Would there be interest for a Measurements Workbench?
Zolko
Re: Would there be interest for a Measurements Workbench?
Post by Zolko »
dprojects wrote: Sun Sep 25, 2022 7:43 pm Also I don't have support for angles because I don't see FreeCAD tool to measure angle from python.
you can do this to measure angles between 2 shapes :
    def angleShapes( self, shape1, shape2 ):
        if shape1.isValid() and shape2.isValid():
            # get the direction of the shape
            dir1 = self.getDir(shape1)
            dir2 = self.getDir(shape2)
            if dir1 and dir2:
                angle = dir1.getAngle(dir2)*180./math.pi
and
    # figure out the direction of a shape, be it a line, a surface or a circle
    def getDir( self, shape ):
        direction = None
        # for a segment, it's the normalized vector along the segment
        if self.isSegment(shape):
            line = shape
            pt1 = line.Vertexes[0].Point
            pt2 = line.Vertexes[1].Point
            vect = (pt2.sub(pt1))
            if vect.Length != 0:
                direction = vect / vect.Length
        # for another line (like Datum::Line) it's the Z vector multiplied by the Line's Placement
        elif self.isLine(shape):
            direction = shape.Placement.Rotation.multVec(App.Vector(0,0,1))
        # for a Circle it's the circle's axis
        elif self.isCircle(shape):
            direction = shape.Curve.Axis
        # for a flt face it's the normal
        elif self.isFlatFace(shape):
            direction = shape.normalAt(0,0)
        return direction
Vincent B
Post by Vincent B »
@easyw-fc @Zolko
About caliper, could be useful to have an parametric measurement. With an option, values could be move inside End and Start x,y,z. When changing the edge, measurement will follow :?:
dprojects
Post by dprojects »
Zolko wrote: Wed Sep 28, 2022 6:37 pm you can do this to measure angles between 2 shapes :
yes, but how to draw it? currently I use "App::MeasureDistance" FreeCAD object for that, and I don't see similar thing for angle drawing ;-)
the "App::MeasureDistance" works with cut-list so you can create your own custom measurements list...
Thanks
Darek
github.com/dprojects
workbench for woodworking is available at: github.com/dprojects/Woodworking
mario52
Post by mario52 »
Hi
have you try WorkFeatures ?
mario
wandererfan
Post by wandererfan »
For your amusement...
>>> import Measure
>>> m = Measure.Measurement()
>>> m.addReference3D("Box", "Edge1")
>>> m.length()
10.0
>>> m2 = Measure.Measurement()
>>> m2.addReference3D("Box", "Edge1")
>>> m2.addReference3D("Box", "Edge2")
>>> m2.angle()
90.0
dprojects
Post by dprojects »
wandererfan wrote: Thu Sep 29, 2022 2:08 pm
import Measure
m2.angle()
90.0
Yes, this is how I would like to calculate the angle in the future. But the biggest problem is to draw beautifly the angle ;-) I guess there is no function at FreeCAD for that? and this may not be easy, so this needs to create own function for draw the angle. So I postpone this feature for later. Also I have to make support for irregular non-rectangle shapes, what probably will take some time ;-)
Thanks
Darek
