Curves workbench
Chris_G
Curves workbench
Post by Chris_G »
Kunda1 is kindly taking care of the addon manager, and asked addon developers to document their addons and present them here , on the forum.
So, here is a presentation of my "Curves" workbench :
https://github.com/tomate44/CurvesWB
Important foreword :
- I am a very bad coder, and this workbench is probably very badly coded.
- So please don't use it for any serious work
My main interest is about NURBS curves and surfaces ( and I've learned a lot about them since I've been here. Thanks guys ! ).
The first tool is about creating BSpline curves.
Keyboard commands are displayed in the upper-left corner.
Next is a tool that turns an edge into an editable BSpline Curve.
This is a crappy temporary tool, until I make a real freehand curve editor ...
Curve degree can be increased / decreased.
Poles can be moved with the properties of the "Poles" section.
Double-click the "Spline" object to show / hide the control points.
I use it to check the parametric behaviour of the other tools.
Third tool joins a set of connected edges into a BSpline Curve.
There is an option for breaking the curve on sharp corners.
It can be useful on imported SVG, to get a real single curve from a smooth SVG path.
Fourth tool discretizes an edge ( or the first wire it belongs to ).
This tool offers all the parameters of the Part.Edge.discretize() python API.
Fifth tool is the best friend of "Discretize". It approximates a set of points to a BSpline curve (or surface).
This tool offers all the parameters of the Part.BSplineCurve.approximate() python API.
When using this tool on several objects, each one will get approximated by a curve.
But if several objects ( with same number of points) are put in a Group, and the tool is used on the Group, it will create an approximating surface.
"Discretize" and "Approximate" could be useful for example in some cases where a sweep operation fails because of a bad sweep path.
To be continued ...
triplus
Re: Curves workbench
Post by triplus »
Nice!
microelly2
Post by microelly2 »
Good to know there is a GUI for these methods.
hammax
Post by hammax »
...sweeping with 2 rails:
If I use "birail-sweep" on two logarithmic spirals, the feature uses automatically a (ruled) connecting edge.
Trying to make a sweep out of a circle or an arc, does not deliver a surface.
I see no possibility, to connect the sketch/facebinderobj to the sweep-paths.
(Trying to build a snailshell, for example).
Chris_G
Post by Chris_G »
hammax wrote: Mon May 29, 2017 9:01 am ...sweeping with 2 rails:
The Sweep On 2 Rails requires 3 steps.
Please update the Workbench, since I added a tool yesterday.
Step 1 -> create a Birail object out of 2 edges
Step 2 -> select the Birail and the profiles and create the Sweep on 2 rails
Step 3 -> Approximate the point cloud with a surface
I don't think it will work on closed profiles.
It also requires at least one profile at each end.
This is highly experimental Work In Progress.
hammax
Post by hammax »
Hello Chris,
...I tried it again with ships construction - Sailboat-halfhull.
It's my longterm goal in FreeCAD.
Using my plane-grid and fife sketches I did my first try with your curves wb.
Only problem is, I can't get the hull's shape and a mirroring.
SecRumpf.FCStd
(62.36 KiB) Downloaded 533 times
Chris_G
Post by Chris_G »
You can approximate the Sweep2Rails object with a surface ( 5th tool of my WB ), and you'll be able to mirror this surface :
hammax
Post by hammax »
...Wow, thanks - everything you want to see is on board.
Especially the wireframe .
Will there be a view-control on Wireframe/Points in the future?
I got curious by
https://forum.freecadweb.org/viewtopic. ... 28#p180586
easyw-fc
Post by easyw-fc »
Hi Chris,
very nice WB!
Do you have a main icon for the WB?
In FC 0.17 windows I cannot see the WB icon in the WB selector...
thanks
Maurice
Chris_G
Post by Chris_G »
hammax wrote: Mon Jul 03, 2017 10:06 am ...Wow, thanks - everything you want to see is on board.
I got curious by
Look at the "DisplayMode" property of the Sweep2Rails object ( as seen in your last screenshot ).
Just to be clear : the output of the Sweep2Rails tool is 2D array of points, with different ways to view it ( the DisplayMode property ). But it is not at all a surface yet. This is why it should then be approximated with a surface, because you'll probably want a real face in the end.
I kept the Sweep2Rails / ApproximateSurface as separate steps, because the approximation tool has a whole set of settings already, and the processing can be long ( or even endless ) on bad point arrays ( that have self-intersection for example ).
This way, I can check that the point cloud is good, keep the "fast to recompute" Sweep2Rails object visible during work, and go for the approximate object later.
easyw-fc wrote: Mon Jul 03, 2017 11:19 am Do you have a main icon for the WB?
You're right, no icon, indeed.
I'll look for one. Thanks.
