow around a cylinder.
Coupling with chrono is also possible.
Problem: I have absolutely no idea how to do the setup. There are tricky
submenues. The youtube channel has a lot of examples, but no workflow
how to setup inlet/outlet with designsphysics. Any ideas? Thanks.
https://www.youtube.com/user/DualSPHysics/videos
https://projectchrono.org/
johnwang
Post by johnwang »
thschrader wrote: Mon Sep 10, 2018 4:34 pm Create a new group.
This one is cool.
hfc series CAE workbenches for FreeCAD (hfcNastran95, hfcMystran, hfcFrame3DD, hfcSU2 and more)
thschrader
johnwang wrote: Thu Jun 04, 2020 4:14 am I wrote a Macro to open the folder which contains all the vtk/vtu result files. It adds the group and loads all the results under that group. It's a pity I can't set the display mode and field with program now.
Thanks for the hint.
dualsphysics:
Built in vtk-converter and paraview link for viewing.
FEM:
I use this tool for vtk-conversion (from user mamah)
ccxfrd2vtk.zip
(58.44 KiB) Downloaded 112 times
https://forum.freecadweb.org/viewtopic.php?f=18&t=11664
Copy frd-result in bin/release folder, drag with mouse over exe, conversion starts.
johnwang
Post by johnwang »
Import some surface_xxx.vtk series from your dualsphysics output folder into Freecad.
Use Import with FEM Result vtk option.
Activate the FEM workbench.
Doubleclick on every surface and adjust Mode to „surface with edges“
Create a new group.
Move all surfaces into the group an hide them.
Click on Group in model-tree, run the MovingMesh macro
My macro now can set display Mode and field (default to Surface & pressure). Just run it to open the folder where vtu/vtk files are stored. A Group is created. Then select that group, run the MovingMesh macro to do animation.
hfcImportVTKfolder.FCMacro
(1.13 KiB) Downloaded 117 times
thschrader
@johnwang:
can you try to open the vtk/stl (in zip) with FC?
I get only one point, not the complete scene as in paraview.
vtk_and_stl_files.zip
(519.63 KiB) Downloaded 117 times
johnwang
Post by johnwang »
thschrader wrote: Fri Jun 05, 2020 5:53 am can you try to open the vtk/stl (in zip) with FC?
Do you mean open zip directly without unzip? No.
After unzip, I can open the vtk and the stl one by one. But they are not in the same scale. stl is larger. Maybe the unit is changed, m-->mm? Is there a way to scale down the stl?
thschrader
johnwang wrote: Fri Jun 05, 2020 6:06 am Do you mean open zip directly without unzip? No.
No, dont open zip. Unpack and load vtk/stl.
I use default units (mm) in FC. When exporting the stl and loading with paraview,
the stl is scaled up by a factor of 1000 (paraview uses m as default). You must scale it down
with Filter/transform. When reimporting the stl in FC, I have no scaling-problem.
Which import-filter for vtk do you use in FC?
johnwang
Post by johnwang »
thschrader wrote: Which import-filter for vtk do you use in FC?
Try use the macro i provided. You have to change the Field value from pressure to Vel, or other listed.
How do i scale stl?
thschrader
johnwang wrote: Fri Jun 05, 2020 8:02 am How do i scale stl?
Activate the Mesh-Design wb, ==> Meshes/scale
johnwang
Post by johnwang »
Open stl first
scale 0.001
import VTK
All good.
