I liked your model to check Ajinkya's latest PR (point on b-spline). Actually it seems to be that with this new ability, you will be able to do much of what you want with about 3 or 4 well selected sections:lordsansui wrote: ↑Sat Jan 21, 2023 5:04 pm I think 10 points might be enough, but talking with other loudspeaker builder I can check if we might need more or less points.
Yes, I used Bspline to connect all points, besides the curve do not exactly pass in the points and think for a real purpose is accurate enough.
Here there is a single B-Spline of 4 poles. The first three vertical lines and the last one have the endpoint, point on object (point on B-Spline). As you can see this (much simpler) B-Spline passes through all the other endpoints of the other vertical lines, even if there is no constraint at all on them. This could simplify the sketch quite a lot:
Of course, this selection of which segments to constraint, as well as the number of poles, is for me "random", as I do not know much about the real problem you are trying to solve. But it may suggest 4 uniformly distributed vertical lines may be enough for approximating the exponential...
I think we will have this new ability in master pretty soon.
