Usually it's because I've messed up a conversion QString <--> std::string or QString <---> char*. For Symbols, QByteArray gets involved too. Lots of opportunity to mess up non-Ascii. I'll look into it.yorik wrote:One little problem I found too, it seems that I can't add utf-8 text to a TechDraw Symbol (and therefore Draft & Arch too). For ex, try creating a symbol with the attached file below. Any idea to solve this?
The Big TechDraw Comments Thread
- wandererfan
Re: The Big TechDraw Comments Thread
- wandererfan
Found it. char* to QString to QByteArray. PR to follow.yorik wrote:One little problem I found too, it seems that I can't add utf-8 text to a TechDraw Symbol (and therefore Draft & Arch too). For ex, try creating a symbol with the attached file below. Any idea to solve this?
Fast finding! Thanks!
Hopefully this is the right place to post.
Attached a screen and a file of a Arch Section on Tech Draw. I would like to use the Rendring Mode Solid instead of Wireframe. I would like to see the colors and transparency the part really has on the paper. But it still shows as wireframe. Am I missing something?
OS: Debian GNU/Linux 8.6 (jessie)
Version: 0.17.8817 (Git)
Build type: Unknown
Hash: 253907d15f80369cd6a900007d5460caca4517aa
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
Build type: Unknown
Qt version: 4.8.6
OCC version: 7.0.0
hmm there are still some problems here and there, but solid rendering should work... I'll check.
In the meantime this is what I produced today, this is the raw techdraw output:
How did you do that. I stuck with a simple wall ... No filling inside the cutted walls.yorik wrote:hmm there are still some problems here and there, but solid rendering should work... I'll check.
Build type: Unknown
Qt version: 4.8.6
OCC version: 7.0.0
- wandererfan
Wow. Very impressive!yorik wrote:In the meantime this is what I produced today, this is the raw techdraw output
Nice to see caption in drawing.
How can I change font size. it is overlapping with section view text. Also rotate along with view [see section B-B]
- sample 4.fcstd
- (59.8 KiB) Downloaded 88 times
- freecad techdraw.png (31.86 KiB) Viewed 5927 times
Is it possible to do like this shaded view in tech draw
- shded view.png (34.39 KiB) Viewed 5923 times
@bernd you need to set the ShowFill property to True in the ArchView. But unfortunately on your example it doesn't work well, the two concentric wires are both filled. This is a difficult case... What we get from the cut algo is an unsorted list of edges, it'll be hard to detect such holes...
If you want to have a look at my file above: https://github.com/uncreatednet/casa-ec ... 2001.FCStd
@wandererfan Have you seen that now the label doesn't encompass the whole view anymore, but stays at the corner? (See Bernd's screenshot above). Something might have change in the code that gets the Symbol bounding rectangle...
