(WORKAROUND) Zoom to fit freeze 3d window?
Roy_043
Re: (WORKAROUND) Zoom to fit freeze 3d window?
Post by Roy_043 »
When you use Std_ViewFitAll on an empty model the problem does not occur. A similar solution could be implemented for Std_ViewFitSelection when a point is selected.
thomas-neemann
Post by thomas-neemann »
Roy_043 wrote: Mon May 23, 2022 5:18 pm ... A similar solution could be implemented for Std_ViewFitSelection when a point is selected.
unfortunately that doesn't work for me either. it is not a problem for me. I am currently developing a freecad training course. I run into this problem when doing an exercise. i will use 0.19.3 for this exercise and it will work around the problem
Roy_043
Post by Roy_043 »
My previous post was a suggestion for Yorik.
Post by yorik »
Hmm yes... setting a minimum distance maybe, that might be a good idea indeed
thomas-neemann
the error is still there for me
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.21.31058 (Git) AppImage
Hash: e6c53d8642af36ce7d738ab6058b063ec58e0859
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
jeno
Post by jeno »
thomas-neemann wrote: Wed Nov 23, 2022 5:14 pm the error is still there for me
I was able to reproduce the problem and saved the file at that state.
Unpacked the file and checked the camera settings at the very end of GuiDocument.xml
<Camera settings="OrthographicCamera {&#10;  viewportMapping ADJUST_CAMERA&#10;  position -nan -nan -nan&#10;  orientation 0 0 1  0&#10;  nearDistance 0&#10;  farDistance 0&#10;  aspectRatio 1&#10;  focalDistance 0&#10;  height 0&#10;&#10;}&#10;"/>
Two strange things
  • position is normally three floating point values (x,y,z) but -nan doesn't make any sense to me. Could also not find anything in the Coin-docs
  • nearDistance clipping plane as well as farDistance clipping plane are set to 0. That means there is in fact no visible range for the camera
Please check that in your file and confirm.
cheers
thomas-neemann
jeno wrote: Thu Nov 24, 2022 7:59 am .
thanks for the cooperation. Unfortunately I can't find any file
jeno
Post by jeno »
thomas-neemann wrote: Thu Nov 24, 2022 8:02 am
see wikipage File Format FCStd
cheers
