[Solved]:How to create a convex lens
Hello,I'm working on a new raytracing workbench.
I want to create a concave or convex lens in my workbench.Can I use "Part::" to create in Python code?Or create lenses without using "Part::"?like this, it seems a little difficult
Freecad novice, A Python enthusiast
Re: Question:How to create a convex lens
Concave lens (like in the picture):
you could use Part_Cut between a Cylinder and two Spheres
1. In the Part WB create the primitives (Cylinder and Spheres)
2. Position the Spheres relative to the Cylinder with the desired overlap (probably only by adjusting the Z value of position)
3. Select the Cylinder (object to be kept), hold Ctrl and select one Sphere
4. Click on Part Cut
5. Select the Cut in the TreeView (object to be kept), hold Ctrl and select the second Sphere
6. Click on Part Cut
Convex lens:
you could use Part_Common between two overlapping Spheres:
1. In the Part WB create the primitives (Spheres)
2. Position the Spheres relative to eachother with the desired overlap (probably only by adjusting the Z value of position)
3. Select both Spheres by holding Ctrl
4. Click on Part Common
Kind regards,
Johannes
EDIT: Complemented answer with instructions for Convex lens due to confusion between the provided picture and the title of the post.
Convex lens:
Kind regards,
Johannes
Last edited by thyssentishman on Fri Jul 01, 2022 8:19 am, edited 1 time in total.
Maybe there is a lens code in optics workbench
https://forum.freecad.org/viewtopic.php ... 0a16fd3123
Thank you for your reply.This is a very detailed way on how to create a Lens in a Part,this is very useful. But I am sorry that I did not describe the problem clearly.thyssentishman wrote: ↑Fri Jul 01, 2022 8:07 am Hi,
I want to do this in Python code, not in the Part workbench.
Thank you for your reply.This helped me a lotjohnwang wrote: ↑Fri Jul 01, 2022 8:09 am Maybe there is a lens code in optics workbench
Makes sense, after all you posted in Python scripting and macros. My bad sorry.
You can do exactly the same that I explained in my previous reply in a script. Check out Part_API for creating the primitives and TopoShape_API for the boolean operations.
Make sure to import the Part library on your script.
Hope this helps.
Kind regards,
Johannes
This is a very good suggestion and well worth a try.thyssentishman wrote: ↑Fri Jul 01, 2022 9:23 amYou can do exactly the same that I explained in my previous reply in a script. Check out Part_API for creating the primitives and TopoShape_API for the boolean operations.
Check out these quick examples I made:
Concave Lens:
Convex Lens:
Kind regards,
Johannes
Concave Lens:
import FreeCAD
import Part
doc = FreeCAD.newDocument()
def makeConcaveLens():
cylinder = Part.makeCylinder(5,10)
sphere1 = Part.makeSphere(5)
sphere2 = Part.makeSphere(5)
sphere2.Placement = FreeCAD.Placement(App.Vector(0.0000,0.0000,10.0000),App.Rotation(App.Vector(0.0000,0.0000,1.0000),0.0000))
cut1 = cylinder.cut(sphere1)
cut2 = cut1.cut(sphere2)
return cut2
concaveLens = doc.addObject("Part::Feature", "Concave Lens")
concaveLens.Shape = makeConcaveLens()
doc.recompute()
import FreeCAD
import Part
def makeConvexLens():
sphere2.Placement = FreeCAD.Placement(App.Vector(0.0000,0.0000,5.0000),App.Rotation(App.Vector(0.0000,0.0000,1.0000),0.0000))
intersection = sphere1.common(sphere2)
return intersection
convexLens = doc.addObject("Part::Feature", "Convex Lens")
convexLens.Shape = makeConvexLens()
doc.recompute()
Johannes
Thanks, your code is very useful.I try to implement the function of modifying the curvature in ComboView-Datathyssentishman wrote: ↑Fri Jul 01, 2022 9:40 am Check out these quick examples I made:
Kind regards,
Johannes
convexLens.addProperty("App::PropertyFloat", "curv", "Shape", "central curvature")
No problem glad I could help. If there is nothing else you need, please make sure to mark the topic as solved by editing the title of your first post and prepending [Solved].
Good luck!
Kind regards,
Johannes
