[ Architecture Masterpiece ] Villa Savoye FC Model
Hi, I have been modelling this building testing some of the features added. Would somehow stop here without further detailing every part of the building, hope someone would like to refine it
Villa Savoye - FC Model
Link to FC Model
[ EDIT ]
To view model nothing more is required.
To edit the model, needs below :
- latest commit with ArchWall OverrideAlign / OverrideWidth
- ArchSketchObject.py to work properly ATM.
https://github.com/paullee0/FreeCAD_SketchArch
Just copy the whole folder into your installation .../src/Mod/... and restart FC.
Link to FC Model
[ EDIT ]
- Screenshot from 2020-01-31 02-20-47.png (222.73 KiB) Viewed 10933 times
- Screenshot from 2020-01-31 02-21-13.png (194.96 KiB) Viewed 10933 times
- Screenshot from 2020-01-31 02-21-29.png (229.95 KiB) Viewed 10933 times
- Screenshot from 2020-01-31 02-21-41.png (228.8 KiB) Viewed 10933 times
- Screenshot from 2020-01-31 02-21-47.png (225.43 KiB) Viewed 10933 times
Re: [ Architecture Masterpiece ] Villa Savoye FC Model
More Screenshots
- Screenshot from 2020-01-31 02-21-52.png (236.28 KiB) Viewed 10931 times
- Screenshot from 2020-01-31 02-22-09.png (236.32 KiB) Viewed 10931 times
- Screenshot from 2020-01-31 02-22-12.png (231.15 KiB) Viewed 10931 times
- Screenshot from 2020-01-31 02-33-50.png (400.91 KiB) Viewed 10931 times
- Screenshot from 2020-01-31 02-35-33.png (216.28 KiB) Viewed 10931 times
Nice model. Well done.
Not sure, but probably this is one of the best high quality 3D model of this building (parametric, bim and all that) available by free.
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Thanks, there are hundreds / thousands of features /details that dxf drawing are not available on internet, but noticeable on photos, that is too tedious to 'visual' measure all and detail in the model.
So, a closer look, you will find it does not match photos , especially for those who like designing details
And seems LoD is an issue yet to have an easy solution ?
Just add more screenshots
version: FreeCAD_0.19.19510_x64_LP_12.1.2_PY3QT5-WinVS2015
1. importing file "Villa Savoye_GF_1F_2F.ifc" failed
Report view:
No IfcProject found in the ifc file. Nothing imported
Console view:
>>> import importIFC
>>> importIFC.insert(u"E:/Downloads/ready/Villa Savoye_GF_1F_2F.ifc","Unnamed")
>>> Gui.SendMsgToActiveView("ViewFit")
>>> ### End command Std_Import
<string>(1)<class 'ModuleNotFoundError'>: No module named 'ArchSketchObject'
Thank you, paulee.
Somehow when I model it up to some point, the ifc file still good opened in IFC++ / BIMServer, but FC no longer open/importing but crashesfc_tofu wrote: ↑Sat Feb 08, 2020 6:18 pm version: FreeCAD_0.19.19510_x64_LP_12.1.2_PY3QT5-WinVS2015
1. importing file "Villa Savoye_GF_1F_2F.ifc" failedCode: Select all
Report view: No IfcProject found in the ifc file. Nothing imported Console view: >>> import importIFC >>> importIFC.insert(u"E:/Downloads/ready/Villa Savoye_GF_1F_2F.ifc","Unnamed") >>> Gui.SendMsgToActiveView("ViewFit") >>> ### End command Std_Import
I haven't had time to post this in IFC/Draft, Arch & BIM sub-forum, maybe you can help? Or even in Mantis BugTracker ?
My fault, I have indicated in the Arch & BIM forum about this but not this. This is an experimental module (I just start learning Python a few months ago .fc_tofu wrote: ↑Sat Feb 08, 2020 6:18 pm 2. can open file "Villa Savoye.FCStd" but prompt lots of error msgsCode: Select all
<string>(1)<class 'ModuleNotFoundError'>: No module named 'ArchSketchObject' ...
No need to have it just opening the file, but if you want to edit some Sketch which you found is named ArchSketch0XX, you need it. And there is a few unfinished rudimentary GUI tools.
I used Linux Fedora + Appimage .... there are some bugs, not known it is related to your problem.
- I select BldgPart_GF, BldgPart_1F, BldgPart_GF and exporting is ok.
- Seem if i select Building to export, there is nothing (in IFC++, or BIMServer?)...?
