Dimensioning of a Revolve
gsandy
Post by gsandy »
Is there any way of adding a drawing page that shows dimensions of a revolve?
In the attached I can add a page and dimensions of the simple cube but not the revolve.
OS: Windows 7
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: English/NewZealand (en_NZ)
Temp.FCStd
(49.54 KiB) Downloaded 46 times
vocx
Re: Dimensioning of a Revolve
Post by vocx »
gsandy wrote: Mon Sep 09, 2019 7:37 pm Is there any way of adding a drawing page ...
Do not use the Drawing Workbench because it is obsolete. Use the TechDraw Workbench.
gsandy
Post by gsandy »
Thanks vocx, I didn't know it was obsolete.
Tried the TechDraw WB and same thing happened, the cube was OK but the "Bullet" would not work!
wandererfan
Post by wandererfan »
gsandy wrote: Mon Sep 09, 2019 7:37 pm Is there any way of adding a drawing page that shows dimensions of a revolve?
I'm going to guess that this is an OCC problem. The parallel and perspective HLR/Projection algos don't fail, but they don't return any edges either. The Coarse algo (polygon approximation) produces a reasonable result, but of course that is useless for dimensioning.
We'll have to check the shape brep with the OCC DRAW program.
Temp_noDraw_TD.brep
(191.6 KiB) Downloaded 23 times
gsandy
Post by gsandy »
Thanks for looking into this Wandererfan.
That's rather surprising, because I get a reasonable result - despite showing an error GO::projectShape - OCC error - - while projecting shape.
Snip macro screenshot-ff80d9.png (22.72 KiB) Viewed 1893 times
OS: macOS High Sierra (10.13)
Version: 0.19.18095 (Git)
Hash: 27cb54009b57c1938f7ff97026c8b35c1688233f
Python version: 3.7.3
Qt version: 5.12.1
gsandy
Post by gsandy »
Chrisb did you use "The Coarse algo (polygon approximation)" to get what you got? And how do you do that?
I replaced the B Spline with an Arc and got a page that I could dimension!
freedman
Post by freedman »
When dimensioning a revolve that was created with an arc; Sometimes in the drawing the sketch side will dimension as an arc and the revolved side can show as a b-spline and I can't get a dimension on it. It's obvious to me that OCC probably recognizes the arc on one side but the revolved side has no hard geometry lines so it just defaults to a b-spline.
gsandy
Post by gsandy »
Great tip Freedman, hadn't come across that yet but no doubt I would have as my drawing progressed.
wandererfan
gsandy wrote: Tue Sep 10, 2019 3:37 am Chrisb did you use "The Coarse algo (polygon approximation)" to get what you got? And how do you do that?
The first entry in the HLR Parameters section of the PropertyEditor data tab for the View.
