Convert my sketch to a "real" drawing
Hi Forum Friends!
I have a sketch of a keychain canister that I need help with converting to a standard CAD drawaing, is anyone interested? I'm willing to pay for the help I just don't know how much $ it will take?
Thanks
John
Thanks
John
- Keychain Canister 60 X 25.png (68.96 KiB) Viewed 3601 times
Re: Convert my sketch to a "real" drawing
Would this also be possible as a community project and you donate to the project?
I'm new to the site, not really sure what a "community project" is? However, if I ultimately end up with a CAD drawing, sure I'll donate? How do you determine how much the donation amount will be?
Thanks
John
Thanks
John
A community would mean that forum members do the work together. For that it would of course be necessary that you make all necessary informations public.
We have done this before and we didn't have a fixed rate for the donation. In the end it could be seen as part for the work and part for the program.
2 files because I can't join file larger than 1MB.
Designed with FreeCad v0.20 (27809) EDIT : V2 ; I made some dimensional corrections
- Porte-clef-bottomV2.FCStd
- (423.28 KiB) Downloaded 72 times
- Porte-clef-topV2.FCStd
- (731.72 KiB) Downloaded 68 times
Wow! Grub, that was fast work. What do I owe you?
BTW: I was able to view the files in FreCAD 0.19, dowloaded the app last week (WIN 10), just starting the learning process
Thanks
John
Thanks
John
What is the purpose of that 1mm lip?
Hi Grub,
One last favor to ask (or clarification?), when viewing the files it looks llike the "top seal" is a seaparate part from the canister body, it should all be one part. I beleive the mixup is due to my sketch, where I was attempting to emphasize the 14mm x 1mm hole/lip on the canister top?
The bottom seal should not be included, bottom cap is basically an extension to the canister's 18mm ID chamber.
If you can help me with this I'll send you a case of virtual beers
I will be donating to this site in your name.
Thanks
John
Thanks
John
- bottom_seal.png (64.16 KiB) Viewed 3206 times
- top_seal.png (98.78 KiB) Viewed 3206 times
Hi kisolre,
The 1mm lip is to hold in place a piece of circular semi-rigid foam.
Thanks
John
Thanks
John
