New ProDark Theme with 4k small text Mod
turn211
Re: New ProDark Theme with 4k small text Mod
Post by turn211 »
adrianinsaval wrote: Wed May 18, 2022 4:39 pm
turn211 wrote: Wed May 18, 2022 12:19 am Your wish has been granted. :lol: Get the latest a https://github.com/turn211/ProDark-FreeCAD-theme Preference Pack coming soon Tool Library Bliss.png
Could you PR that into the main repo? @uwestoehr can we get this merged before release? the theme is broken right now and merging it can't break anything else
Done. https://github.com/FreeCAD/FreeCAD/pull/6905
MisterMaker
Post by MisterMaker »
Does someone here knows if you can use this theme file to remove the text field in the workbench toolbar? I am trying to convert the workbench toolbar to tabs but it ads an empty space after each icon which seems to be an empty text field.
with text:
Seems like original icons also have a gap although it is smaller so I'm not sure what is going on:
adrianinsaval
Post by adrianinsaval »
are you using selector toolbar addon or what? or is it a linkbranch feature?
MisterMaker
adrianinsaval wrote: Thu May 19, 2022 11:53 am are you using selector toolbar addon or what? or is it a linkbranch feature?
You can replace icons in linkstage, true the icon themes folder or this theme.
Click 'Save' button to save the content here to create your own icon set. Or, you
can manually copy the content and append to your existing icon set configuration.
Note, tree view, toolbar, and workbench tab bar support non-square icons. The
size can be specified by adding an extra field as follow. Only SVG icon requires
explicit setting of dimention.
TreeItemInvisible, iconset:MyIcons/TreeItemInvisible.svg, 128x64
and
To override application icons, you can save the above configurations into your
application user directory Gui/IconSets/. You can then select your icons set in
Preference -> General -> Icon set.
For stylesheet authors, you can also override icons through Gui::MainWindow
property 'overrideIcons' as shown below. Please note that the icon settings in
the stylesheet takes precedence over icon set configurations.
Gui--MainWindow {
qproperty-overrideIcons : url(
TreeItemVisible, iconset:MyIcons/TreeItemVisible.svg
size can be specified as follow,
I looked a bit more at it and I am pretty sure it is the text padding that is the cause. Wonder if I can change it?
adrianinsaval
I was asking about the workbench tabs rather than the icon override, is it selector toolbar addon or are you doing something else?
MisterMaker
adrianinsaval wrote: Thu May 19, 2022 12:24 pm I was asking about the workbench tabs rather than the icon override, is it selector toolbar addon or are you doing something else?
It's the standard workbench toolbar the tabs including text are workbench icons replaced with custom png file. Not the best too as an image as text but it's super versatile, can make all kind of fancy stuff with an image that you cannot do with plain text.
As far as I see it is called Std_workbench
Simbioz
Post by Simbioz »
The text in the blue letters is barely visible on my screen (I have to be directly in front and pretty close to see it). I think those are expressions referencing values on the spreadsheet. Where in the .qss file do I have to edit to change it's color? Thanks.
I have the latest git version btw.
Non native English speaker.
MisterMaker
I think I fixed that in mine version:
https://github.com/MisterMakerNL/ExtremeProDark
It's probably highlight thingy in the tree section.
Simbioz
Post by Simbioz »
MisterMaker wrote: Sat Jul 02, 2022 5:31 am I think I fixed that in mine version:
Thanks I will check it out.
psommerfeld
Post by psommerfeld »
I don't understand what happened to the ProDark theme in my install. The drawing area is now a white background and sketches are hard to see. How can I revert to the correct ProDark coloring scheme?
Screen Shot 2022-08-21 at 10.05.30 AM.png (447.07 KiB) Viewed 1584 times
