openBrain wrote: ↑Mon Nov 21, 2022 6:07 pm
Now I wonder if we are in the good direction.
Hmm I see. Myself as a user I don't use any of constraint, element & Edit control.
Well I do use Edit control from time to time to show grid but that's very occasional. The only time I used element and constraints is when I've been developping tool setting, to see the geometry end/start points and so on. For me the only important taskbox is Tool settings. Which is missing anyway.
I reworked element and constraint only because their ui was quite bad and I thought it would be quick, though it ended up taking a lot of time.
Now for Edit control, I still think that this is wrong to take so much space for a few settings. My first suggestion was to put a global 'setting' button in the toolbar, but that didn't seemed to gather much support. Then today I had this idea of splitting in the existing 'settings' button which sounds like it make sense because looking in the element widget to change the element rendering order does make sense.
What setting do you think would be annoying to use with this idea? In the discussion it didn't felt like many people would miss rendering order if we get rid of it completely. So it's the 'Auto constraint'?
