Cycloidal Drive Workbench update
I've updated my cycloidal drive workbench https://github.com/iplayfast/CycloidGearBox to add MasterSketches for all parts. The idea being you use the workbench to figure out number of teeth, sizes an so on, and then use the MasterSketches as references to parts you make with PartDesign.
Suggestions are welcome, and I'm wondering how I could get into the freecad addon system. (if it's worthy)
Working on...
- adrianinsaval
Re: Cycloidal Drive Workbench update
I think this is where I failed before. I don't see any way of registering to edit the wiki. Can anyone help me with that?
Working on...
Getting this error when trying to select the workbench from the workbench list:
No module named 'cycloidDiskSketch'
File "<string>", line 77, in Initialize
File "C:\Users\mwganson\AppData\Roaming\FreeCAD\Mod\CycloidGearBox\cycloidbox.py", line 53, in <module>
import cycloidDiskSketch
Sorry bout that. fixed now.
Working on...
Fixed again. I've since noticed that after saving files, and then reloading them, references to other files are lost, so it's not releasable yet.
I've explained the problem and asked for help here: https://forum.freecadweb.org/viewtopic.php?f=22&t=66865
Working on...
MasterSketch003 has some kind of an issue. Changing constraint from -2 to +2 fixes it, but also flips the geometry.
Invite to 2023 FreeCAD (and Free CAE) Users Conference
Good Day @iplayfast
My name is Varnu Govender, I am the assistant to Dr du Plessis at the University of Pretoria, South Africa.
We are organizing the 1st Annual FreeCAD (and Free CAE) Users Conference, which is set to take place in Early 2023.
I have taken interest in your Workbench, and I would love if you could present your work at the conference.
You are welcome to present your workbench in the following manner:
I hope to hear from you soon.
Regards
Varnu Govender
- Introduction/Overview of your Workbench
- Run-down on how the workbench operates through the user interface and backend.
- A tutorial demonstrating the full functionality of the workbench.
- A showcase of something that has been created/modelled in the workbench.
Regards
Varnu Govender
