Bring branch up to date with master changes.
Re: Bring branch up to date with master changes.
recently triplus helped me out with the git stuff: https://forum.freecadweb.org/viewtopic. ... 10#p195546. However, I didn't succeed.
In the first go I checked out to my existing local repository, made my changes, added them and succeeded finally to make a commit. When I tried to create a pull request the changed stuff had gone.
So I went the triplus way:
I moved my local repository because it was called "FreeCAD" as well.
Then I continued with the git commands:
triplus wrote: Sat Oct 14, 2017 10:33 pm
git clone https://github.com/YOUR-USERNAME/FreeCAD
cd FreeCAD
git remote add upstream https://github.com/FreeCAD/FreeCAD.git
git fetch upstream
git checkout master
git merge upstream/master
git push
When I came to
git checkout master
I get the followng error message:
FreeCAD$ git checkout master
error: The following untracked working tree files would be overwritten by checkout:
	.arcconfig
	.gitattributes
	.github/PULL_REQUEST_TEMPLATE.md
	.gitignore
	.log_errors
	.subuser.json
	.travis.yml
	BuildAll.bat
	BuildRelease.ini
	BuildRelease.py
	CMakeLists.txt
	COPYING
	ChangeLog.txt
	LibraryVersions.h.cmake
	README.md
	appveyor.yml
	cMake/ConfigureChecks.cmake
	cMake/FindCoin3D.cmake
	cMake/FindCoin3DDoc.cmake
	cMake/FindEigen2.cmake
	cMake/FindEigen3.cmake
	cMake/FindKDL.cmake
	cMake/FindMEDFile.cmake
	cMake/FindMatplotlib.cmake
	cMake/FindNETGEN.cmake
	cMake/FindOpenCV.cmake
	cMake/FindOpenCasCade.cmake
	cMake/FindPyCXX.cmake
	cMake/FindPySide2Tools.cmake
	cMake/FindPySideTools.cmake
	cMake/FindRift.cmake
	cMake/FindSMESH.cmake
	cMake/FindSpnav.cmake
	cMake/FindWix.cmake
	cMake/FindXercesC.cmake
	cMake/FreeCadMacros.cmake
	cMake/UseLibPack10x.cmake
	cMake/UseLibPack6x.cmake
	cMake/UseLibPack7x.cmake
	cMake/UseLibPack8x.cmake
	cMake/UseLibPack9x.cmake
	cMake/UseLibPackCLbundler.cmake
	cMake/UseLibPackCustom.cmake
	config.h.cmake
	data/CMakeLists.txt
	data/License.txt
	data/examples/ArchDetail.FCStd
	data/examples/CMakeLists.txt
	data/examples/DrawingExample.FCStd
	data/examples/EngineBlock.FCStd
	data/examples/Fem.FCStd
	data/examples/Fem2.FCStd
	data/examples/FemCalculixCantilever2D.FCStd
	data/examples/FemCalculixCantilever3D.FCStd
	data/examples/PartDesignExample.FCStd
	data/examples/RobotExample.FCStd
	data/examples/Schenkel.stp
	data/tests/Crank.fcstd
	data/tests/Crank.py
	data/tests/Jt/Engine/2_Cylinder_Engine.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Cam_shaft_123_457_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Case_r_123_200_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Cylinder_1_123_100_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Cylinder_2_123_101_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Head_1_123_150_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Head_2_123_151_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Head_Nut_123_005_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Head_Stud_123_006_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Lifter_123_923_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Piston_123_844_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Piston_pin_123_845_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Rocker_Arm_123_600_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Rocker_Arm_Shaft_123_601_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Rocker_Arm_copy_123_602_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Rocker_Bolt_123_603_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Rocker_Mount_123_604_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Rocker_Mount_Cap_123_608_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Spark_Plug__0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Spring_Link__0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Valve_123_700_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Valve_Cover_123_701_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Valve_Cover_copy__0_Main.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Valve_Spring_123_702_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/Valve_Spring_Cap_123_704_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/cam_gear_123_456_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/crank_123_782_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/crank_gear_123_783_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/cylinder_bolt_pattern__0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine/rod_123_699_0_Parts.jt
	data/tests/Jt/Engine/2_Cylinder_Engine1_Internals.plmxml
	data/tests/Jt/Engine/2_Cylinder_Engine2_Externals.plmxml
	data/tests/Jt/Engine/2_Cylinder_Engine3.plmxml
	data/tests/Jt/Engine/2_Cylinder_Engine3.xml
	data/tests/Jt/Engine/2_Cylinder_Engine3_Exploded.plmxml
	data/tests/ModelRefineTests/Y_Rod_Mount.brep
	data/tests/ModelRefineTests/ZMotorMountscripted.brep
	data/tests/ModelRefineTests/aox.brep
	data/tests/ModelRefineTests/blocks144.brep
	data/tests/ModelRefineTests/cylinder1.brep
	data/tests/ModelRefineTests/cylinder3.brep
	data/tests
Aborting
cb@ubuntu:/maccb/Users/cb/FreeCAD$ git checkout masterB
This is what I don't understand:
- I downloaded these files seconds before from the repository and now they seem to be unversioned.
- in the commands you gave: is "upstream" a git keyword or a self selected identifier (like YOUR-USERNAME)
I am willing to delete all my git repositories if there is a chance to do the following:
  • Initialize
    I need to check out a FreeCAD to my local computer.
  • Contribute
    I want to make the following steps repeatedly:
    • Sync my local repository with the official FreeCAD repository
    • Make my changes
    • Create a pull request, so others can verify and commit them to the official repository
There may be additional steps in between, but I don't think that my desired workflow is too exotic.
I really want to contribute to FreeCAD, albeit small things for now, and I have some minor things in the pipeline. But this git stuff is completely pushing me off. I don't want to invest hours and hours in a pull request, if the change has taken only two or three, bug tracking included. mlampert helped me the first time I tried - finally successful - but I didn't succeed with the set of commands I have recorded.
I tried the procedure from https://forum.freecadweb.org/viewtopic. ... 21#p180425 as well, but I get the same error as before.
So please can anyone give me a set of git commands for the tasks mentioned above.
Post by Kunda1 »
An aside: if anyone still has issues with CLI git, I use a GUI called gitkraken:
Developing FreeCAD with GitKraken
looo
Post by looo »
I don't know what the most efficient work-flow with git is. My suggestion is to use the workflow that works best for you...
Mine looks like this:
setup:
1. have a fork on github
2. have the fork locally cloned (git clone <path_to_fork>)
3. set up the upstream repository (git remote add freecad https://github.com/FreeCAD/FreeCAD)
update your fork:
1. update remote (git fetch freecad)
2. rebase your branch on the freecad master (git rebase freecad/master)
(3.) if not successfully use mergetool (kdiff3) to resolve the mergeproblems and (git rebase --continue / git rebase --abort)
4. push to origin (git push origin +master) [don't do this if others are working on your fork, I think the alternative is using merge instead of rebase, but this creates additional commit messages]
contribute:
1. make changes to your master
2. commit changes (git commit -a / git commit <files> / git commit -a --amend)
3. push changes (git push)
try out a branch from someone else:
1. add remote: (git remote add other https://github.com/<other_fc_repo>)
2. load the branch: (git fetch other)
3. checkout other branch: (git checkout other/<branch>)
(4.) if you want to make changes to a copy of other/<branch>:
git checkout -b copy_of_other_branch
git reset other/<branch> --hard
add commit from any other branch (remote or local):
1. git checkout <branch_to_copy_commit_from>
2. find commit (git log) [you can also use github to browse the commits]
3. copy the commit-hash (long number in the first line after "commit")
4. git checkout <branch_to_copy_commit_to>
5. git cherry-pick <commit-hash>
(6.) eventually use mergetool and (git cherry-pick --continue) to resolve merge conflicts
other stuff sometimes useful:
- remove all added diff (git stash)
- change commit-order/ gather some commits/ change commit-messages: (git rebase -i HEAD~3 / git rebase -i <commit-hash>)
- diff to file: git diff <branch> <file/directory> >file.patch
but maybe using a gui-tool is the easier alternative...
:D
wandererfan
Post by wandererfan »
chrisb wrote: Sat Oct 28, 2017 12:59 pm So please can anyone give me a set of git commands for the tasks mentioned above.
This is how I do it.
Setup gitHub:
  navigate to "FreeCAD/FreeCAD"
  "fork" FreeCAD/FreeCAD to your account(myGitHubID)
Setup local repo:
  mkdir FreeCAD-src
  cd FreeCAD-src
  git clone https://github.com/myGitHubId/FreeCAD.git .
Develop:
  *git branch newBranchName
  *git checkout newBranchName
  code, commit, code, commit, ....
Catch up my newBranch with upstream/master (the "real" master):
  *git checkout master
  *git fetch upstream
  *git merge upstream/master
  git rebase master
Send my changes to my github:
  git push origin                //* send my local newBranchName to my gitHub
Make a PR:
  in github,
  navigate to FreeCAD/FreeCAD
  "you recently pushed to your github fork, do you want to make a PR y/n?"
  fill in PR form, press create.
  wait for Appveyor/Travis to run
  wait for Admin to merge to master
Get ready for next Development phase:
  *git fetch upstream
  *git branch anotherBranch
  *git checkout another Branch
*git => steps where I use git-gui
I don't know if git gurus would approve, but it seems to work for me.
wf
triplus
Post by triplus »
chrisb wrote: Sat Oct 28, 2017 12:59 pm This is what I don't understand:
Just to make sure you did replace the YOUR-USERNAME with your actual GitHub user name (and you did create a fork of FreeCAD on your GitHub)? Therefore the first line would look something like:
git clone https://github.com/chrisb/FreeCAD
If your GitHub user name would be chrisb and you have created a FreeCAD fork (on GitHub). Follow the procedure again but this time replace the first two lines from the original instructions with:
git clone https://github.com/YOUR-USERNAME/FreeCAD TestFC
cd TestFC
P.S. Does this get you any further? If not please share a link to your GitHub account.
Thanks for the help, there are several possibilities I can try. I will do so tomorrow, it's late here now.
My git user is PLChris, and these are the commands I tried:
git clone https://github.com/PLChris/FreeCAD
cd FreeCAD
git fetch upstream
git checkout master
I like the possibility of
because I had troubles that everything is called FreeCAD: The official master, the clone on https://github.com/PLChris/ and my local copy. Perhaps this will help.
Do I have to go to my git website prior to these commands and perform some action to get it in sync with the official master?
With slight modifications I managed to create a pull request. I will veryfy the procedure with my next pull request and report back.
I have already a preliminary observation: The procedure I performed from getting a new local copy until creating the pull request has resulted in a pull request containiing two commits, one of them being empty.
triplus
Post by triplus »
Good to hear that and happy hacking!
Thanks to all who helped with special thanks to wmayer (in the german forum) and wandererfan. I am, of course, far from being a developer, but I almost feel like one: I have made another pull request!
Here are the git steps. Do you think it is sensible, if I put them into a chart similar to the bug tracker workflow?
  • One time actions:
    • create an account on github
      Let's assume the name of the new user is DonaldDuck
    • In the browser clone/fork the official FreeCAD repository
    • on your computer open a terminal and change directory to the place where you want to have your local copy
         cd /home/DonaldDuck/develop
         git clone https://github.com/DonaldDuck/FreeCAD FreeCADLocal # create local copy named FreeCADLocal on your
             	  		 		     		  #  computer. If you omit "FreeCADLocal",
             	  		 		     		  #  the default is "FreeCAD"
         cd FreeCADLocal            # all subsequent git commands are to be executed from within this folder
    now you have finished the setup of your development environment
  • Sync your clone, according to wmayer it is sufficient to do this once a month
    git checkout master 	   # change to your local master branch
        	     		   # if you encounter problems, consider to force the checkout with the command
    			   # git checkout -f master
    git fetch upstream  	   # get changes from the official FreeCAD-Repository
    Annotations
    • After
      git checkout master
      I got an error message indicating that some files should be overwritten, which is a bit frightening, because the directory did not exist before. Perhaps someone can have a look if there is a problem in the official FreeCAD repository,
      worked.
    • When I did my very first
      I must have created an empty commit which later occured in my first pull request. This was perhaps due to the mysterious changes during checkout.
  • If you want to contribute to FreeCAD, e.g. by developing a new function "Do_What_I_Mean", short "dwim"
    git branch dwimBranch	  # create a new branch
    git checkout dwimBranch
    make all the changes necessary to implement dwim
    if you have added new files make them known to git with e.g.
    git add dwim.py
    git commit -am "dwim is a new function which under all circumstances does exactly what I want"
                        # this commits the changes from the branch to your local master
    # make further changes: code - commit - code - commit ...
  • publish your changes so that they finally will reach the official FreeCAD
    git checkout master
    git fetch upstream
    git rebase master
    git push -u origin dwimBranch     # send your changes to your DonaldDuck git account
    In the browser go to your DonaldDuck account and create a Pull Request with appropriate further comments
    Annotation
    When making the final push, I can omit the branch name and I get asked to set one of the options
    git config --global push.default matching
    or
    git config --global push.default simple
    my guess is, that simple is what pushes just the current branch.
