- We keep just the Plot module here (i.e. freecad.plot.Plot), and get the workbench (the tools to manipulate those plots) in its own repo (https://github.com/FreeCAD/freecad.plot)
- We get everything (module and workbench) shipped here and remove Plot from the Addon Manager
What to do with Plot
I really though Plot was not used anymore in the core, but I was totally wrong (see https://github.com/FreeCAD/FreeCAD/pull ... -868694008). Thus, removing Plot is not the solution. There are at least 2 options:
Re: What to do with Plot
I have no GitHub account, so i write it here.
I never compiled FreeCAD with Plot. So i did a little test run with Plot. When i start the Shaft Wizard, he starts normal. But it seems that is broken anyway. I get an ton of errors, sometimes adding a column did not work. The forces were sometimes on the false shaft element, ...... . But the most important thing was, that i did not create a PartDesign Body/Object.
And the feature itself was broken.
And on the top, when tried to plot something (with compiled PlotWorkbench), i get the message to install the Plot addon.
So i would wipe the Shaft Wizard it from PartDesign also. Also the Shaft Wizard uses FEM constraints without a FEM Analysis Container, which is useless. And a analysis tool has nothing to do in PartDesign. This things should always be separated.
And also one generally technical thing: I never used the Shaft Wizard, so i can only guess, if the things below are included.
I guess the plot only makes a F(x), M(x), ..... means forces and so on from a running x. I you do that on discontinuous (and also relative discontinuous) elements, then you must include factors for notch effects, roughness of surfaces, size, application, ....... . If this is not included the calculation is invalid (often extremely). And If you do not know that and see, ahhh that result is OK (sigma is OK), then it could be dangerous! So my conclusion is that if you want do make a shaft, you should do it with normal FreeCAD workbenches and if you want to analyze it, you should do it yourself or with FEM. And if anyone is familiar with FreeCAD, you can use later the Wizard with the addon anyway (if it works).
Greetings
user1234
<PartDesignGui> Utils.cpp(73): no body found
Greetings
user1234
