Realthunder's Link branch Snap packages
This subforum is specifically to discuss packaging issues on different platforms (windows, mac, linux), and using different packaging systems (conda, etc...)
bambuko
Re: Realthunder's Link branch Snap packages
Post by bambuko »
ppd wrote: Tue May 24, 2022 8:59 am ...I only tried with the official freecad snap and standard Nautilus in Ubuntu 22.04, and my file opened just fine...
Thank you!
I am downloading official FreeCAD snap to compare with Link branch
Will report back.
bambuko
Post by bambuko »
@ppd
As promised:
I have tested it with official main branch snap and (as you have said) it all works fine.
So my issue is Link branch snap specific :oops:
ppd
Post by ppd »
@bambuko That's a great result. Now we have to compare both desktop files to find the culprit! If you're feeling extra helpful today, you can file an issue in realthunder's repo.
Try FreeCAD from the Snap Store: Stable releases (in latest/stable) & daily builds (in latest/edge). Supports installing additional python packages via pip!
bambuko
Post by bambuko »
ppd wrote: Tue May 24, 2022 9:49 am @bambuko That's a great result. Now we have to compare both desktop files to find the culprit! If you're feeling extra helpful today, you can file an issue in realthunder's repo.
problem solved ;)
%F is missing from link branch .desktop file
Modifying it solves the issue
Issue on github:
https://github.com/realthunder/FreeCAD/ ... 1246368929
bambuko
Post by bambuko »
@ppd
sorry if it is a wrong place?
latest snap update looses icon because .desktop file points at .svg whereas the location it points to, only has .png :oops:
Should I mention it to @realthunder or you?
ppd
Post by ppd »
@bambuko
So you're saying freecad-realthunder revision 34 (see snap info freecad-realthunder) does not have
/snap/freecad-realthunder/current/usr/share/icons/hicolor/scalable/apps/freecad_link.svg
The desktop file references this icon:
/var/lib/snapd/desktop/applications$ cat freecad-realthunder_freecad-realthunder.desktop
[Desktop Entry]
X-SnapInstanceName=freecad-realthunder
Version=1.0
Name=FreeCAD Link Branch
Exec=env BAMF_DESKTOP_FILE_HINT=/var/lib/snapd/desktop/applications/freecad-realthunder_freecad-realthunder.desktop /snap/bin/freecad-realthunder
Icon=/snap/freecad-realthunder/34/usr/share/icons/hicolor/scalable/apps/freecad_link.svg
Type=Application
Categories=Engineering;
Comment=Feature based Parametric Modeler
Terminal=false
StartupNotify=true
NoDisplay=false
MimeType=application/x-extension-fcstd;
As you can see, I can't reproduce the issue. Or am I misunderstanding you?
bambuko
Post by bambuko »
sorry @ppd guess I am getting muddled again:
Screenshot from 2022-05-25 11.20.55.png (13.6 KiB) Viewed 384 times
and:
Screenshot from 2022-05-25 11.17.09.png (63.93 KiB) Viewed 384 times
my previous message about .png ve .svg was wrong
I am still with no icon though :oops:
later edit:
forget it - sorry
it is all OK now ... don't know what was going on :oops: :roll:
ppd
Post by ppd »
bambuko wrote: Wed May 25, 2022 10:23 am it is all OK now ... don't know what was going on :oops: :roll:
Maybe the snap was updated in the background and your manually copied desktop file pointed to a now outdated icon path.
Try replacing the revision number in your local desktop file with "current", i.e. Icon=/snap/freecad-realthunder/current/usr/share/icons/hicolor/scalable/apps/freecad_link.svg
bambuko
Post by bambuko »
ppd wrote: Wed May 25, 2022 12:03 pm ...Try replacing the revision number in your local desktop file with "current", i.e. Icon=/snap/freecad-realthunder/current/usr/share/icons/hicolor/scalable/apps/freecad_link.svg
Yes, I guess that is what has solved the problem ;)
Thank you again for your help and patience!
bambuko
Post by bambuko »
ppd wrote: Wed May 25, 2022 12:03 pm Maybe the snap was updated in the background and your manually copied desktop file pointed to a now outdated icon path.
No, it is not that :mrgreen:
worked it out today (because the same has happened with master snap) :ugeek:
What actually seem to be happening is that every time snap is updated one critical address is changed.
It doesn't matter if one uses .desktop from snap, but because I am using copied/modified version, this address doesn't get updated... :oops: :(
Icon=/snap/freecad/40/usr/share/icons/hicolor/scalable/apps/org.freecadweb.FreeCAD.svg
40 is the thing that keeps changing as you update snap (this number differs for different snaps)
Now I know it is relatively simple matter to keep it updated manually, but.... there must be a better way?
