Page 6 of 11
Re: [FreeCAD 0.20] a beta release for Windows is available
Posted: Sat May 28, 2022 12:59 pm
by ebrahim raeyat
OS: Windows 10 Version 2009
Version: 0.20.28936 (Git)
Branch: Branch_0.20beta1
Hash: b02705d79f2e1adc7773f0c845e0acc5ae8fde4b
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, OCC 7.6.2
Installed mods:
* BIM
* BOLTSFC
* civilTools
* Curves 0.3.0
* dodo
* etabs_api
* hfcMystran
* Launcher
* OSAFE 2022.2.0
* Pyconcrete
* Reinforcement
* SteelColumn
* test
Unknown command 'Std_AddonMgr' in Report View at startup and not entry in Toosl for addon manager. Thanks.
Posted: Sat May 28, 2022 9:53 pm
by Syres
uwestoehr wrote: ↑Sat May 28, 2022 11:52 am
Can you find out what DLL is missing?
I tried updating Microsoft Visual C++ 2015-2022 Redistributable (x64) to version 14.32.31326 and rebooted but still hard crashes. Therefore based on the hassle with the 0.19 first release I'm inclined to think this is CPU instruction set related:
- CPU_Z.jpg (88.78 KiB) Viewed 2008 times
Posted: Sat May 28, 2022 10:11 pm
by chennes
ebrahim raeyat wrote: ↑Sat May 28, 2022 12:59 pm
Can you please turn on logging and post your log/report view content from startup?
Posted: Sun May 29, 2022 4:15 am
by ebrahim raeyat
chennes wrote: ↑Sat May 28, 2022 10:11 pm
08:37:37 OpenGL version is: 4.4 (4.4.0 - Build 20.19.15.4624)
08:37:37 Run Gui init script
08:37:37 Init: Running FreeCADGuiInit.py start script...
08:37:38 Init: Searching modules...
08:37:38 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\AddonManager... failed
08:37:39 ----------------------------------------------------------------------------------------------------
08:37:39 Traceback (most recent call last):
File "<string>", line 140, in RunInitGuiPy
File "<string>", line 6, in <module>
File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\AddonManager.py", line 42, in <module>
from package_details import PackageDetails
File "C:\Program Files\FreeCAD 0.20\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
return original_import(name, *args, **kwargs)
File "C:\Program Files\FreeCAD 0.20\Mod\AddonManager\package_details.py", line 39, in <module>
from change_branch import ChangeBranchDialog
ImportError: cannot import name 'ChangeBranchDialog' from 'change_branch' (C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\OSAFE\.\change_branch.py)
08:37:39 During initialization the error "cannot import name 'ChangeBranchDialog' from 'change_branch' (C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\OSAFE\.\change_branch.py)" occurred in C:\Program Files\FreeCAD 0.20\Mod\AddonManager\InitGui.py
08:37:39 Please look into the log file for further information
the rest of the log:
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Arch... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Draft... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Drawing... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Fem... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Idf(InitGui.py not found)... ignore
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Image... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Import... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Inspection... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Material... done
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Measure(InitGui.py not found)... ignore
08:37:39 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Mesh... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\MeshPart... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\OpenSCAD... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Part... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\PartDesign... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Path... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Plot(InitGui.py not found)... ignore
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Points... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Raytracing... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\ReverseEngineering... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Robot... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Show(InitGui.py not found)... ignore
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Sketcher... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Spreadsheet... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Start... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Surface... done
08:37:40 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\TechDraw... done
08:37:41 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\test... done
08:37:41 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Tux... done
08:37:41 Init: Initializing C:\Program Files\FreeCAD 0.20\Mod\Web... done
08:37:41 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\BIM... done
08:37:41 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\BOLTSFC(InitGui.py not found)... ignore
08:37:41 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\civilTools... done
08:37:41 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\Curves\.\(InitGui.py not found)... ignore
08:37:41 Module: Part
08:37:41 Loading Part module... done
08:37:42 flag
08:37:42 flag2
08:37:42 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\dodo... done
08:37:42 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\etabs_api(InitGui.py not found)... ignore
08:37:42 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\hfcMystran... done
08:37:42 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\Launcher... done
08:37:42 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\OSAFE\.\... done
08:37:42 Failed to get handle to OSAFE -- no icon can be generated, check classname in package.xml
08:37:42 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\Pyconcrete... done
08:37:45 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\Reinforcement\.\... done
08:37:45 Init: Initializing C:\Users\ebi\AppData\Roaming\FreeCAD\Mod\SteelColumn... done
08:37:45 All modules with GUIs using InitGui.py are now initialized
08:37:45 Init: Initializing freecad.Curves
08:37:46 Init: Initializing freecad.Curves... done
08:37:46 All modules with GUIs initialized using pkgutil are now initialized
08:37:46 Init: Loading FreeCAD GUI
08:37:46 Init: Running FreeCADGuiInit.py start script... done
08:38:01 Init: Activating default workbench StartWorkbench
08:38:01 Loading GUI of Web module... done
08:38:01 Loading GUI of Start module... done
08:38:01 Loading Start module... done
08:38:01 Unknown command 'Std_AddonMgr'
08:38:01 Init: Showing main window
08:38:01 Main window restored
08:38:01 Show main window
08:38:01 Toolbars restored
08:38:01 3Dconnexion device not attached.
08:38:01 Init: Entering event loop
08:38:01 Init: Executing event loop...
08:38:02 Init: Processing command line files
Intentionally I set 2 blank lines before and after the error line.
Posted: Sun May 29, 2022 4:20 am
by ebrahim raeyat
oh, I have change_branch in my OSAFE workbench too
https://github.com/ebrahimraeyat/OSAFE/ ... _branch.py
Posted: Sun May 29, 2022 10:48 am
by wmayer
ImportError: DLL load failed with error code 3221225501 while importing MeshPart
Download the utility
Dependency Walker. Start FreeCAD, open its Python console and enter:
import os
os.system("depends.exe") # set here the full path to the Dependency Walker
Inside Dependency Walker load the file MeshPart.pyd and check if a DLL is missing or if anything looks suspicious.
Posted: Sun May 29, 2022 10:54 am
by Kunda1
We should document this Dependency Walker troubleshooting technique
Posted: Mon May 30, 2022 1:33 am
by uwestoehr
Syres wrote: ↑Sat May 28, 2022 9:53 pm
I think a DLL is missing, but then FC does not crash. Can you please do what was suggested here:
https://forum.freecadweb.org/viewtopic. ... 81#p598281
Here is the dependency walker tool:
Posted: Mon May 30, 2022 9:27 am
by Syres
Missing Dlls from
MeshPart.pyd are:
API-MS-WIN-CORE-WINRT-ERROR-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-ROBUFFER-L1-1-0.DLL
API-MS-WIN-CORE-WINRT-STRING-L1-1-0.DLL
DCOMP.DLL
IESHIMS.DLL
I've looked in previous Libpack builds and cannot find any trace of these Dlls to copy over.
Posted: Mon May 30, 2022 3:25 pm
by uwestoehr
Syres wrote: ↑Mon May 30, 2022 9:27 am
Missing Dlls from
MeshPart.pyd are:
DCOMP.DLL
IESHIMS.DLL
I don't have these DLLs on my PCs (all Win 10). It seems to be Win7-specific:
https://github.com/dotnet/core/issues/6976
In this issue they reference .Net for Win7 installations:
https://docs.microsoft.com/en-us/dotnet ... ional-deps
So maybe you need to install the latest .Net libraries.
Since I don't have any access to Win7 (even no friends operate this anymore) I cannot help further.
