A macro to rig tiles on surfaces. make normals on a surface too.
Select a face, then run the macro.
Tile Face
Tile Face
- Face2try.FCStd
- (237.46 KiB) Downloaded 137 times
- TileFace.py
- (6.69 KiB) Downloaded 169 times
- Capture.JPG (36.04 KiB) Viewed 4768 times
Re: Tile Face
Super cool!!
Maybe you can find more ideas from http://www.co-de-it.com/wordpress/code/blender-tissue
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
Re: Tile Face
I would like to make voronoid or delaunay pattern, but my python level is low.
Re: Tile Face
Hi, thanks GlouGlou for the macro- great for adding knurling to any object. As I try to recreate german WW2 fighter style grip KG13 there is one little thing to ask- is there any way to change knurling horizontal and vertical angle ?
Looks like knurling is at some 30 deg angle of horizontal axis, while the one I can create looks more square :
OS: Windows 8.1 Version 6.3
Version: 0.19.24291 64bit
Branch: releases/FreeCAD-0-19
Python : 3.8.6+
Qt : 5.15.2
Coin : 4.0.1
OCC : 7.5.0
Locale: Polish
Python : 3.8.6+
Qt : 5.15.2
Coin : 4.0.1
OCC : 7.5.0
Locale: Polish
Re: Tile Face
Update 20.2.22
So after several restarts of Freecad I still get the same error message but now it works (the only difference is that earlier I had the macro in a custom folder and now it is in the "original" folder, I also renamed the macro from .py to .FSMacro if that is of any difference?
Hi, and thanks for the script. It seems just what I need but does it work in the latest version? When I try to use it on any face I just get this message:
I get the default 6x6 points and I can change the style but it seems I only get faces and I believe I should get solids? I opened the demo sketch from the first post and I get the following error three times (as there are three objects):
I see the same solids as in the image in the post but I can't make any changes to the tiles. Any ideas on what is wrong? My setup details are below
Part::FeaturePython / TileFace: Links go out of the allowed scope
<string>(1)<class 'AttributeError'>: Module __main__ has no class TileFace
OS: Linux Mint 20.3 (X-Cinnamon/cinnamon)
Version: 0.19.24366 (Git) AppImage
Branch: (HEAD detached at 0f9259c)
Hash: 0f9259cda103ae1824ac16c68ac9b4a0d54b05fc
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
