IFC Viewer ifcplusplus
Re: IFC Viewer ifcplusplus
Post by bernd »
mhh me neither ... On Debian Buster it runs smooth ...
Post by bernd »
I haven never ever used fedora but I may give it a try on a fedora VM. What packages did you install to compile Ifc++ Do you know how to install them in a bash?
paullee
Post by paullee »
I figured out and was successful in compiling e.g. in Fedora 27, packages installed are recorded in earlier post, e.g.
https://forum.freecadweb.org/viewtopic. ... 50#p231732
I remember reading some documents on your repo and/or IFC++ website, something like...
cmake ../
make
make install
Post by bernd »
no error here ...
try this script ... https://gist.github.com/berndhahnebach/ ... f897676be1
paullee
Post by paullee »
Thanks for the script :)
Running and building again ... seems no much difference in the script, just it use git rather than me downloading the zip.
Hope it builds.
[EDIT]
It works ! Thanks!
Screenshot from 2019-10-12 07-42-15.png (711.96 KiB) Viewed 2477 times
Post by bernd »
great!
Post by bernd »
rebased my branch to latest ifcplusplus. Had to add some imports to get it compiled.
https://github.com/berndhahnebach/ifcpl ... its/master
Post by bernd »
rebased my branch to latest ifcplusplus. Head compiles on Debian Buster :D
https://github.com/ifcquery/ifcplusplus/commits/master
twohot
Post by twohot »
bernd wrote: Mon Jan 13, 2020 10:50 am rebased my branch to latest ifcplusplus. Head compiles on Debian Buster :D
Resurrecting this thread.
I needed to look at some IFC files while in Linux (Fedora Rawhide) so I tried to complie IfcPlusPlus.
Required Packages (deduced from errors during compilation):
cmake
qt5-qtbase-devel
OpenSceneGraph-devel
Here is my mileage:
$ make -j$(nproc --ignore=2)
Consolidate compiler generated dependencies of target carve
[  3%] Built target carve
Consolidate compiler generated dependencies of target IfcPlusPlus
[  3%] Building CXX object IfcPlusPlus/CMakeFiles/IfcPlusPlus.dir/src/ifcpp/reader/ReaderUtil.cpp.o
[  3%] Building CXX object IfcPlusPlus/CMakeFiles/IfcPlusPlus.dir/src/ifcpp/reader/ReaderSTEP.cpp.o
In file included from /home/oss/bim/ifcplusplus-git/ifcplusplus/IfcPlusPlus/src/ifcpp/reader/ReaderSTEP.cpp:45:
/home/oss/bim/ifcplusplus-git/ifcplusplus/IfcPlusPlus/src/ifcpp/reader/ReaderUtil.h: In function ‘void readIntegerValue(const std::wstring&, int&)’:
/home/oss/bim/ifcplusplus-git/ifcplusplus/IfcPlusPlus/src/ifcpp/reader/ReaderUtil.h:70:34: error: ‘numeric_limits’ is not a member of ‘std’
   70 |                 int_value = std::numeric_limits<int>::quiet_NaN();
/home/oss/bim/ifcplusplus-git/ifcplusplus/IfcPlusPlus/src/ifcpp/reader/ReaderUtil.h:70:49: error: expected primary-expression before ‘int’
/home/oss/bim/ifcplusplus-git/ifcplusplus/IfcPlusPlus/src/ifcpp/reader/ReaderUtil.h:74:34: error: ‘numeric_limits’ is not a member of ‘std’
   74 |                 int_value = std::numeric_limits<int>::quiet_NaN();
/home/oss/bim/ifcplusplus-git/ifcplusplus/IfcPlusPlus/src/ifcpp/reader/ReaderUtil.h:74:49: error: expected primary-expression before ‘int’
Any idea how to get this to work?
Post by yorik »
Std::numeric_limits, which your error says is undefined, is defined in a "limits.h" header according to https://en.cppreference.com/w/cpp/types/numeric_limits
I would check if 1) the erroring file has #include <limits> in it (on some systems (windows) it's not required to #include std headers, so it's not uncommon these lines are missing), and 2) there is a "limits.h" file installed by some package in usual places (/usr/include for ex). i'm not familiar with fedora, but your package manager should be able to tell which package you need to get that file
